Replacing and tuning 1.9L (Digijet) AFM
kenoravsky
kenoravsky is offline
PostPosted: Fri Aug 21, 2020 12:58 pm    Post subject: Replacing and tuning 1.9L (Digijet) AFM Reply with quote
After a few years of asking dumb questions and getting smart answers, I am proud to say that I can finally contribute something to the Samba.
A few years ago Quixotix gave us this very useful post about tuning a 2.1L AFM:
Unfortunately, I have a 1.9 Digijet, and I had a slightly different situation: My van ran pretty well, but had some serious dead spots on the AFM carbon tracks, which took some nursing the throttle at certain speeds and loads. Tencentlife's 5 volt testing procedure confirmed this. I found a used AFM with good carbon tracks that I was able to clean up. It tested perfect electrically. However, the wiper position was a bit different, and I couldn't tell if the spring had a different adjustment. The idle mix screw was different too, but that was easy to assess and change.
Here's my adjustment (2.1L to 1.9L) to Quixotix's procedure:
1) O2 sensor only has one wire, so the correct wire to use is obvious.
2) There is no idle control valve, so nothing to disconnect there.
3) Temp sensor II is on pins 2&7 instead of 6&10.
4) If you want to compare how one AFM spring setting compares to another's, remove the AFM from the vehicle and bench test it with a shop vac. I just sealed up everything and gave the AFM full shop vac vacuum, which ran about 3/4 up the scale. I marked the wiper positions on both AFMs and they were identical.
Bottom line: Better idle, better acceleration and a bit more power. I'll check on fuel economy over the next few tanks. Now I can rebuild or get the old AFM rebuilt and have a good spare.
1983 Westy (air cooled)
1984 Westy
tencentlife
tencentlife is offline
PostPosted: Fri Aug 21, 2020 2:02 pm    Post subject: Re: Replacing and tuning 1.9L (Digijet) AFM Reply with quote
Just don't vacuum the shop between tests!
See innovative Vanagon accessories at the Vanistan shop:
Hmmm, provincial much?:
"I wouldn't go much on whats written on the samba, they love a "theory" and rarely ask any Europeans what is actually correct."
kenoravsky
PostPosted: Fri Aug 21, 2020 2:16 pm    Post subject: Re: Replacing and tuning 1.9L (Digijet) AFM Reply with quote
Yes, we must be good scientists. I did these tests one after the other. Any extra junk in the shop vac or on its filters would change its vacuum.
1984 Westy
