Fuel pump help
pilcher
pilcher is offline
PostPosted: Fri Apr 20, 2007 11:10 am    Post subject: Fuel pump help Reply with quote
My fuel pump isnt getting any electrcity to it. its a 73. Do I need a new fuel pump relay?Can someone please respond with at least where to get started?
nodrenim
nodrenim is offline
PostPosted: Fri Apr 20, 2007 4:19 pm    Post subject: Reply with quote
I hope that you have checked the fuse? I would next check the wiring plug that attaches the wires to the fuel pump. Sometimes they get corrision and cease to function, this has happened to me on two of my 3's. Or maybe the wire just vibrated loose, I've known that to happen also. This is where I would start. Good Luck!
Russ Wolfe
Russ Wolfe is offline
PostPosted: Fri Apr 20, 2007 4:52 pm    Post subject: Reply with quote
When you first turn the key on, the pump only runs for about 2 seconds.
Check the fuses, and the wiring. Check the relay under the rear seat.
Check that the computer has power when the key is turned on.
When you first turn the key on, you should here 2 clicks, about 2 seconds apart. This says the computer has power and is alive.
With the key on, ground the connection in the spot of light in that picture. The pump should run continously.
Gary: OK. Ima poop.
pilcher
pilcher is offline
PostPosted: Fri Apr 20, 2007 4:56 pm    Post subject: Reply with quote
fuses and wiring is good. Fuel pump is brand new. Is the only thing left the relay? and if so does anyone have the part number for it?
pilcher
pilcher is offline
PostPosted: Fri Apr 20, 2007 4:57 pm    Post subject: Reply with quote
And its not getting electricity from the start. Like its not getting any power inititially.
Russ Wolfe
PostPosted: Fri Apr 20, 2007 5:02 pm    Post subject: Reply with quote
Check the wire from the battery, to the relay next to the voltage regulator under the rear seat. These get corroded. Also check the screw that holds the regulator. It needs to be tight and clean. The screw with the brown wire under it.
Gary: OK. Ima poop.
Chory
Chory is offline
PostPosted: Sat Apr 21, 2007 11:56 am    Post subject: Reply with quote
First yeah, check the ground connections. Note that there are 2 (two) relays; one behind the fuse box (relay one, as I call it) and another beneath the rear seat (this one has an in-line fuse beside it, which should be replaced if it is anything but new) this one is controlled directly by the ECU. To see if the problem is with the first relay (#1), bypass it temporarialy by doing the following:
disconnect the battery
disconnect the two red leads from the relay behind the fuse box
paperclip the two leads together
reattach the battery
At this point, the pump should run constantly. If so, the issue is with the relay in the dash. I just ordered two relays from CIP1, and they are SIGNIFICANTLY different from what is on the car—five terminals, but arranged entirely differently from those on the VW regulator—so if you find a one which matches, I'd like to hear about it.
Alternately, I'll pist pics of what I have and we'll see if someone has a work-around.
--Chory
Be kind…
'71 "Shantung Yellow" FI 1600 Square
(O)<+>(O) -Audrey
‘91 “Carnival Yellow” MTREC 660cc Honda Beat
/o¡o\
Chory
Chory is offline
PostPosted: Sat Apr 21, 2007 6:09 pm    Post subject: Reply with quote
Replacement relay:
Terminals numbered:
----87---
86 87 85
----30----
Shall I just omit the push-on plastic connector and wire direct to the apropriate terminals with spade-connectors?
Regarding "apropriate" terminals:
Bentley diagram shows three wires to the under dash relay
one gray - term. 85 to ECU
one blue & yellow - term. 86 to under-seat ECU relay
one black & red - term. 30/51 to fuse box
one empty terminal - term. 87 (is this where power runs out to the pump?)
I have:
One Gray - term. 86
(which runs to a plastic connector alongside)
One Blue & Yellow (faded to white) - term. 85
Two Red (one going to the fuse box [term 30/51], one toward the rear of the car[term. 87])
the relay I have also has a single unused terminal (paired at term. 87)...for a total of 5 terminals...with no ground.
What's up with that? Why are term 85 & 86 wires transposed? Where to does the red wire run from term 87, which Bentley shows as unused (or is that the wire which runs power to the pump? why is it not shown in the Bentley?)? I presume that term. 30 on the replacement is = to term 30/51 on the old one...right?
The new relay is plastic, should I ground it in some manner as the old one seemed to be ground at the body of the car? Or does the under-seat relay ground wire (brown) function to ground the entirety of the system?
Be kind…
(O)<+>(O) -Audrey
/o¡o\
Russ Wolfe
PostPosted: Sat Apr 21, 2007 7:10 pm    Post subject: Reply with quote
The one under the rear seat is not controlled by the ECU, it is the power FOR the ECU. And the relay shown is not the right one for the FI. It will probably work, but be careful that it gets wired right, and has the right current rating.
Gary: OK. Ima poop.
Chory
Chory is offline
PostPosted: Sat Apr 21, 2007 7:44 pm    Post subject: Reply with quote
Thanks, Russ, for the clarification.
So now I am a little concerned.
The replacement is the only one I can find—have found multiple references to (old)Bosch # 0 332 003 021 (VW# 311 906 061) being replaced by new style Bosch # 0 332 019 150 (this from both 914 forums as well as Volvo forums)
HOWVER:
Old style is 12V 10A
new style; 12V 30A
All necessary terminals are present and numbered correctly tho their layout differs (altho term. 30/51 is replaced by term. 30).
Bosch website is of no use and has no reference to old style # or new—it would seem you cannot search by part #.
Sites hawking Bosch FI supplies listing new part with old part #:
http://www2.partstrain.com/partlisting/full/saab/9...tion+Relay
http://www.autopartswarehouse.com/replacement_sm/volvo~fuel_pump_relay~replacement.html
http://store.autopartsliquidations.biz/0332019150.html
Be kind…
(O)<+>(O) -Audrey
/o¡o\
Tram Premium Member
Samba Socialist
Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Tram is offline
PostPosted: Sat Apr 21, 2007 8:02 pm    Post subject: Reply with quote
HOWVER:
new style; 12V 30A
This is one of my chief gripes with parts houses these days. They think that because some catalogue somewhere says a different part number will fit, it's gospel. You can only "condense" part numbers down so much. I can't tell you how many times this happens. Sometimes, these catalogue bloopers are out and out mistakes that get perpetuated and multiplied by dozens of distributors replicating the wrong information in their computer programs. And, "parts professionals" today know nothing about parts. If the computer says it fits, your car must be incorrect.
Get the right part, even if you have to get a used one. Unless, of course, you want to have it fail right off the bat, or every few months. Rolling Eyes
May 4, 1970- 50 years- NEVER FORGET!! Sad
vwfye wrote:
Oh the joy of custom things...
RIPRW
"I'm very fond of long walks, especially when taken by those who annoy me."- Fred Allen
Chory
Chory is offline
PostPosted: Sat Apr 21, 2007 8:13 pm    Post subject: Reply with quote
Aaaaaaarrrrrgghhh!
Be kind…
(O)<+>(O) -Audrey
/o¡o\
Russ Wolfe
PostPosted: Sat Apr 21, 2007 8:42 pm    Post subject: Reply with quote
Chory wrote:
Aaaaaaarrrrrgghhh!
$5.00 plus shipping gets you a known good relay.
Gary: OK. Ima poop.
KTPhil Premium Member
KTPhil is offline
PostPosted: Sun Apr 22, 2007 10:14 am    Post subject: Reply with quote
Those look like high current foglamp relays. They certainly have the capacity (30A), so as long as the contact resistance and pull-in current draw are small (though I've never measured them for the FI relays), they should work for FI.
Chory
Chory is offline
PostPosted: Sun Apr 22, 2007 11:41 am    Post subject: Reply with quote
Tram wrote:
This is one of my chief gripes with parts houses these days. They think that because some catalogue somewhere says a different part number will fit, it's gospel. You can only "condense" part numbers down so much.<br>And, "parts professionals" today know nothing about parts. If the computer says it fits, your car must be incorrect.Rolling Eyes
My gripe is with Bosch for not maintaining their database in a searchable format. How dificult would it be for the manufacturer to chime in on the topic? They made this stuff, they could at least verify wether there is a surrogate available or not (even just listing the part # accompanied by a bog fat NLA) as opposed to just eliminating all reference to it from their catalogue. One can look up the car on their site, find all accompanying pieces which are still under manufacture, but not search by Bosch part numbers—now that is the stupidest thing I have ever heard.
I've seen them called "headlight," "foglamp," "horn," and "Fuel Pump" relays. I think this is a consequence of what Tram is calling "condensing." Seeing as I now have two of them, I am going to put the thing in today and see what happens—worst case scenario, it short citcuits, blows out the used fuel pump, melts relay-plastic onto my foot, blows the fuse, and causes an in-dash fire. All of which I can handle. What I cannot handle is the fuel pump cutting out at 35mph again—it's embarrasing—tho the car is light in weight, I hate pushing it.
Will report back later.
Should the above occur, expect a PM from me.
What are we to do in another 30 years when all of these relays really are dead and NLA? Convert to Carbs?
Be kind…
(O)<+>(O) -Audrey
/o¡o\
Russ Wolfe
PostPosted: Sun Apr 22, 2007 1:21 pm    Post subject: Reply with quote
The original relay was not made by Bosch. It was made by SWF, IIRC, without looking at one.
VW used many different manufacturers to supply parts for their cars.
Gary: OK. Ima poop.
pilcher
pilcher is offline
PostPosted: Sun Apr 22, 2007 2:20 pm    Post subject: Reply with quote
Allright. I have power to the pump and it is going, but I am not getting any fuel to the rest of the engine. Ive checked the wiring, I have hooked the fuel pump up directly to see if it was working, which the whirring sounds seem to mean. But I have no idea why fuel wouldnt be reaching the engine.
KTPhil is offline
PostPosted: Sun Apr 22, 2007 3:11 pm    Post subject: Reply with quote
Is it exiting the pump? If so, you may have a blockage in the line.
pilcher
pilcher is offline
PostPosted: Sun Apr 22, 2007 3:13 pm    Post subject: Reply with quote
Would a block in the line prevent all fuel from getting there? And if so how do i run it out?
KTPhil is offline
PostPosted: Sun Apr 22, 2007 3:21 pm    Post subject: Reply with quote
Well, check the pump itself first: attach a hose to the outlet and jumper it to run for a couple of seconds. If that works well, then start checking each segment to see where the blockage is. You might get by with a blast of compressed air once both ends are open, but more likely you will need to replace the section.
