malcolm2 Samba Member
Joined: September 28, 2011 Posts: 1272 Location: Mount Juliet, TN
Posted: Sun Aug 23, 2020 5:40 pm Post subject: I need a couple vacuum locations.... |
I have borrowed a nice set of carbs to break-in my engine and maybe even drive the bus around my neighborhood a bit.
Now that the engine etc... is almost assembled, I noticed that this dual set of weber 44s and their intakes don't have a vacuum fitting for the vacuum advance in my distributor. And I guess I need something for the brake booster, right?
Any suggestions for this temporary set up?
Thanks. _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
SGKent Samba Member
Posted: Sun Aug 23, 2020 5:51 pm Post subject: Re: I need a couple vacuum locations.... |
a SVDA needs ported vacuum - meaning above the throttle plate so it goes away when the throttle is closed. Brakes use manifold vacuum - well below the carb so it is always there. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Sun Aug 23, 2020 7:01 pm Post subject: Re: I need a couple vacuum locations.... |
If they are Real Weber’s and Not Chinese knockoffs they have ports next to the
Mixture screws on the base of the carbs.
Could also be that no one ever removed the tiny screws and installed the tubes
For the vacuum hose
Dual Weber’s work best on our buses if both carbs have a tee then another
Hose to the distributor port.
If in doubt you could call or email John at aircooled.net for parts.
_________________ V.W.owner since 1967
Last edited by old DKP driver on Mon Aug 24, 2020 8:18 am; edited 1 time in total |
Posted: Mon Aug 24, 2020 5:23 am Post subject: Re: I need a couple vacuum locations.... |
I'll take a pic today and see if someone can point out this port. These were on a 1.7 in a 914, so the PO may not have needed a vacuum. _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
Posted: Mon Aug 24, 2020 4:32 pm Post subject: Re: I need a couple vacuum locations.... |
Both sides. Thanks for the markings.
Posted: Thu Sep 24, 2020 6:53 pm Post subject: Re: I need a couple vacuum locations.... |
old DKP driver wrote: |
For the vacuum hose
OK I am back on this.... Yes they are REAL. "Made in Spain" is on them
And YES, no one removed the screws on the port you have circled GREEN. So I did that and put them in a baggie for the owner.
If I understand you correctly. I should get a hose on both of these ports, run them to a TEE. Then run a hose from the 3rd port of the TEE to the Vacuum can on the Distributor.
BOOM done, right? _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
Posted: Thu Sep 24, 2020 6:56 pm Post subject: Re: I need a couple vacuum locations.... |
Next issue. And maybe it won't matter, but let's hear what you got.
These carbs were purchased some time ago, and to the best of my knowledge, they have never been used.
What should I do about that? Also should I worry about jetting, etc....? How do I know what I have? What do I need?
Remember my plan is to use these carbs to break-in my fresh 2 liter. That might pretty much be it. However, the guy that loaned them to me is a long ways from needing them. Maybe I could keep them a bit longer...
Originally purchased for a 1.7 914. No idea what i have here.
Thanks _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
Posted: Thu Sep 24, 2020 7:27 pm Post subject: Re: I need a couple vacuum locations.... |
If they were yours, you could pull the lids and see what jetting they have, but since they aren't yours maybe you should leave them alone. I know I would be really pissed if I lent a set of carbs to someone and they rejetted them without my prior consent.
airschooled Air-Schooled
Posted: Thu Sep 24, 2020 7:30 pm Post subject: Re: I need a couple vacuum locations.... |
Besides a door stop, there is no better use for a non-vacuum distributor than breaking in a new engine. _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Thu Sep 24, 2020 7:40 pm Post subject: Re: I need a couple vacuum locations.... |
airschooled wrote: |
Besides a door stop, there is no better use for a non-vacuum distributor than breaking in a new engine. |
OK. I am pretty sure we just went thru the vacuum line installation. Or did I do something wrong here? _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
Posted: Thu Sep 24, 2020 7:58 pm Post subject: Re: I need a couple vacuum locations.... |
malcolm2 wrote: |
OK. I am pretty sure we just went thru the vacuum line installation. Or did I do something wrong here? |
There are a hundred ways to skin a car. Er, cat.
Why do you want to modify borrowed carburetors?
From here on, differentiate between manifold vacuum (for power brakes) and ported vacuum (for vacuum advance.) They are functionally unrelated.
Manifold vacuum is the suction of the pistons going down on their intake strokes to assist your brake pedal effort. If you’re driving your car on the road, don’t worry about this.
Vacuum advance is a “load sensor” that advances the spark when engine load is low, like cruising at light throttle. If you’re not actively driving your car through varying conditions, vacuum advance is useless.
Slow down for a hot second and consider why and how these engines work. Just because someone on the internet says something doesn’t make it true.
Danwvw Samba Member
Posted: Thu Sep 24, 2020 8:03 pm Post subject: Re: I need a couple vacuum locations.... |
The carbs might run straight out of the box, worth a try. I would disassemble & clean passages jets etc and make notes of what all the jet sizes are and what venturi it is. 44's are kind of big for a 1.7 or 1.8 ltr but would work on a 2 ltr Type 4 engine with 28-32mm venturi's. I would prefer Weber 40 Idf's on a bus though. As far as brake boost just tap the closest intake manifold on just one of the cylinders somewhere easy for a thread in 1/4 or 3/8" pipe fitting to 1/2" tubing.
Example: just one is needed though. Be sure to run a check valve.
[img][/img] _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Fri Sep 25, 2020 5:02 am Post subject: Re: I need a couple vacuum locations.... |
Should have better worded my OP.
Theses are borrowed 44s. Borrowed for engine break in on the stand. So the brake booster question was for after break in and engine install. Since I have them and he doesn’t seem to be in a rush to get them back, it was kind of a “what-if”. But now i know. Plus these intakes have no manifold ports.
2ndly, I have learned much from these forums. Car things and people things. There are only a few people that I would jump off a bridge with. But I learn from most.
Lessons Learned here: small vacuum tee and hoses Go from both carbs to the vacuum can on the distributor. But may not be needed. Don’t worry about jetting. And of course brake boost is not needed.
I plan on the disty vacuum cause everyone on the internet says connection is needed to set the timing at 3000 rpm.
Thanks to all you people on the internet. _________________ My Toys: '75 Porsche 914, '92 Ski Nautique and now a 1972 VW Transporter Deluxe (punch list fixing) |
Posted: Fri Sep 25, 2020 6:04 am Post subject: Re: I need a couple vacuum locations.... |
malcolm2 wrote: |
Not sure what you are meaning here, but when you are setting your timing at full mechanical advance you disconnect the vacuum hose(s). |
SGKent Samba Member
Posted: Fri Sep 25, 2020 7:18 am Post subject: Re: I need a couple vacuum locations.... |
After you told us what your needs are, I would have just left them alone, set the timing with the mechanical advance only, then break in the cam and call it a day. You aren't going to run the engine up to a wide open throttle full load scenario on an engine stand anyway. If someone does without a block house and remote controls then they are suicidal. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
halfassleatherworks Samba Member
Joined: December 09, 2018 Posts: 641 Location: Reno NV
Posted: Fri Sep 25, 2020 9:17 am Post subject: Re: I need a couple vacuum locations.... |
you borrowed them... get a 019 _________________ Halfass Leatherworks*****GOT LEATHER Made to order Leather crafts, you can find us on that face book thing
Belts, wallets, mouse pads, drink coasters, Engraving, most things made in leather.
personal items if you want it in leather in Reno Nv, ***** |
