dobryan Samba Member
Joined: March 24, 2006 Posts: 16504 Location: Brookeville, MD
Posted: Mon Aug 24, 2020 5:28 am Post subject: Key vs power door locks mystery -solved- |
An interesting thing just happened with my euro bus project.
The bus has power locks but they have never worked. I do not care and actually think that not working is a better feature since I know from past experience that power locks go crazy when the wiring starts to go bad.
Friday the front door power locks spontaneously started working together as power locks for the first time in the two years I have had the bus. I guess the internal wire break that likely existed somehow bridged the gap and a strand of wire made connection. And coincidentally the key will not turn in the slider door or hatch lock. Not a bit. It is fine in the front doors. I can open the slider and lock/unlock the door from the lock knob and it makes no difference to the key not turning. The hatch fortunately was unlocked when this happened so I can still open it but the key will not turn to lock it. There was no hint of any key issue prior to this.
I am at a loss as to how to proceed to trouble shoot. Anyone ever had this happen? _________________ Dave O
The Western Syncro build
markswagen Samba Member
Joined: January 28, 2018 Posts: 1038 Location: san diego
Posted: Mon Aug 24, 2020 7:11 am Post subject: Re: Key vs power door locks mystery |
I've had no luck with the tail gate, getting it to work on the central locking seems , within the few hours I have chosen to throw at it, is impossible.
I feel the front 3, slider and cab are a bonus to have, owning two vans with and two without, I much prefer with, and I get complaints from my boss if and when hers fails.
If you are concerned about the wiring, pull the harnesses out of the doors and go through them, it's not difficult, it's a good time to upgrade the speaker wiring, and get the electric mirrors working. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
Posted: Mon Aug 24, 2020 7:31 am Post subject: Re: Key vs power door locks mystery |
The actuators are energized, forcing them against the key, just like if you have the locking system open, and disconnect the battery, you'll not be able to lock the van, you'll need to overcome that, if you are planning on removing, take the actuators out.
The tail gate, if you take out the actuator, you'll need to zip tie the linkage into its working spot, if you don't it'll move, and you'll find yourself locked out. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
Posted: Mon Aug 24, 2020 7:35 am Post subject: Re: Key vs power door locks mystery |
markswagen wrote: |
The tail gate, if you take out the actuator, you'll need to zip tie the linkage into its working spot, if you don't it'll move, and you'll find yourself locked out. |
Great. Makes sense! _________________ Dave O
Posted: Mon Aug 24, 2020 7:38 am Post subject: Re: Key vs power door locks mystery |
If you take it all out, and I wouldn't { make it work }
But if you take it all out, bring it Chula Vista, I'll throw it away for you.
Did I mention, make it all work. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1491 Location: Victoria,B.C.Canada
Posted: Mon Aug 24, 2020 8:05 am Post subject: Re: Key vs power door locks mystery |
Could be the actuators in the front doors. There are connectors for the wiring behind the fuse box and behind the glove box, where you can check continuity with the doors. Best mod I ever did was converting to remote power locks from EBay/China for about $25. |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2561 Location: Philly, mang
Posted: Mon Aug 24, 2020 8:11 am Post subject: Re: Key vs power door locks mystery |
my suggestion is to pull the power from the actuators and never think about them again. _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
Zeitgeist 13 Samba Member
Posted: Mon Aug 24, 2020 8:28 am Post subject: Re: Key vs power door locks mystery |
When you finally upgrade your van to the A1Electric kit I've been pimping for over a decade, you can bypass the flaky factory front door wiring...plus you get remote locks as an added beni. Just do it.
https://www.a1electric.com/Merchant2/merchant.mvc?...=W02F-712T
_________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6357 Location: Honolulu,Hawaii and France
Posted: Mon Aug 24, 2020 12:44 pm Post subject: Re: Key vs power door locks mystery |
Your actuator in the sliding door is stopped halfway through its cycle, just energize the contacts at the door with a battery and 2 wires, I think the top one is not used.
The rear hatch gets tricky bc the mechanical slider gets jammed and adds to the issue, even with a working actuator. The brass spinged pin gets worn out and the aluminum ramp it rides on get sharp on one end, gotta smoothen it with a Dremel, the steel sliding bar also worns out the sliding part, and it gets cocked too.
I rejuvenate these all the time for customers, one of my favorite systems to fix , it`s dumb easy. Some motors are not salvageable bc of water intrusion, corrosion damage, but you can install new ones. First things first, check continuity of wires from the connector behing the glovebox and your actuators. Be careful, colors are switched going to the rear , yellow becomes white and white becomes yellow bc they work in reverse motion as the front. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
davideric9 Samba Member
Joined: January 21, 2009 Posts: 1001 Location: Oakland CA
Posted: Mon Aug 24, 2020 1:06 pm Post subject: Re: Key vs power door locks mystery |
Under normal conditions, turning the key in the rear hatch has NOTHING to do with the power actuator. I suppose its possible the "U" shaped sliding mechanism could interfere with the lock, but some metal part would have to be broken OR the push button is not fully extended to its resting position. Remove the lock with the three allen screws and let us know what you find.
_________________ 1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012) |
Posted: Mon Aug 24, 2020 7:05 pm Post subject: Re: Key vs power door locks mystery |
but by the time you have gone in that far, why not just repair the original harness, and why go to chinesium parts, the issue is likely the wiring, replace and refit the stock stuff.
i guess adding a remote lock, but why not add that into the stock wiring.
Zeitgeist 13 wrote: |
619 201 0310 |
jmranger Samba Member
Posted: Mon Aug 24, 2020 8:27 pm Post subject: Re: Key vs power door locks mystery |
I'm kind of skeptical that the issue is electrical - if the actuators were binding, your battery would drain in short order. But ruling this out is easy: the power to the system has a dedicated wire going to one of the "P" terminals in the back of the fuse panel, and is protected by a dedicated 20A fuse. Disconnect one or the other, and see what changes this make.
Even easier for the slider - if you open it, the actuator doesn't have power. Is it still frozen in that case?
For the rear hatch, the actuator and the key are not moving the same part - the key rotates the piece where I hid the keycode, while the actuator moves the u-shaped piece left/right:
At the same time, having linkage issue in both the slider and the rear hatch at the same time, and having both causing the lock to jam is really weird. Looks like you'll have to pull some panels and have a look. Don't wait for one of the doors to jam...
Edit:
ALIKA T3 wrote: |
Your actuator in the sliding door is stopped halfway through its cycle, just energize the contacts at the door with a battery and 2 wires, I think the top one is not used. |
The more I think about it, the more I think Alika's right. Issue is that the circuit wasn't energized long enough for all actuators to reach a stable position.
Posted: Mon Aug 24, 2020 8:55 pm Post subject: Re: Key vs power door locks mystery |
markswagen wrote: |
That kit includes Swiss made actuators, though I can't vouch to the provenance of the remote controller or remotes themselves. The wiring in this kit is all encased in a thick sheath like an extension cord, so it's way better than the stock wiring in the jamb. _________________ Casey--
y u rune klassik? |
Posted: Mon Aug 24, 2020 8:56 pm Post subject: Re: Key vs power door locks mystery |
dobryan wrote: |
Hmm this can give me a kill switch via that remote as well. |
Now you're thinking like a killer. Good on you _________________ Casey--
y u rune klassik? |
Posted: Tue Aug 25, 2020 6:22 am Post subject: Re: Key vs power door locks mystery |
dobryan wrote: |
Now you're thinking like a killer. Good on you |
Done. Ordered. The remote kill switch did it for me.
I have a kill switch on my other westy and the failure mode is going to be user error when I forget to use it. I really like that I will be enabling the kill switch whenever I lock the doors, no extra brain cells required. KISS.... _________________ Dave O
Posted: Tue Aug 25, 2020 8:03 am Post subject: Re: Key vs power door locks mystery |
I finally got someone to take my advice! [MIC DROP] _________________ Casey--
y u rune klassik? |
Posted: Sat Aug 29, 2020 7:34 pm Post subject: Re: Key vs power door locks mystery |
There`s zero relation between the cylinder and the slider part unless the roll pin got out...
Here are some pics of my retrofit work.
The lock cylinder is not clocked the same way in the barrel, so I transfered the waffles. The left cylinder is the central locking model.
The little ramp got a dremel job as I mentioned earlier to make it smooth actuating.
For people retrofitting the whole assembly like me, I glued the bracket in the rear hatch rather than drilling and riveting like factory. Cleaner, less holes to rust.
The lock cylinder got a new o`ring, a Honda power steering hose o`ring from a CR-V fits perfectly! Lucky find from extra left over parts on a job I did.
I upgraded the hardware to stainless steel M8 XZN bolts from a Jetta MK4, they are free and great quality, just shorten the one that goes in the lock barrel, or an internal bridge will collapse and interfere with the functioning. BTDT...
You break it, you fix it!
I ran longer wires than the factory ones, as these will be crimped with factory connectors to connect the factory harness, but the donor wasn`t a Westfalia, so I had to modify some of the wiring sections. The red wire is actually the ground, it`s a crappy brown that looks red on pictures....
