Doverdude Samba Member
Joined: September 29, 2015 Posts: 14 Location: Dover Foxcroft Me.
Posted: Mon Aug 24, 2020 8:58 am Post subject: 1990 Westy w/ blown 2.2 Subaru engine - Should I buy it? |
Hi all, there is a 1990 Westfalia for sale with a blown 2.2 Subaru on craigslist up here in Maine. The price is $9000 it looks in pretty good shape. Would it be worth it for me to purchase this and put a 2.5 Subaru in it? Thoughts please |
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Mon Aug 24, 2020 9:01 am Post subject: Re: 1990 Westy blown 2.2 Subaru engine Should I buy it? |
If the overall condition of westy is solid, like minimum rust nice interior etc... i would strongly consider it. You can get a solid 2.2 or 2.5 used for $500 or less. If you can install then that saves a ton of money. If you have to outsource the work then the economics may not make sense. What are your skill levels? |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17153 Location: Retired South Florida
Posted: Mon Aug 24, 2020 9:05 am Post subject: Re: 1990 Westy blown 2.2 Subaru engine Should I buy it? |
It’s like buying an outboard that’s been used in salt water. Your buying the hull. A vehicle you can’t road test could have a lot of other needs. $9000 for a non running vanagon seems high. If it’s solid, “good hull” might be worth it.
It’s way easier to buy something running and sorted for slightly more. _________________ ☮️ |
oldskoolsteve Samba Member
Joined: July 01, 2007 Posts: 73 Location: Vancouver Island Canada
Posted: Mon Aug 24, 2020 9:14 am Post subject: Re: 1990 Westy blown 2.2 Subaru engine Should I buy it? |
I would.
The body is the real value... and how hard is it to find a used 2.2 from an auto wrecker and drop it in?
The conversion kit is expensive and that's already done. _________________ 63 Type 3 1500 notch
84 WESTY: Suby EJ22 powered
85 WESTY: needs engine and trans
Hoodride for life |
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1491 Location: Victoria,B.C.Canada
Posted: Mon Aug 24, 2020 9:19 am Post subject: Re: 1990 Westy blown 2.2 Subaru engine Should I buy it? |
$9000 for a 90 Westy in good shape with blown Subaru seems like a deal. Others on this list might jump on it. Swap parts are already there and might be in good shape. All you need is the 2.5,harness and ECU. Better than buying it with a running high mileage 2.1 WBX. |
squeegee_boy Samba Member
Joined: April 27, 2008 Posts: 762 Location: Langley, BC, Canada
Posted: Mon Aug 24, 2020 9:24 am Post subject: Re: 1990 Westy blown 2.2 Subaru engine Should I buy it? |
Nope, useless, not worth your time. You should PM the link to the ad so I can avoid it too.
Robyn
/But seriously, assuming it's solidbody-wise and you can do the swap, do it. _________________ 1984 FrankenSyncro Westy. EJ25 RMW kit
1971 Super Beetle with an EJ22. Oh yes. Daily driver |
pjn_wyo Samba Member
Joined: April 22, 2019 Posts: 181 Location: Bellingham, WA
Posted: Mon Aug 24, 2020 9:29 am Post subject: Re: 1990 Westy blown 2.2 Subaru engine Should I buy it? |
Buy it and swap in another 2.2 (or rebuild the one that is there) to keep it simple. |
JudoJeff Samba Member
Joined: May 24, 2013 Posts: 1179 Location: Near Springfield, MA
Posted: Mon Aug 24, 2020 9:36 am Post subject: Re: 1990 Westy blown 2.2 Subaru engine Should I buy it? |
Grab it ASAP _________________ ________________________________________
1989 Vanagon GL Westfalia Camper, Burned up on 7/31/16.
1987 Vanagon GL Westfalia Camper, Bostig & Rebuilt, sold
1986 Vanagon GL Westfalia Camper, Bostig Sold May 10, 2021
1999 Ford GTRV Westfalia camper (30% bigger Westy layout) |
Joined: April 29, 2015 Posts: 704 Location: Berkeley Ca
Posted: Mon Aug 24, 2020 9:53 am Post subject: Re: 1990 Westy blown 2.2 Subaru engine Should I buy it? |
Do it, looks good. You could rebuild 2.2 easy. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
Franklinstower Samba Member
Posted: Mon Aug 24, 2020 12:28 pm Post subject: Re: 1990 Westy w/ blown 2.2 Subaru engine - Should I buy it? |
what year 2.2? OBD1 or OBD2?
the 92-94 EJ22 have been the true work horse for Subaru. Really durable and long lasting engines, almost zero head gasket problems, can rev high all day long. About 20-30 hp less than the 2.5 but you get great reliability. _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug |
Posted: Mon Aug 24, 2020 1:47 pm Post subject: Re: 1990 Westy w/ blown 2.2 Subaru engine - Should I buy it? |
I’m not sure what you were the engine is. It was installed in 2002. |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2561 Location: Philly, mang
Posted: Mon Aug 24, 2020 1:52 pm Post subject: Re: 1990 Westy w/ blown 2.2 Subaru engine - Should I buy it? |
without confirming the transmission works... and with a blown engine... i'm not sure what i would do. it would have to be in really excellent condition to take that gamble. like everything else is there and working and in good condition.
i overpaid for my Westy project... i only say that after i've dug into it and then added up everything i've spent. i could have started with a nicer one for double the money. "they all cost 20k, it just depends you want to spend it" seems to ring true. _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
Zeitgeist 13 Samba Member
Posted: Mon Aug 24, 2020 6:20 pm Post subject: Re: 1990 Westy w/ blown 2.2 Subaru engine - Should I buy it? |
Buy it and put a real engine in there. That's what I would do, and 9 out of 10 dentists agree. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
owokie Samba Member
Posted: Mon Aug 24, 2020 7:09 pm Post subject: Re: 1990 Westy w/ blown 2.2 Subaru engine - Should I buy it? |
Zeitgeist 13 wrote: |
Buy it and put a real engine in there. That's what I would do, and 9 out of 10 dentists agree. |
That ad shows a lot of rust starting to come through. That'd kill it for me. FWIW, if price is the same I'd rather buy a van with a blown conversion done well, than one with a functional 2.1.
Homeboy is a broken record on the engine topic and ignores the fact that many VWs left the factory without VW engines. |
Posted: Mon Aug 24, 2020 7:47 pm Post subject: Re: 1990 Westy w/ blown 2.2 Subaru engine - Should I buy it? |
He’s right. Pull that 2.2 and put in a 2.5. |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4024 Location: Redwood City, California
Posted: Mon Aug 24, 2020 8:50 pm Post subject: Re: 1990 Westy w/ blown 2.2 Subaru engine - Should I buy it? |
Unless it was real rusty or really trashed I'd buy it in a New York minute but I wouldn't take my my Texas time to do.
The conversion is worth 3K on its own if it's well done.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
Posted: Mon Aug 24, 2020 8:58 pm Post subject: Re: 1990 Westy w/ blown 2.2 Subaru engine - Should I buy it? |
Yes, sell the conversion or use it to moor your boat in the harbor. _________________ Casey--
y u rune klassik? |
16CVs Samba Member
Posted: Mon Aug 24, 2020 9:03 pm Post subject: Re: 1990 Westy w/ blown 2.2 Subaru engine - Should I buy it? |
Or you could appease all the gods and take the Subaru out and put a Properly Built WBX in it.
Choose wisely.
Posted: Mon Aug 24, 2020 9:12 pm Post subject: Re: 1990 Westy w/ blown 2.2 Subaru engine - Should I buy it? |
16CVs wrote: |
Choose wisely.
Stacy |
Worst idea ever
All kidding aside, the odds are that 130k miles on a 1990 westy, the transmission is likely good. They did not suffer the fate of failed 3/4 sliders like earlier vans. Unless it did a lot of towing or poor shifting and lugging, the trans is probably fine for a long time with a fresh oil change. As far as engine, you can easily find a good used subie 2.2 to throw in there until you figure out what your dealing with. All in a good running 1990 westy subie conversion for $10k. Miles and $1000s ahead of folks with lesser vans.
Just sayin, if it were me, it would already be in my driveway |
