scirocco_crazy Samba Member
Posted: Fri Oct 02, 2020 12:45 pm Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline |
I am going to take you up on that offer for the tech support. Have a great day
Cap10323 wrote: |
scirocco_crazy wrote: |
Hi Cap10323, i will be using the EZ36 mated to a TY758 trans. The clutch is going to have to come from overseas because we never were offered the larger clutch and flywheel here in the states(out of a 3.0 manual legacy GT). I also like the fact that the trans shifting is cable driven. This way i am not limited by trying to use something from the stock bus. so the width of a bay window bus is 67.7" and the tribeca will be at 74.02". With the right wheel and tire package it should be just a bit wider. My plan although willing to be changed is to use the extra width of the tribeca suspension to help with a more stable base. I always have a fear of being top heavy at highway speeds. Plus it might look a bit cool having the wheels out just a smidge. One last thing, i would love to use the 5EAT but there isnt a ring and pinion reversing kit for that trans. Its also a lot longer and would push the engine to far back. For now it looks like the TY758 is the way to go. 6 speed with decent strength. Just as long as i dont thrash on it. |
TY758 should be able to take the power of a N/A EZ30 without issue, even if you thrash it pretty hard. The STI guys shove pretty big power through those and they seem to hold up okay.
The wider suspension makes sense, plus the added benefit of the Tribeca being nearly 1500lbs heavier than the Forester means that the suspension is more robust, and can be further reinforced and upgraded to carry additional weight. (Tribeca uses the double a-arm rear, and upgraded front design)
I know first hand that the SF suspension is pretty flimsy, and the weight of an SF plus spirited driving is more than enough to blow shocks, bend control arms, etc.
Again. Looking forward to watching this build take shape. Let me know if you have any Subaru questions. I've done a lot of work on these cars, and might be able to give advice. |
_________________ Current Build 1976 VW Bus Subaru with EZ36 https://www.thesamba.com/vw/forum/viewtopic.php?p=9443081#9443081
Second Current Build 1979 Porsche 911SC
https://www.thesamba.com/vw/forum/viewtopic.php?p=10117349#10117349
Previous Builds 78 Westy with matching trailer
http://www.thesamba.com/vw/forum/viewtopic.php?t=589790&highlight=westy
78 Bay with Acura 3.2 Type S engine
http://www.thesamba.com/vw/forum/viewtopic.php?t=516038&postdays=0&postorder=asc&start=0 |
Cap10323 Samba Member
Posted: Thu Nov 12, 2020 7:22 pm Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline |
Nice looking donor car. The interior on these is something else. _________________ -Ian
'77 Westfalia - 2.0 F.I |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Thu Nov 12, 2020 11:39 pm Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline |
Consider the floor/seat/wheel height ratios. Do the seat pedestals in the bus allow for comparable placements? Tiny misalignments can be adjusted for in the pivoting/sliding steering wheel, right?
I personally feel like losing the walkthrough to the dash cluster isn't worth it for a bus that will see any kind of use, like a camper. Even if it's not raining, I'll often use the slider or passenger door exit to avoid mud, puddles, other cars, etc… You could blend it to preserve the floor space, right?
www.airschooled.com |
deathman68 Samba Member
Joined: May 06, 2005 Posts: 339 Location: Atlanta, GA
Posted: Fri Nov 13, 2020 5:54 am Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline |
Congrats on the Tribeca. Assuming you’ll be building your own CANbus emulator or going with Subarugears?
The green bus you mention was my inspiration when I first started thinking of the Subaru swap. There’s “no” prob for fitment of the dash and you can easily modify it to maintain access to the area between the front seats. The only thing I didn’t care for about the swap was that it used TWO different chain driven drives/extenders to mate up with the original VW steering arm. Chain drives obviously are highly reliable but for me less is more especially when steering is involved. In your AWD setup will you also be adapting the r&p steering? If so, it might be a different ballgame.
For my swap I’m going to try to shoehorn the HVAC unit under the original dash and fab the connecting plastic ductwork since I’d rather cut/weld plastic vs metal. If you check out the build page pics on that green bud, its not clear if they included the HVAC unit in the end so it might be worth reaching out to them for details. You can, however, see that they completely removed the fresh air intake sheet metal to make everything fit.
Looking forward to seeing your build as it progresses. _________________ 1973 Riviera “Annie”
Build Thread: 1973 Riviera+Subaru 2.5+5 Speed
EJ25+5 Speed Conversion Part/Cost Tracker |
markd89 Samba Member
Joined: November 04, 2005 Posts: 657 Location: Los Angeles
Posted: Fri Nov 13, 2020 7:28 am Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline |
airschooled wrote: |
I personally feel like losing the walkthrough to the dash cluster isn't worth it for a bus that will see any kind of use, like a camper. Even if it's not raining, I'll often use the slider or passenger door exit to avoid mud, puddles, other cars, etc… |
I agree. _________________ 78 TDI Sunroof Bus
Los Angeles |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Fri Nov 13, 2020 11:34 am Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline |
While I would be impressed with the ingenuity to make that dash fit (especially if everything ends up working), there doesn't seem, to my eye, to be anything about the dash itself that makes it super special. Seems like a dash made with a lot of plastic from a slightly higher than economy vehicle.
I know this guy, and generally feel similarly about the Jetta dash in the Split. It is cool that he made it all fit and work and look like it was supposed to be there, but I just don't like the concept much myself. Greg's work on all his projects is 100% top notch with no expense spared and I'm always impressed with his ability to fabricate as well as envision what he wants to do.
My personal preference is when old-looking parts are made to work modern components. A very simple example is utilizing the heat lever on my Bus to control the flow of heated coolant to control the temperature. Or using an old-school BN4 switch to turn on my modern Espar heater from the front.
Even though I like being able to drive my TDI Bus faster and have a few somewhat more modern conveniences, I also really like that when you're sitting there in the driver's seat, it looks and feels like the old-school stuff.
But I fully acknowledge that this is just my own preference and you should do what you want!
_________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Fri Nov 13, 2020 2:36 pm Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline |
I don't disagree with you. I also have loved my other bus's with the levers and simple function of them. Not sure that much of the bus will be left by the time i am done. If it sucks then i will scrap it. I kept the dash and parts from the 27k mile bus. It is super super primo and would look great. I just love the challenge and the journey.
vwwestyman wrote: |
panel Samba Member
Joined: December 02, 2001 Posts: 1090 Location: Victoria B.C. Canada
notchboy Samba Member
Joined: April 27, 2002 Posts: 22448 Location: Escondido CA
Posted: Wed Dec 02, 2020 11:29 am Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline |
I wouldn't worry so much about opinions. The only approval you need is when its actually finished and out tearing shit up.
Nobody remembers what you did from here to there, just that there is this bad ass 4x4 with a funny dash in front of them.
Keep pushing through. Do your thing, and make us jealous about your AWD. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
JSMskater Samba Grease Gorilla
Joined: February 01, 2006 Posts: 5362 Location: Murrieta California
Posted: Wed Dec 02, 2020 5:10 pm Post subject: Re: AWD 1976 Westy with 3.6 Subaru Motor and Driveline |
pretty sweet! I'll be following this, lots of cool suspension ideas to be had here... _________________ 71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors |
