Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2211 Location: UK (South)
Posted: Wed Aug 26, 2020 11:22 am Post subject: Sealing exhaust connections - 1600 DP |
I rebuilt my 1600 DP engine. In the course of the rebuild, I replaced the heat exchangers with a better old pair and replaced the exhaust with a new Jopex unit that fitted around the filter pump that I also fitted.
I started having problems with exhaust leaks after about 70 miles. The leak appeared to be at the connection with the right hand heat exchanger. I could hear it (like a holed muffler) and see the soot staining on the heat exchanger.
I pulled the exhaust, replaced the wire mesh gaskets and refitted, but the leak was worse than before. The gaskets that were in place when I took the original exhaust offwere very hard wire gaskets. The ones in the aftermarket fitting kit were softer and seemed looser.
Pulling and refitting the exhaust is a pain, so to try to avoid doing it again, I've bought a NOS exhaust fitting kit.
Should I also use any exhaust sealant? I don't want to ruin the gaskets (the NOS kit wasn't cheap) but I want it to seal properly this time. _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Clara Samba Member
Posted: Wed Aug 26, 2020 5:46 pm Post subject: Re: Sealing exhaust connections - 1600 DP |
I've got in the habit of using a hi temp copper goo at the exhaust gaskets.
Theoretically it wasn't needed when new, but the old heater boxes are not 100 smooth, and the goo helps fill in the pits. Seems like every few years the beetle gets a stinky heater. Then I re-goo the exhaust donuts. Sometimes it needs new donuts, which means splitting the donut to install. Problem solved. I don't have to remove the exhaust.
b-man Samba Member
Posted: Wed Aug 26, 2020 5:57 pm Post subject: Re: Sealing exhaust connections - 1600 DP |
I’ve been using Walker Acoustiseal. On the slip connections on early heater boxes and the single exhaust damper as well as all the donut connections. It comes apart easily if you heat it with a torch when you need to disassemble your exhaust.
_________________ 1956 Dove Blue Panel
1966 Velvet Green Single Cab
1957 L41 Black Oval Window Beetle |
busdaddy Samba Member
Posted: Wed Aug 26, 2020 6:06 pm Post subject: Re: Sealing exhaust connections - 1600 DP |
Clara wrote: |
X2 for the high temp copper RTV, lasts quite a while and much easier to get off later compared to most of the dedicated "exhaust compounds", stays flexible too. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
74 Thing Samba Member
Posted: Wed Aug 26, 2020 9:52 pm Post subject: Re: Sealing exhaust connections - 1600 DP |
I have used that stuff. It becomes like a plaster type substance. You should be able to pick up at your local parts store. |
Posted: Thu Aug 27, 2020 12:52 am Post subject: Re: Sealing exhaust connections - 1600 DP |
Thanks all. Seems that the concensus is that goop is good.
Thanks for the product recommendations too. _________________ Andy
Joined: August 31, 2013 Posts: 12861 Location: North Carolina
Posted: Thu Aug 27, 2020 1:11 am Post subject: Re: Sealing exhaust connections - 1600 DP |
I just weld 1.5” flanges to the muffler & heat exchangers to lose that crappy clamp connection. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
RWK Samba Member
Posted: Thu Aug 27, 2020 4:20 am Post subject: Re: Sealing exhaust connections - 1600 DP |
X2, that's what I do to all mine. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
Stocknazi Samba Member
Posted: Fri Aug 28, 2020 12:19 pm Post subject: Re: Sealing exhaust connections - 1600 DP |
If the doughnut does not fit tightly on the heater box tube they will leak.
I've cut off and replaced a few heater box tube ends. Mount the heater box and muffler so you can use them to help mock up the replacement end; tack the new tube in a few places, then remove it and weld it up properly on the bench.
I found that dual port intake manifold tube to be the perfect outer diameter, but it's too thin. I used another section of old TV antenna mounting pole to increase the overall thickness. Worked perfectly. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
