bigEZbob Samba Member
Joined: March 30, 2016 Posts: 34 Location: Ontario Canada
Posted: Tue Sep 01, 2020 10:24 am Post subject: Crank Case Hose N90072501 |
I have to order this hose.
The kicker is the shipping is $45.00 and the part is $35.00 (U.S. which is about 3 million Canadian eh)
I've been told I can use a replacement providing it is oil resistant hose.
Does anyone here know the interior diameter of this hose.
No worries if not-I'll take it off tonight when I return from work and measure it myself.
Thanks in advance.
bob |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Tue Sep 01, 2020 10:26 am Post subject: Re: Crank Case Hose N90072501 |
If it is the hose between the oil tower and the intake boot. 3/4" or 19mm is a snug fit. _________________ ☮️ |
Posted: Tue Sep 01, 2020 10:43 am Post subject: Re: Crank Case Hose N90072501 |
Thank you Mark! |
Posted: Tue Sep 01, 2020 11:27 am Post subject: Re: Crank Case Hose N90072501 |
30r7 fuel/PCV hose should work. Silicone heater hose would work as well. |
Dogsled Samba Member
Joined: November 07, 2010 Posts: 62 Location: Denver, CO
Posted: Wed Sep 22, 2021 8:11 am Post subject: Re: Crank Case Hose N90072501 |
MarkWard wrote: |
If it is the hose between the oil tower and the intake boot. 3/4" or 19mm is a snug fit. |
Indeed I found 3/4" fuel line just not quite fit over the plastic/electric breather part - larger diameter than the other fittings. 3/4" fits everywhere else but tight. _________________ Don't make a fuss, just get on the bus... |
Posted: Wed Sep 22, 2021 10:09 am Post subject: Re: Crank Case Hose N90072501 |
Laundry soap, WD40, or some other lubricant should help get it on.
You can buy 7/8" hose for a dishwasher IIRC, but it may not last super long, though likely longer than the crappy original factory hose did.
4Gears4Tires Samba Member
Posted: Wed Sep 22, 2021 12:28 pm Post subject: Re: Crank Case Hose N90072501 |
Sometimes a little heat can help fit stubborn hoses. _________________ '87 Syncro
AtlasShrugged Samba Member
Joined: October 30, 2008 Posts: 1605 Location: Decatur, Ga. USA
Posted: Wed Sep 22, 2021 4:19 pm Post subject: Re: Crank Case Hose N90072501 |
Try some 7/8 or 3/4 inch silicone heater hose. Get the cheap stuff without a lot of reinforcement. Single ply will do.
The silicone hose is very pliable when fitted over tight fittings. A little Vaseline helps too.
https://www.amazon.com/Flexfab-Silicone-Heater-Rad...amp;sr=8-3 _________________ 'Let's Go Brandon' |
