Rorke Samba Member
Joined: August 04, 2016 Posts: 255 Location: Traverse City, MI
Posted: Fri Sep 04, 2020 7:31 pm Post subject: Lithium Start Battery? |
My Optima battery barely holds a charge. It looks like it is time for a new battery.
I would prefer to go as small as possible because the existing battery is in a crowded box under the bus.
What does the group think about this as a replacement?
Thanks
Size: 6.89" x 3.4" x 5.12" (LxWxH)
900 Cranking Amps
30 Amp Hours (PbEq), 15Ah (Actual)
5.18 lbs
https://antigravitybatteries.com/products/starter-batteries/restart-oem/atx20-hd/ |
kguarnotta Samba Member
Joined: April 01, 2004 Posts: 1160 Location: Woodstock, NH
Posted: Sun Sep 06, 2020 7:28 am Post subject: Re: Lithium Start Battery? |
I can't speak to the specs except that I've heard using this type of battery is not good in cold weather. I don't understand it exactly - but I think the re-charging of the battery in certain temps can damage the battery. I'm not sure where you live, or will be driving.... _________________ -Kevin
Lincoln, MA
'86 Triple Knob Syncro w/EJ22
'78 Westy
'69 Single Cab
'65 Kombi - EZ-Camper |
izzydog Samba Member
Posted: Sun Sep 06, 2020 3:58 pm Post subject: Re: Lithium Start Battery? |
Lithium batteries with a BMS (battery management system) will not allow the battery to be charged below 32F. You can discharge the battery (use it) at any temperature, just not charge it. The BMS will not allow a charge into the battery if you decide to drive at temps less than 32F. That said, if your start battery is under the drivers seat and your heater is working, the temp inside the van won't be 32F for long but that still means that a lithium battery will be discharging without recharging until you reach 32F. |
Danwvw Samba Member
jimf909 Samba Member
Posted: Sun Sep 06, 2020 9:18 pm Post subject: Re: Lithium Start Battery? |
Lithium starter batteries don't come up often here. I'm guessing that's because the Vanagon has good locations for Group 41 or T-5 size batteries. Lithium batteries come up often in motorcycle forums due to their small size. Would a picture of your "box under the bus" be interesting and show folks the space you're working with? I'm assuming it's not the box under the passenger seat because a T-5 lead-acid battery fits there and frees up considerable space.
_________________ - Jim
Abscate wrote: |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 11998 Location: Santa Cruz, CA
Posted: Sun Sep 06, 2020 10:33 pm Post subject: Re: Lithium Start Battery? |
I looked at a T5 battery at walmart the other day, it said 575 CCA on it |
Rorke Samba Member
Posted: Mon Sep 07, 2020 5:29 am Post subject: Re: Lithium Start Battery? |
This is the space. If I could swap to Lithium for both the start and house, I could shed 100 lbs, improve battery performance, and achieve more "hidden" storage.
[/img] |
Posted: Mon Sep 07, 2020 5:35 am Post subject: Re: Lithium Start Battery? |
Nice box you put in there...is there a thread on it's installation? _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
Rorke Samba Member
Posted: Mon Sep 07, 2020 5:50 am Post subject: Re: Lithium Start Battery? |
kguarnotta wrote: |
Nice box you put in there...is there a thread on it's installation? |
Kevin,
After a quick search through my profile, I couldn't find a new topic of this install.
I must have posted within another topic (or two).
This wasn't original. Though I did make some tweaks to what others did.
My version drops through the top. So upon any impact, it should come up through the floor instead of getting crushed. Who knows though.
Another difference is that this box extends under the backseat. So it is continuous storage for bigger stuff and simplifies wire runs.
It is pretty cool. |
Posted: Mon Sep 07, 2020 6:31 am Post subject: Re: Lithium Start Battery? |
syncrodoka wrote: |
They offer Everstart Value, Plus and Maxx battery lines. The Everstart Maxx still shows 650 CCA on their website but who knows what's what.
Pretty cool.
Your post is in this thread...
https://www.thesamba.com/vw/forum/viewtopic.php?p=8467782#8467782
Good luck with the battery. _________________ - Jim
Abscate wrote: |
