Cptn. Calzone Samba Member
Joined: June 27, 2007 Posts: 1855 Location: S>E>Alabama
Posted: Sun Sep 06, 2020 11:42 am Post subject: Wiring harness in engine bay |
Hope everyone is enjoying the weekend and the holiday; I am about to send my Noitch off to paint..and when installing the main wiring harness I noticed two
grommets replaced all) on the drivers side lower fender well cavity.Seems to make sense that the larger portion of the harness fits the larger opening and the smaller so forth... I cannot see how the long whip that bis he passenger side tailight gets over there? I cannot find an opening from the cavity between the motor bay and the inner fender.. _________________ 71 westfalia
67 912 Porsche Quintilla
67 Single Cab aka my work horse |
Posted: Mon Sep 07, 2020 6:08 am Post subject: Re: Wiring harness in engine bay |
Anyone care to share a pic to help out? _________________ 71 westfalia
FastyOrange Samba Member
Joined: November 15, 2012 Posts: 111 Location: Greenville, SC
Posted: Mon Sep 07, 2020 7:00 am Post subject: Re: Wiring harness in engine bay |
What year is your notch? I'm not sure if there are differences between different years on that detail...I wouldn't be surprised if there are. I have a 70 & 72 Fastback and would be happy to share a photo of the wiring routing from those cars when I head over to my shop in a bit.
Jon _________________ 72 FI Fastback
70 FI Fastback (Parts Car) |
Posted: Mon Sep 07, 2020 7:04 am Post subject: Re: Wiring harness in engine bay |
It's a 67 and thank you I'm beginning to think perhaps both wires should go through the big grommet but then what is the other grommet above it therefore I'll try and send some pics _________________ 71 westfalia
Posted: Mon Sep 07, 2020 7:46 am Post subject: Re: Wiring harness in engine bay |
Got it. I will see how my two cars compare. They may have the same routing.
Posted: Mon Sep 07, 2020 8:26 am Post subject: Re: Wiring harness in engine bay |
Ok, my gut says that you need some photos from someone with a notch of the same or similar year. Below are two photos showing the passenger side tail light harness exiting through the engine bay side wall just in front of the engine hanger bracket on my 1972 Fastback that I have with me. I will check my 1970 when I go to my shop but I have a feeling it will be the same and probably not match the setup on your car.
1st shot - wiring harness is visible under the hoses going into the side of the air cleaner.
2nd shot - wiring harness exiting the engine bay through a rubber grommet (engine hanger mount visible on right side of image).
Jason37 Samba Member
Posted: Mon Sep 07, 2020 8:31 am Post subject: Re: Wiring harness in engine bay |
On my 63, the only wires that enter the engine bay are the ones for the engine. |
Posted: Mon Sep 07, 2020 8:41 am Post subject: Re: Wiring harness in engine bay |
Thanks everybody I'm going post a pic of the 2 grommets on the inner Fender and I guess I need to just really keep looking for where that long whip would go to I know it clips all up-and-over the front of the motor area on the fire wall and then heads out to the passenger side and drops off another wire here there I think one of them is the signal wire to the starter let me post some pics I'm going up to the shop now thank you for your help _________________ 71 westfalia
DQDan Samba Member
Joined: October 24, 2016 Posts: 351 Location: Cleveland OH
Posted: Mon Sep 07, 2020 8:54 am Post subject: Re: Wiring harness in engine bay |
Here's how the passenger tail lights get their feed on my 66 SB, I took the engine out so you could see it better.
Posted: Mon Sep 07, 2020 10:15 am Post subject: Re: Wiring harness in engine bay |
I just checked my 70 Fastback...it is the same as the pictures of the 72 above. Hopefully someone with a notch can chime in in case it is different.
