66uno Samba Member
Joined: December 05, 2006 Posts: 603 Location: maryland
Posted: Wed Sep 09, 2020 10:58 am Post subject: Scary lowered bus |
So, my mechanic and I just got done lowering my bus 2 1/2 inches. We did it right. It’s an IRS conversion using a super beetle trans and adjustable spring plates and up front it has dropped spindles and disc brakes.
My first ride in it was exhilarating and simultaneously, terrifying. It wandered over the road way and at times it was difficult to control. I only took it a short distance, got it in third gear and turned around.
Tomorrow, I am getting an alignment. Hoping that helps. But, I must say, I was so frightened by the ride I thought I would have to sell it. Only after cooling off and thinking about it some more did I calm down. A lot of people are driving these and many swear by them.
Am I right? Can I get some feedback, please?
johny__utah Samba Member
Joined: September 02, 2008 Posts: 426 Location: Arizona/California
Posted: Wed Sep 09, 2020 11:10 am Post subject: Re: Scary lowered bus |
try and post suspension pics. Was the center pin replaced? Any play in your steering box? _________________ 1956 L31
1961 L346 L347
1963 L380 L289 |
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1357 Location: Richmond, VA
Posted: Wed Sep 09, 2020 11:16 am Post subject: Re: Scary lowered bus |
Post some pics of the suspension, if there's something glaringly wrong someone will be able to point it out. If it hasn't had at least an eyeball alignment it's probably gonna drive like crap after changing so many variables though, I'd get a proper alignment before throwing it on Craigslist. _________________ 1973 Superbeetle: 1st car, owned since age 12. Update thread --> https://www.thesamba.com/vw/forum/viewtopic.php?p=9919140#9919140
1966 Beetle: My new project. (SOLD) Build thread--> https://www.thesamba.com/vw/forum/viewtopic.php?t=678040 |
66uno Samba Member
Posted: Wed Sep 09, 2020 12:22 pm Post subject: Re: Scary lowered bus |
yes, there is play in the steering box. I think that is part of it.
Tomorrow, it is getting a proper alignment by a real technician.
Pictures to come.
but is anyone rolling a similarly modified bus and how do you like the performance? |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3850 Location: San Jose, CA
Posted: Wed Sep 09, 2020 12:51 pm Post subject: Re: Scary lowered bus |
Did it handle wildly and frighteningly before you lowered it?
Since you did both ends, and your rear toe could be wonky now, your problems are all most likely associated with not having any sort of alignment after taking everything apart.
Unless you had wandering and darting problems before taking things apart, then just lowering 2.5 inches wouldn't cause such drastic changes. A little bit of drift from a loose box shouldn't scare the pants off of you. |
peecee69 Samba Member
Joined: January 27, 2005 Posts: 1572 Location: Annapolis, MD/Bloomfield Hills, MI
VWAdam Samba Member
Joined: February 14, 2002 Posts: 3331 Location: Birmingham, Alabama
Posted: Wed Sep 09, 2020 4:23 pm Post subject: Re: Scary lowered bus |
Who built the beam? The spindles?
My Bus drives great. A Bus lowered properly will have a more stiff and jarring ride than stock but won't be any more difficult to drive. _________________ All he needed was a wheel in his hand and four on the road.
'59 Euro Beetle ragtop
'63 Standard Microbus
Come to my show! www.volksjam.com
Looking for badge/sticker/frame from Western Motors in Great Falls, Montana |
turkis-deluxe Samba Security
Posted: Wed Sep 09, 2020 4:39 pm Post subject: Re: Scary lowered bus |
Did you lower that Westy that you posted a picture of? Looks like a super nice stock SO42. |
66uno Samba Member
Posted: Thu Sep 10, 2020 2:49 am Post subject: Re: Scary lowered bus |
Yes, I lowered that beautiful Westy. I saw the tests made by the California Highway patrol in 1966 and they scared me quite a bit, the tendency for rollover at even low speeds. When I grenaded my stock transmission, I put a small nut transmission in And found I had a top speed of about 60 and it whined like hell. That’s when I decided to do the IRS conversion and get the center of gravity a bit lower. Overall, I love it. I love that I don’t have to climb in, I can just easily enter. And, I am pretty sure that it will now be able to go into my garage with the roof rack on.
I appreciate all the help. I think you have answered my questions.
Today it gets an alignment. That will either cure it or I will be getting my steering box rebuilt. The competent shop I am having do the job, I am sure can steer me in the right direction concerning the steerin g box (pun intended). |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Thu Sep 10, 2020 3:04 am Post subject: Re: Scary lowered bus |
Hopefully it can be corrected with an alignment. However, there’s a strong possibility that the shop screwed up the geometry when installing the IRS conversion.
Like stated above, if the vehicle handled well beforehand with the current steering box, replacing it isn’t going to remedy an issue that presents itself after everything that was recently done. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
VWAdam Samba Member
Posted: Thu Sep 10, 2020 4:55 am Post subject: Re: Scary lowered bus |
66uno wrote: |
Did you use an IRS kit from someone?
I put a Wolfgang IRS kit in my Bus a couple of years ago. I did it myself without any fancy tools and then had a friend align it at his shop and it and it drives awesome. _________________ All he needed was a wheel in his hand and four on the road.
DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6250 Location: SBS headquarters: Missery
Posted: Thu Sep 10, 2020 5:47 am Post subject: Re: Scary lowered bus |
First, that is hardly low. LoL Do you have another picture of it lowered? LoL I kid, I kid. LMBO
There are so many things that could be wrong, you should post pictures like everyone is saying to help. I can honestly say, any worn or loose parts will make it scary to drive low or stock. I know I had a worn box with a worn rod end and that SOB was all over the road. _________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Thu Sep 10, 2020 8:53 am Post subject: Re: Scary lowered bus |
Busstom wrote: |
This^^.
Aligning might help.
Did you balance the (new?) tires? _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
Malokin Martin Samba Member
Posted: Thu Sep 10, 2020 10:16 am Post subject: Re: Scary lowered bus |
Classic samba thread:
“OMG help me something is seriously wrong!“
“There’s a bunch of knowledgeable people here who can help. Please post pictures and information about the parts you used. You should also try this... this... and this first....”
(Ignores posts) “I’m just going to try it this way” |
Posted: Thu Sep 10, 2020 10:44 am Post subject: Re: Scary lowered bus |
VWAdam wrote: |
I put a Wolfgang IRS kit in my Bus a couple of years ago. I did it myself without any fancy tools and then had a friend align it at his shop and it and it drives awesome. |
I didn't know you had an IRS kit in your bus. I installed one in my 64 while overseas from Bus Boys. It was super easy and rode nice! I didn't have enough engine to push the gearing. _________________ Anthony
SBS #1
SBS #1 on FB
66uno Samba Member
Posted: Thu Sep 10, 2020 12:21 pm Post subject: Re: Scary lowered bus |
I used the bolt in pivot points and adjustable spring plates from Dubfab. I have had a very good experience with Mike Anderson. Initially, he was hard to get ahold of. But once I did, he was very helpful. And his parts are of the highest quality.
The shop I am using is Annaptown Imports in Maryland. The owner is Fred the Motorhead. He is very knowledgable, especially for engines. Being on the East Coast, we don’t have the depth of knowledge concerning lowering that the west coast guys have. Air cooled vw’s are pretty scarce here.
I wasn’t ignoring the request for photos. I am just having a very hard time uploading them, compounded by my poor eyesight.
Nuts, I uploaded four separate images and discovered it was really just one image, saved four times! Anywyas, here it is. I will try again.
tisius Samba Member
Posted: Thu Sep 10, 2020 12:45 pm Post subject: Re: Scary lowered bus |
I take it the rear shocks were put on after you had taken this picture. _________________ drive it like you just robbed the bank
aa390392 Samba Member
Posted: Thu Sep 10, 2020 1:41 pm Post subject: Re: Scary lowered bus |
Malokin Martin wrote: |
So many times Ive wanted to say the exact same thing. _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
VWAdam Samba Member
Posted: Thu Sep 10, 2020 3:57 pm Post subject: Re: Scary lowered bus |
DubStyle wrote: |
VWAdam wrote: |
I didn't know you had an IRS kit in your bus. I installed one in my 64 while overseas from Bus Boys. It was super easy and rode nice! I didn't have enough engine to push the gearing. |
It was straight axle when you rode in it.
I'd always toyed with the idea of IRS and after I lost 4th gear, I just decided to go for it. I love it. _________________ All he needed was a wheel in his hand and four on the road.
