camino70 Samba Member
Joined: September 13, 2020 Posts: 156 Location: Canton, Georgia
Posted: Sat Mar 06, 2021 5:34 pm Post subject: Re: Intro - 1974 Westfalia |
Fuel gauge works, I need to check on G. _________________ Ron
1974 Westfalia
Goal: get the 914 1.7 running |
Posted: Mon Mar 08, 2021 9:55 am Post subject: Re: Intro - 1974 Westfalia |
I pulled the filler, not sure why I let it intimidate me, not bad.
Crusty plate for the cap, I’m cleaning up now, rubber grommet is toast:
Garbage in metal section of filler:
Garbage in rubber section of filler:
Cracks in rubber:
Is my only option some exhaust tubing to replace the rubber bend? _________________ Ron
1974 Westfalia
Posted: Mon Mar 08, 2021 12:34 pm Post subject: Re: Intro - 1974 Westfalia |
Gas tank is back out, with engine in.
Apparently I did a substandard job cleaning the tank. The top was not cleaned well and still shows gunk.
Going to see what I can do and not soak myself. _________________ Ron
1974 Westfalia
busdaddy Samba Member
Posted: Mon Mar 08, 2021 12:57 pm Post subject: Re: Intro - 1974 Westfalia |
The exhaust pipe mod is the best option, that way you can use known quality straight hose, either the Sprinter parts, or a length from NAPA.
Sorry to hear about the tank, but better to find it now. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Mar 08, 2021 2:59 pm Post subject: Re: Intro - 1974 Westfalia |
I can't believe I am trying to clean this again and not ordering a new one...
What can I use to plug the holes for a good soak, possibly with hot water and TSP, or maybe diesel fuel or e85? _________________ Ron
1974 Westfalia
Posted: Mon Mar 08, 2021 3:14 pm Post subject: Re: Intro - 1974 Westfalia |
You'll likely need something a bit more potent to get it really clean: https://www.thesamba.com/vw/forum/viewtopic.php?t=378770
As or plugs Home depot has plumbing test caps that fit the filler neck, sender holes can be plugged with a small yogurt cup or similar tapered plastic thing, kiddie sippy cup?, sex toy?, use your imagination with what's on hand. A glove stuffed full of paper even works in a pinch. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Mar 08, 2021 4:08 pm Post subject: Re: Intro - 1974 Westfalia |
This is what I have:
1974 Westfalia
Posted: Sat Mar 27, 2021 1:38 pm Post subject: Re: Intro - 1974 Westfalia |
I’ve got the tank clean and installed. New pipes and hoses.
Now I need to learn more about the charging system. I thought the positive off of the alternator was going to the starter, but it didn’t actually get that far and was taped up.
Now I have it going to the positive on battery and not getting a charge. _________________ Ron
1974 Westfalia
Posted: Sun Mar 28, 2021 4:57 pm Post subject: Re: Intro - 1974 Westfalia |
When I took it out the other day, I thought it ran till the battery gave up.
Turns out my problem is bigger, I think I locked it up. _________________ Ron
1974 Westfalia
Posted: Sun Mar 28, 2021 5:16 pm Post subject: Re: Intro - 1974 Westfalia |
Well that sounds dismal, have you tried turning the engine with the alternator nut?, or by pushing the bus in 4th gear? Don't try using the bolts in the fan hub, overtorque or snap one of them and you'll have even more problems. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Mar 28, 2021 5:31 pm Post subject: Re: Intro - 1974 Westfalia |
Unfortunately yes. It used to spin easily from the alternator 22mm, now it won’t.
On the ground and in gear, I can’t push it.
Now I think the starter is in fact extending, but unable to move the flywheel.
I was expecting shrapnel in the oil and strainer, but to my tired and upset eyes the oil looked ok.
Unless there are other suggestions, I’m going to start pulling it back out tomorrow. _________________ Ron
1974 Westfalia
Posted: Sun Mar 28, 2021 5:56 pm Post subject: Re: Intro - 1974 Westfalia |
Maybe try a fresh battery first, if the starter is stuck mid start it could drag it down somewhat and make it hard to turn. But usually a push in 4th disengages it, hmmm....
Were the oil and charge lights working before the drive? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Mar 29, 2021 7:03 am Post subject: Re: Intro - 1974 Westfalia |
I pulled the batter and starter and had them tested at FLAPS, hoping they were my issue. They both tested as good. _________________ Ron
1974 Westfalia
Posted: Mon Mar 29, 2021 9:32 am Post subject: Re: Intro - 1974 Westfalia |
How’s this look?
1974 Westfalia
Posted: Mon Mar 29, 2021 4:42 pm Post subject: Re: Intro - 1974 Westfalia |
Looks like a strainer from here, any sparkles in the oil? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Apr 01, 2021 11:42 am Post subject: Re: Intro - 1974 Westfalia |
I repurposed a furniture Dolly with just an extra piece of plywood, its a hair too low, but I can still force the floor Jack under it.
It took me about two hours to get it up in the air, unhooked and dropped.
1974 Westfalia
Posted: Thu Apr 01, 2021 2:29 pm Post subject: Re: Intro - 1974 Westfalia |
Exhaust removed, four nuts up top, four nuts under cover.
I can get the heads and cylinders to move but not come off, what am I missing?
1974 Westfalia
crownline Samba Member
Joined: September 10, 2010 Posts: 593 Location: Northwoods of WI
Posted: Thu Apr 01, 2021 2:43 pm Post subject: Re: Intro - 1974 Westfalia |
Stuck with carbon and crud. Get a rubber hammer and slowly tap side to side and top to bottom. But not on the fins. _________________ 1972 Bus 1700 cc Single Carb. But not a progressive.
Barelymuvin
Wish I still had the ones I got rid of.
"It"s got some dings and dents and neither of us is going to SEMA."(Update, I went to SEMA in 2019 but the Bus stayed home)
[url=http://www.vw-mplate.com/mplate-8446.png]Click to view image[/URL] |
Posted: Thu Apr 01, 2021 3:09 pm Post subject: Re: Intro - 1974 Westfalia |
I misunderstood and didn’t remove this tray that screws to the block, the cylinders and has a curved section that holds the heads back.
I can’t get the screws to break loose yet.
1974 Westfalia
Posted: Thu Apr 01, 2021 5:07 pm Post subject: Re: Intro - 1974 Westfalia |
Three bolts to remove the fan, four bolts to remove the fan shroud, made it easier for me to get to all the tins for removal.
I only got the one side done, the other side tin is still soaking in penetrating oil.
These two pistons move in the cylinder.
1974 Westfalia
