Intro - 1974 Westfalia
Page: Previous  1, 2, 3 ... 9, 10, 11, 12, 13  Next
camino70
camino70 is offline
PostPosted: Fri Apr 02, 2021 12:11 pm    Post subject: Re: Intro - 1974 Westfalia Reply with quote
I was able to remove the last tin and pulled the other head. All cylinders are now removed. All four pistons move freely, crank is not moving.
I guess my only option is to split the case?
Ron
1974 Westfalia
Goal: get the 914 1.7 running
busdaddy
busdaddy is offline
PostPosted: Fri Apr 02, 2021 12:51 pm    Post subject: Re: Intro - 1974 Westfalia Reply with quote
Sure sounds that way, from the looks of the rest of things it's likely time anyways.
Слава Україні!
camino70
camino70 is offline
PostPosted: Fri Apr 02, 2021 5:15 pm    Post subject: Re: Intro - 1974 Westfalia Reply with quote
I think I have everything unbolted, any secrets to get the case apart?
Ron
1974 Westfalia
busdaddy
busdaddy is offline
PostPosted: Fri Apr 02, 2021 7:04 pm    Post subject: Re: Intro - 1974 Westfalia Reply with quote
There's 26 or 27 bolts/nuts/fasteners holding it together, how many can you count on yours? You may want to get that flywheel off first as well, it's alot easier when the crank is secured and there's a nut hiding behind it that has to come off too.
Слава Україні!
Abscate
Abscate is offline
PostPosted: Sat Apr 03, 2021 3:57 am    Post subject: Re: Intro - 1974 Westfalia Reply with quote
Get the Wilson book and read through before proceeding. It’s a shame to Ruin good stuff nowadays.
.ssS!
camino70
camino70 is offline
PostPosted: Sat Apr 03, 2021 3:16 pm    Post subject: Re: Intro - 1974 Westfalia Reply with quote
Flywheel off, another 13mm under there
I haven’t had success getting the oil pump cover off.
Ron
1974 Westfalia
busdaddy
busdaddy is offline
PostPosted: Sat Apr 03, 2021 3:25 pm    Post subject: Re: Intro - 1974 Westfalia Reply with quote
It's not a cover on a type 4, it's the whole pump. With all the case fasteners off and a split starting it should pull out, careful prying on the ears, they break off quite easily. Even pressure on both sides so it comes straight out and doesn't get sideways and jam, worst case scenario double nut the studs and remove them (just 2 on same side is OK), then split the case and catch the pump as it falls out.
Слава Україні!
camino70
camino70 is offline
PostPosted: Thu Apr 08, 2021 6:25 pm    Post subject: Re: Intro - 1974 Westfalia Reply with quote
I got a few minutes this evening, some slow prying and I was able to pull the oil pump.
I think I have all the bolts off, including this one
I’ll try pulling it apart again tomorrow.
I am still entertaining purchasing a beat 74 914, am I just postponing the inevitable rebuild?
Ron
1974 Westfalia
camino70
camino70 is offline
PostPosted: Fri Apr 09, 2021 11:18 am    Post subject: Re: Intro - 1974 Westfalia Reply with quote
Working slowly
Ron
1974 Westfalia
camino70
camino70 is offline
PostPosted: Fri Apr 09, 2021 1:20 pm    Post subject: Re: Intro - 1974 Westfalia Reply with quote
I’m having a hard time reaching the pins on the two on the bottom of their stroke. How else can I get to them with the crank not spinning?
Ron
1974 Westfalia
busdaddy
busdaddy is offline
PostPosted: Fri Apr 09, 2021 1:50 pm    Post subject: Re: Intro - 1974 Westfalia Reply with quote
So one (or more) of those rods is stuck to the crank and won't turn? I'm guessing that's why the pistons are still on 1 & 3? Looks like they were far enough out to remove the pins to me.
A 12 point socket on a 3/8" breaker bar should get the nuts broken loose, maybe a short extension as well to get out from between the counterweights. It may be a game of turning the nut 1:12 a turn and taking the socket off the bar and rotating it 1/4 turn, then another 1:12 turn and so on, sometimes it's the only answer in tight spaces.
There's another thread here from last week doing a very similar job, he ended up boring a hole in the piston to get in there with a long extension. It's a shame to destroy possibly reuseable German parts, but sometimes it's the only option.
Слава Україні!
camino70
camino70 is offline
PostPosted: Fri Apr 09, 2021 2:13 pm    Post subject: Re: Intro - 1974 Westfalia Reply with quote
1&3 are accessible, though I’ve not been successful removing the clip yet.
2&4 are not accessible, they’re far enough in the block/cylinder that they look removed in the picture.
2&4 rods/caps look dry compared to 1&3.
I’m good at destroying things, I’m not ready to do it purposefully yet.
Ron
1974 Westfalia
orwell84
orwell84 is offline
PostPosted: Fri Apr 09, 2021 3:17 pm    Post subject: Re: Intro - 1974 Westfalia Reply with quote
Stop before you beat up good parts and go out and buy these:
https://channellock.com/product/927/
They are good and sturdy and made in the USA.
Cheapo pliers make getting the piston pin retainers off agony. They are definitely worth the money.
camino70
camino70 is offline
PostPosted: Fri Apr 09, 2021 4:08 pm    Post subject: Re: Intro - 1974 Westfalia Reply with quote
I have these. Not sure if it’s my limited angle without crank movement impeding me (more than normal).
Ron
1974 Westfalia
orwell84
orwell84 is offline
PostPosted: Fri Apr 09, 2021 6:51 pm    Post subject: Re: Intro - 1974 Westfalia Reply with quote
Gotcha. You said pistons were moving freely, but I reread your post and saw:
Crank was NOT.
Could you hook the the end of the retaining ring with a dental pick thingy and just pull them out ugly? That’s what I ended up doing...when I still had crappy snap ring pliers. If you pull on it so the snap ring kind of bends in n itself you shouldn’t damage the piston.
Somebody else just did this...split case with crank not turning...on a T4.
camino70
camino70 is offline
PostPosted: Fri Apr 09, 2021 7:53 pm    Post subject: Re: Intro - 1974 Westfalia Reply with quote
Crank was NOT.
I’ll keep trying with the channel locks, I seem to make more progress when I step away and return a day or two later.
I half don’t want to find the other thread to see what I may be in store for.
Ron
1974 Westfalia
orwell84
orwell84 is offline
PostPosted: Sat Apr 10, 2021 7:49 am    Post subject: Re: Intro - 1974 Westfalia Reply with quote
I think he drilled holes in the pistons to get to the rod nuts, but his pistons were toast. The rod was stuck on melted bearing material.
I have never actually dealt with this problem but I agree with you about walking away for awhile. I find that if I keep at it after I am past my frustration point I resort to desperate brute force and ignorance, forget things and bad things happen. If I walk away for awhile, it all looks different when I come back to it and a solution comes to me.
I get especially jittery when putting together a case on a rebuild. You kind of have to see the whole thing through. There is always a point where things go south; a part gets misplaced, a case half hangs up and you get stuck while the case sealant catches flies. I try to get everything ready before hand and just take my time.
You’ll get it. Hang in there.
camino70
camino70 is offline
PostPosted: Sat Apr 10, 2021 11:16 am    Post subject: Re: Intro - 1974 Westfalia Reply with quote
2&4 rods are remarkably drier than 1&3.
I could get to the rod nuts on the top side, I sprayed them liberally with penetrating oil yesterday. I got them off today.
Flipped it over, removed the oil tray:
It looks like I may be able to get to the rod nuts from the bottom side. I sprayed them with penetrating oil today and going to let it set overnight.
Ron
1974 Westfalia
busdaddy
busdaddy is offline
PostPosted: Sat Apr 10, 2021 12:19 pm    Post subject: Re: Intro - 1974 Westfalia Reply with quote
Wooooo..., it's one of them fancy Porch motors, "I hear they bolt right in!" Razz
Odd that it has a windage tray and dished pistons, a bit of everything going on there.
Good job on the nuts, keep at it. That cam doesn't look half bad, I hope you kept track of which holes the lifters came out of.
Слава Україні!
cmonSTART
cmonSTART is offline
PostPosted: Sat Apr 10, 2021 12:24 pm    Post subject: Re: Intro - 1974 Westfalia Reply with quote
That sure is really weird - wonder why it has the windage tray.
Interesting.
'78 Bus 2.0FI
de K1IGS
Page 10 of 13
