Remove Steering Wheel Horn cover and pad, Sunbug
sun-bug74
sun-bug74 is offline
PostPosted: Wed Sep 23, 2020 2:54 pm    Post subject: Remove Steering Wheel Horn cover and pad, Sunbug Reply with quote
Is there an old post or does someone know how to get the top off of the steering wheel in a 74 sunbug SB? It is a special wheel that year.
Thanks.
BZ
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Sep 23, 2020 2:59 pm    Post subject: Re: Remove Steering Wheel Horn cover and pad, Sunbug Reply with quote
Isn't the same as the steering wheel as other Beetles of the same year?
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
sun-bug74
PostPosted: Wed Sep 23, 2020 3:30 pm    Post subject: Re: Remove Steering Wheel Horn cover and pad, Sunbug Reply with quote
My understanding is that it is a special wheel for the sunbug. It has the castle on it in the center and is padded.
BZ
Tim Donahoe
Tim Donahoe is offline
PostPosted: Wed Sep 23, 2020 3:35 pm    Post subject: Re: Remove Steering Wheel Horn cover and pad, Sunbug Reply with quote
Assuming you mean the horn button, you simply dig your fingers (don’t use a tool) between the horn button and the front body of the housing. Dig in and pull one corner until it comes up, then do the same for the other three corners.
However, with the 1974, you have only done half the job. Once the four corners are up, you must turn the horn button about 90 degrees counterclockwise. This will allow you to pull the horn button off completely. Remember to unhook the horn wire before pulling off completely.
I always put a little dielectric grease on the edges of the four round tabs that hold the button on. This makes it easier to remove it—without breaking one of the tab edges.
Tim
Let's do the Time Warp again!
Richard O'Brien
sun-bug74
PostPosted: Wed Sep 23, 2020 4:22 pm    Post subject: Re: Remove Steering Wheel Horn cover and pad, Sunbug Reply with quote
Thanks. Do I go under the silver trim or between the silver trim and the upper black part? I assume you are familiar with the sunbug wheel? I can send a pic if needed.
BZ
sun-bug74
PostPosted: Thu Sep 24, 2020 5:30 am    Post subject: Re: Remove Steering Wheel Horn cover and pad, Sunbug Reply with quote
I got it off. This post was how:
https://www.thesamba.com/vw/forum/viewtopic.php?p=6876116#:~:text=It's%20easy.,the%20seat%2C%20of%20course).
BZ
