mr white Samba Member
Joined: October 02, 2005 Posts: 1193 Location: beautiful Oregon & Mohave County, AZ
Posted: Mon Sep 14, 2020 6:00 pm Post subject: Bus trans ID numbers |
I am going through a pile of bus transmissions this week. All are big nut transmissions. Can someone please attach a link so I could possibly Id the years they came out of??
Thanks in advance! |
Lind Samba Member
Joined: November 06, 2000 Posts: 9913 Location: idaho
Posted: Mon Sep 14, 2020 8:37 pm Post subject: Re: Bus trans ID numbers |
You can see what day the transmission case was cast on. It is just like the engines, 3 sets of 2 digit numbers.
day day, month month, 1or2or3 year.
14 04 23 is april 14th 1963 or april 14th 1973. _________________ .
Wanted:
Posted: Mon Sep 14, 2020 8:44 pm Post subject: Re: Bus trans ID numbers |
Thanks Lind! That will help figure some things out! Looking for the elusive 67 in the piles. |
Lind Samba Member
Posted: Tue Sep 15, 2020 6:41 am Post subject: Re: Bus trans ID numbers |
this is what they look like. found inside the bell housing.
_________________ .
Wanted:
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3096 Location: Alberta
Posted: Tue Sep 15, 2020 4:25 pm Post subject: Re: Bus trans ID numbers |
So it would correct to interpret this casting as November 17 1960 (as it is a tunnel swing axle centre section)?
_________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
dmuis Samba Member
Joined: September 01, 2004 Posts: 381 Location: Sunny Alberta, Wild Rose Country.
Posted: Tue Sep 15, 2020 5:46 pm Post subject: Re: Bus trans ID numbers |
I found this to be a link I have used often for this purpose.
Engine Case (and other parts) Casting Date Codes
https://www.thesamba.com/vw/forum/viewtopic.php?t=430442
I believe that early split case transaxles have the casting dates on the bottom outside of the case halves at the seam closer to the nose cone. Certainly until September 1955. |
