90weekender Samba Member
Posted: Wed Nov 04, 2020 2:58 pm Post subject: Re: 2.1 MV rebuild |
J,
The text from the GW web site would suggest the 96mm pistons are cast...not forged. Did you buy the early sets of 96's that were forged?
https://www.gowesty.com/tech-article-details.php?id=82
"We use two companies to make our pistons: Silv-O-Lite for cast pistons and JE for forged pistons. We started out with forged pistons in all of our engines even though they were over-kill for the lower performance examples. As the volume of engines we produced increased, we reached a point where we could justify having our own, proprietary casting and forging. All the while, it was possible to further refine an already excellent German piston design by using state of the art alloys and a more modern "slipper skirt" shape. By contrast, the “competition” is still just copying the original, 30+-year-old design piston, and doing a poor job at that.
Fun (sad) fact: The first batch of cast pistons we received and used in our own engines had a higher than normal failure rate, and we ended up having to replace about 10% of them under warranty. Ironically, it had nothing to do with the switch from forged to cast, but rather was a problem with the coating that was used on the sides!"
R |
Posted: Wed Nov 04, 2020 4:29 pm Post subject: Re: 2.1 MV rebuild |
So I see 2 engine spec scenarios I'd like to get feedback on:
Scenario 1: "power now" (never to be turbocharged in future)
NOS DJ pistons
CB 2252 cam
knock sensor
Scenario 2: "OEM turbo-ready" (but strong enough to be turbocharged in future)
NOS pistons and liners
Aftermarket MV-like cam (which cam?)
I'd love your inputs.
R |
hdenter Samba Member
Joined: October 14, 2008 Posts: 2754 Location: San Luis Obispo, CA
Posted: Thu Nov 05, 2020 8:13 am Post subject: Re: 2.1 MV rebuild |
Which way you should go is going to depend on what risks and compromises you are willing to live with...
DJ engines are solid and proven (lots of them in europe) and with the cautionary inclusion of a knock sensor should provide a nice bump in power. Better fuel economy, too. Nothing too complicated, a conservative choice.
A turbo ready motor sends you down a path towards a more significant and exciting power improvement. However, that trail has several potential pit falls... The first is that we could be old and gray(grayer) before Marco or somebody else finally puts out a proven and reliable kit with good long term parts/maintenance support. The second is that an after market or home grown turbo system will add additional layers of technology that can fail and/or be temperamental to tune. The one guy did his Volvo turbo swap that I admire and has been reliable, but are you prepared to do all that work yourself?
My DJ pistons are destined for my work van where I want more power, better fuel economy and dependability. My turbo aspirations are for my daily driver or the UFWW(ultimate frankenstein westy weekender). If one of those breaks down, I will still have an other set of wheels to get me around.
We all go to hell, just pick out the hand basket you want to get there in🤔
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
jberger Samba Member
Posted: Thu Nov 05, 2020 10:15 am Post subject: Re: 2.1 MV rebuild |
90weekender wrote: |
NOS DJ pistons
CB 2252 cam
knock sensor
R |
I would NOT run a 2252 cam with DJ pistons 10.5:1.. too much dynamic CR. I would run properly measured MV pistons and cylinders (don't have to be new) with a 2252 and have happily done so many times. It is a nice combo. Get it running reliably and forget about it.
J |
Posted: Thu Nov 05, 2020 2:43 pm Post subject: Re: 2.1 MV rebuild |
Hdenter, I agree the Turbo-ready route is a longer game with more unknowns.
The DJ cam is the same as an MV...so I would need to find an aftermarket cam close to an MV.
Called Heritage and they are pessimistic about their new MV cam supplier delivering any time soon.
To reduce unknowns I've contacted MansiSpeed wrt a cam choice that will be "turbo-ready". They are saying both the CB Eagle 2252 and a reground MV cam will work well with their 1.35 rockers and turbo kit.
GW cams are regrinds. Not sure the spec.
Vangain cams look OE on the site but are 3 bolt cams. |
Posted: Fri Nov 13, 2020 6:26 pm Post subject: Re: 2.1 MV rebuild |
Crank case breathing looks like a problem on HC WBX that can be solved with aftermarket systems like Mann Provent.
However, I've not seen a single picture of a WBX with one installed. Also, if I chose to install one, I'd like it to be "OE Stock" specification.
This video of Oettinger 3.2s shows a very stock looking breather system but with an added couple of parts off to the right of the alternator. Anyone know if this is worked well? Can it be purchased?
R
Posted: Sat Jan 09, 2021 6:00 pm Post subject: Re: 2.1 MV rebuild |
Happier New Year All,
I've decided to keep the engine stock but add 1.35 ratio rockers. Why?
- Excellent examples of original spec vans are very rare and deliver a totally unique and desirable driving experience.
- This van is in excellent condition and is better kept stock.
- Modding my van to meet modern expectations in the high sierras and mountain passes requires a different drive train.
- A pickup truck with camper setup is better suited for adventures in the American wild.
- This "stock" van will pass German TUV inspection if we want to explore the EU.
As I go through the Muir book, I am taking photos of each step. Here are some highlights:
Clean case and threads: Should I put epoxy on the "bung" holes?
Verifying fit of standard size KS bearings: BTW - I dropped the little dowel pin down the oil tunnel...it fell out easily with gravity by turning the case upside down. Phew!
I put a new brass timing gear on (Van Cafe)...I marred the original pulling it off.
Posted: Sat Jan 09, 2021 6:06 pm Post subject: Re: 2.1 MV rebuild |
I've purchased NOS rods and new 1.9 non-stretch bolts ($220 shipped). I've searched the forum but have not found a guide to remove the 2.1 TTY bolts from the NOS rods and installing the new 1.9 bolts.
Is this work my machinist should do? I thought it should be easy enough to do at home...but I' usually underestimate the complexity of everything I do on this beast.
NOS 2.1 rods with TTY bolts (Cosmolene rubs off with DW-40 or mineral oil)
New 1.9 Rod bolts
R
Robw_z Samba Member
Posted: Sat Jan 09, 2021 11:28 pm Post subject: Re: 2.1 MV rebuild |
R
Stating the obvious, but yes that is a catch can with a PCV valve. If there is no positive crankcase pressure it sucks from the fresh intake, if there is pressure it sucks from the catch can.
-Rob |
Posted: Mon Jan 11, 2021 11:50 pm Post subject: Re: 2.1 MV rebuild |
Thanks Rob for such a clear and concise explanation. I'm not an engineer or mechanic...so it's all pretty mysterious to moi.
Regarding rod bolts. I discovered a new way to search the forum (which I don't remember) but found a few many opinions on rod bolt theory...practical challenges...social implications and future policy SAE and Manufacturer recommendations...GAWD I love this forum! But in the end I was not clear how to remove them at home.
SOOO...a 3 minute chat with my Machinsto confirmed "Yes" I can knock out the bolts at home...pound in the new 1.9 bolts and he is happy to check and correct the ovality of my big ends. YAY!
I'm almost ready to start step 4 in Miurs book.
PS - fresh engine case hardware ready to go.
16CVs Samba Member
Joined: February 22, 2004 Posts: 4026 Location: Redwood City, California
Posted: Tue Jan 12, 2021 12:32 am Post subject: Re: 2.1 MV rebuild |
. _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
Posted: Wed Jan 13, 2021 10:27 pm Post subject: Re: 2.1 MV rebuild |
16cvs,
I appreciate your supremely concise comments, but suggest you opine a bit more lest your inputs be misinterpreted. |
16CVs Samba Member
Posted: Thu Jan 14, 2021 1:34 am Post subject: Re: 2.1 MV rebuild |
,. _________________ 1987 Syncro Westfalia Triple knob (bastard)
dabaron Samba Member
Joined: June 21, 2018 Posts: 2561 Location: Philly, mang
Posted: Thu Jan 14, 2021 7:54 am Post subject: Re: 2.1 MV rebuild |
agreed.
looking forward to seeing this engine completed. vroom! _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
Posted: Sun Feb 07, 2021 10:25 pm Post subject: Re: 2.1 MV rebuild |
A few highlights from installing NOS 1.9 non stretch bolts on my NOS 2.1 rods.
How to loosen the bolts...for noobs like me this is trick:
After installing the new bolts I noticed a little cosmolene on one rod cap...so I took em apart and noticed a lot more dirt in there needing removal:
new rod bolts ready to hammer in:
Posted: Sun Feb 07, 2021 10:43 pm Post subject: Re: 2.1 MV rebuild |
Transmission needs love while im having some bits plated.
New stuff:
New spring is a little longer and stiffer than the OG:
Leaking seal caused by me last year when I hammered this seal into place and felt a the plastic bushing crack. It started leaking immediately:
Both seals damaged:
This time I'm simulating the factory tool with a couple of long sockets:
The outer seal still backs out too easily, so I'm using silicone gasket maker and clamping it in place. We'll see if it stays tomorrow:
felixbobcat Samba Member
Joined: December 13, 2017 Posts: 173 Location: Los Angeles
Posted: Sun Feb 21, 2021 11:11 pm Post subject: Re: 2.1 MV rebuild |
Did you really use a hammer to instal your rod bolts? |
Posted: Mon Feb 22, 2021 11:25 am Post subject: Re: 2.1 MV rebuild |
I did...with a wooden base so nothing got dented. I took them to my machinist and he did a final check. |
Posted: Mon Feb 22, 2021 11:37 am Post subject: Re: 2.1 MV rebuild |
Sealing the case halves.
I've heard Gasgacinch a better sealant for the case halves, because it results in an extremely thin gasket thickness. Whereas the Rienze stuff can be a tad thick which can make all the bearings a tad loose.
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
How round were the big ends with the 1.9 fasteners? _________________ ☮️ |
