My beam is rusty and I donít know what it is...
unclebilly
unclebilly is offline
PostPosted: Tue Sep 15, 2020 6:54 pm    Post subject: My beam is rusty and I donít know what it is... Reply with quote
My car is a bit of a Frankenstein.
It seems to have the right bits for the most part but itís a bit of a mystery what some of them are.
I was trying to ID my beam tonight and found some rust holes I didnít like.
What beam is this? The drums are 4 bolt.
Should I be worried about this rust? The passenger side is worst.
Q-Dog
Q-Dog is offline
PostPosted: Tue Sep 15, 2020 7:38 pm    Post subject: Re: My beam is rusty and I donít know what it is... Reply with quote
Later model ball joint beam. Weld some patches on it and drive it. What year is this car supposed to be?
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
unclebilly
PostPosted: Tue Sep 15, 2020 7:47 pm    Post subject: Re: My beam is rusty and I donít know what it is... Reply with quote
It is a 60 but the engine and trans are 70...
joemama
joemama is offline
PostPosted: Tue Sep 15, 2020 10:02 pm    Post subject: Re: My beam is rusty and I donít know what it is... Reply with quote
Sounds like the body might be a '60, but the pan is later. Ball joint front end came out in '66, and IRS rear in '69. Seems like its not just the engine and trans that are '70.
Dale M.
Dale M. is offline
PostPosted: Wed Sep 16, 2020 6:57 am    Post subject: Re: My beam is rusty and I donít know what it is... Reply with quote
VIN number on pan will tell you what year pans is that will validate the BJ front end.... VIN on pan probably does not match VIN in spare tire well...
Dale
ďFear The Government That Wants To Take Your Guns" - Thomas Jefferson.
unclebilly
PostPosted: Thu Sep 17, 2020 8:48 pm    Post subject: Re: My beam is rusty and I donít know what it is... Reply with quote
Well itís definitely a newer pan... it doesnít have IRS so I have the worst of both worlds.
joemama
joemama is offline
PostPosted: Fri Sep 18, 2020 4:55 am    Post subject: Re: My beam is rusty and I donít know what it is... Reply with quote
When you said the trans was a '70, I assumed IRS.
Well, dont automatically discount the ball joint/swing axle set up. I have a fiberglass buggy thats on a '67 pan, so same thing. While I eventually changed the swing axle to IRS, if I had it to do over, I would have left it alone. I used this buggy all over Glamis, took it to car shows, explored trails all over Big Bear, towed it behind a motorhome and drove it all thru Yosemite, my wife picked the kids up from school, and it worked great. Its a very simple, trouble free combination.
Dale M.
Dale M. is offline
PostPosted: Fri Sep 18, 2020 8:04 am    Post subject: Re: My beam is rusty and I donít know what it is... Reply with quote
For a general purpose buggy(street/off road/occasional auto X) the is noting wrong with what you have... Please explain "worst" comment.... I have had buggies with full BJ/IRs and now only one with SA/K&L and quite frankly and don't find either much superiors over the other for general purpose.... Only exception is BJ/IRS was a bit better in hardcore Auto-X car....
Dale
unclebilly
PostPosted: Fri Sep 18, 2020 12:00 pm    Post subject: Re: My beam is rusty and I donít know what it is... Reply with quote
Based on what I have read, LinkPin / IRS is the most desirable setup. I have Ball Joint / Swing Axle.
The car is used 90% off road on our farm (my 10 year old drives it instead of the quad or his dirt bike most of the time).
I am not going to patch this beam - you can see daylight through the uprights, I will replace it.
Should I get a widened beam or keep it stock width?
It is worth upgrading to a link pin setup? I would probably use the adapter plates that HBB recommended against in the suspension sticky above (the car isnt going jumping).
The beam repair / upgrade will be a winter project and we will continue to use it 'as is' until then.
Stauffenberg
Stauffenberg is offline
PostPosted: Fri Sep 18, 2020 12:56 pm    Post subject: Re: My beam is rusty and I donít know what it is... Reply with quote
Sounds like you should get a stock replacement as you said its only being used on your farm. If you go wider in the front you have to go wider in the rear which would mean going to IRS and then you're spending a lot of money on a farm bug lol people want link pin and IRS because you can get more travel out of them for things like jumping Wink
1971 Super Beetle More cancer than car (sold)
1971 Standard Beetle
1967 Baja Project
Mike E.
Mike E. is offline
PostPosted: Fri Sep 18, 2020 7:21 pm    Post subject: Re: My beam is rusty and I donít know what it is... Reply with quote
VW never produced a bug with a link pin front end and an IRS rear end. All of Baja bugs and buggies you see with a Link pin front and IRS rear were modified at one end or the other. Changing either end, or both ends is a doable project and there are advantages to all of the different options. Weigh all your options along with the intended use of the car and decide what works best for you. The ball joint beams have different diameter tubes and they are spaced apart differently than the link pin. It is not a simple swap the beam deal. Have fun with the car and enjoy
cbeck
cbeck is offline
PostPosted: Sat Sep 19, 2020 5:14 pm    Post subject: Re: My beam is rusty and I donít know what it is... Reply with quote
If you use it in the woods, keep it skinny.
My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779
unclebilly
PostPosted: Sun Nov 01, 2020 8:41 pm    Post subject: Re: My beam is rusty and I donít know what it is... Reply with quote
The pan was built in Oct 65 so Iím guessing itís an early 66.
I thought I found a good beam but it was rusted through like mine. Iím just going to patch mine up on the car.
dustymojave
dustymojave is offline
PostPosted: Mon Nov 02, 2020 1:43 pm    Post subject: Re: My beam is rusty and I donít know what it is... Reply with quote
You can do external patches on the shock towers out of 1/8" plate. You can do a wrap reinforcement around the perimeter of the tower with 1" x 3/16" strap. But when you're welding to the beam tubes, the weld heat can destroy the trailing arm bearings. And your reinforcement SHOULD be welded to the beam tubes. You can remove the bearings (carefully to not destroy them with that) while welding.
Bearings can be replaced with urethane bushings. But having just put a set of current urethane bushings in my own beam, I DO NOT recommend the current ones. They're very soft rubbery junk, not the solid nearly hard ones that used to be sold. Delrin bushings are probably OK.
Richard
A.R.T.S. Tech Inspection MORE/MDR
Bajas, Fiberglass Buggies and Rails built in the Mojave Desert
SoCalBajas Member
Kicked Cancer's A$$...this match
unclebilly
PostPosted: Sat Nov 07, 2020 8:35 pm    Post subject: Re: My beam is rusty and I donít know what it is... Reply with quote
Instead of patching mine, should I replace the beam with a new one? If yes, who makes a stock BJ beam that isnít lowered and is stock width?
dustymojave
PostPosted: Sat Nov 07, 2020 11:09 pm    Post subject: Re: My beam is rusty and I donít know what it is... Reply with quote
https://www.cbperformance.com/product-p/6286.htm
Only $340 Shocked
Maybe I should sell the one I have in my back yard?
Caramba!
Rolling Eyes
Richard
SoCalBajas Member
don1357
don1357 is online now
PostPosted: Sat Nov 07, 2020 11:15 pm    Post subject: Re: My beam is rusty and I donít know what it is... Reply with quote
In reality either way works fine. If you like to weld things go to town, or just spend $50 on a barebone beam and move everything over.
