JackVW1959 Samba Member
Joined: February 15, 2014 Posts: 64 Location: Homewood, Illinois
Posted: Fri Sep 18, 2020 6:20 am Post subject: 1967 Type1 rear passenger ash tray missing hinge |
I've attached pictures of the rear passenger ash tray from my 1967 type1. I've had it put away for quite awhile and now that I'm ready to install it I find I cannot attach the door to the base. I can't find how the door attaches to the base.
I've looked through the search Forum and found only questions about the assembly. Does anybody out there have a picture of the hinge or missing part? I don't see anything on the inside of the door that would even accept a hinge or pin. I even have an extra ash tray without a hinge as well! Does anyone have a picture of the assembled unit? Thanks |
finster Samba Member
Joined: May 26, 2012 Posts: 7951 Location: north o' the border
Posted: Fri Sep 18, 2020 9:06 am Post subject: Re: 1967 Type1 rear passenger ash tray missing hinge |
that's because you're missing the actual ashtray itself with its spring/stub out plate that fixes to the back of the cover _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
KTPhil Samba Member
Posted: Fri Sep 18, 2020 9:24 am Post subject: Re: 1967 Type1 rear passenger ash tray missing hinge |
I've never seen that style ashtray in any mid-'60s Bug. I've only seen this style:
The ones with the knob/handle are older, I think.
https://www.thesamba.com/vw/forum/viewtopic.php?t=474500
But I agree in any case that there is no hinge required, and the tray is missing. |
Posted: Fri Sep 18, 2020 11:31 am Post subject: Re: 1967 Type1 rear passenger ash tray missing hinge |
pretty sure this style is for a vert - which jack owns judging by the photos in his gallery _________________ "we're here on Earth to fart around" kurt vonnegut
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Fri Sep 18, 2020 1:45 pm Post subject: Re: 1967 Type1 rear passenger ash tray missing hinge |
finster wrote: |
pretty sure this style is for a vert - which jack owns judging by the photos in his gallery |
bingo _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
67conv Samba Member
Joined: July 10, 2005 Posts: 386 Location: Simi Valley, California
Posted: Fri Sep 18, 2020 3:19 pm Post subject: Re: 1967 Type1 rear passenger ash tray missing hinge |
Definitely a convertible ashtray. Picture is of a factory original "1967 only" CONVERTIBLE right rear 1/4 panel with the ashtray in place. If memory serves me correctly this style of rear ashtray was used on convertibles from 1958 - 1968. Perhaps it doesn't matter to the OP, but I do believe that since his ashtray has the "gray" colored plastic pull knob, it was for an earlier model convertible - from the early 60's and not for a 1967. The 67's have a "whiteish-cream" colored pull knob. At least mine does, and all the other 67's I've seen do too. Maybe "AirCooled" can verify this on his all original 67 convertible?
_________________ 1967 VW Convertible, owned /driven /pampered for 34 years.
1957 DKW 3=6, owned /driven /risen from the dead for 20 years.
Previously owned: 72 "Baja Champion SE" Spec. Edition Super Beetle bought NEW; 79 Convertible bought NEW; 67 type 1 savanna beige; 67 2.0 911S; 73 2.4 911T; 63 356 T6 B Cabriolet; 64 356 SC sunroof coupe; 72 Type-3 Squareback; 68 + 69 Type-3 Fastbacks; 87 Vanagon GL Wasserboxer |
Posted: Sat Sep 19, 2020 6:32 am Post subject: Re: 1967 Type1 rear passenger ash tray missing hinge |
Ah yes. I'll look on the pile of parts I have on my work bench. I'll bet my missing ash tray piece is buried there. I have two 67 VW convertibles. One driver and the other for parts. Both had the ash trays and both had the gray knob. I haven't really focused on the ash tray when viewing other cars and car shows but I wasn't working on them at that point. I can't confirm that I've seen the cream colored version. Thank you to all for your information and pictures that has helped considerably. |
