Info needed on older EMPI P/C set
vwracerdave
vwracerdave is offline
PostPosted: Fri Sep 18, 2020 10:13 am    Post subject: Re: Info needed on older EMPI P/C set Reply with quote
I'm sure they are the standard wall 92's
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos
johnnyvw164 Premium Member
johnnyvw164 is offline
PostPosted: Fri Sep 18, 2020 9:37 am    Post subject: Re: Info needed on older EMPI P/C set Reply with quote
I have a picture of the labels on the box, that's where I got the part numbers from. They are 69 x 92.
If anyone is interested, I could put you in touch with him. He is located in Easton PA
I took another look at the picture, Mahle is written all over it (literally...LOL)
Dan Ruddock
Dan Ruddock is offline
PostPosted: Fri Sep 18, 2020 6:53 am    Post subject: Re: Info needed on older EMPI P/C set Reply with quote
johnnyvw164 wrote:
I found someone local selling a EMPI 92mm P/C set, made in 2012. The EMPI part number is 98-1992-B. They look to be Brazilian made with forged pistons. There is a product code of K70371 from the manufacturer. Does anyone out there know anything about these, how good they may be (especially compared to what's currently on the market)? I hadn't planned on going to that big of a bore, but if these are something good I may consider them.
Thanks!!
Sounds like cima/mahle. Do you have the box? Pic of the spec label would help. What is his price. Are they a stroker set? They are very good quality.
Dan
halfassleatherworks
PostPosted: Fri Sep 18, 2020 6:52 am    Post subject: Re: Info needed on older EMPI P/C set Reply with quote
check here
https://www.amazon.com/EMPI-98-1992-B-FORGED-PISTON-CYLINDER/dp/B00BBJUZEK
Product description
Mahle Brand Forged 92mm X 69mm Aircooled Vw Pistons And Cylinders.
92mm X 69mm = 1835cc
Machining Required On Heads 90.5/92mm
Machining Required On Case 90.5/92mm
Complete Set Includes:
Set Of 4 Barrels, Forged Pistons, Rings, Wrist Pins And Clips.
Applications For Volkswagen Air Cooled Engines, Type 1 Bug, Beetles, Karmann Ghia, Type 2 Bus, Type 3 Squareback, Fastback, Notchback.
Mahle K70371
Halfass Leatherworks*****GOT LEATHER Made to order Leather crafts, you can find us on that face book thing
Belts, wallets, mouse pads, drink coasters, Engraving, most things made in leather.
personal items if you want it in leather in Reno Nv, *****
Last edited by halfassleatherworks on Fri Sep 18, 2020 6:54 am; edited 1 time in total
PostPosted: Fri Sep 18, 2020 6:41 am    Post subject: Info needed on older EMPI P/C set Reply with quote
Thanks!!
