door nuts thread pitch
charleslabri
charleslabri is offline
PostPosted: Sun Sep 20, 2020 7:13 pm    Post subject: door nuts thread pitch Reply with quote
when looking at the catalogues, they all say that the main door bolts for the front are 8x18mm... doesnt give me a thread pitch.
Anyone know if these are 1.0, 1.25, 1.5? I want to start replacing the sensitive bolts with stainless steel and dont have a good read on which pitch to buy.
Thanks!
ZsZ
ZsZ is offline
PostPosted: Sun Sep 20, 2020 11:58 pm    Post subject: Re: door nuts thread pitch Reply with quote
in Metric M8 means 1.25 thread pitch if not stated other
Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008
Vanagon Nut
Vanagon Nut is offline
PostPosted: Mon Sep 21, 2020 12:03 am    Post subject: Re: door nuts thread pitch Reply with quote
For lack of an actual answer....
IIRC, those types of bolts are used in many places on a Vanagon. So, an appropriate stainless M8 bolt should be available at an Ace Hardware or Home Depot. Take the old bolt and match up by eye? My guess is it's a 1.25 per inch thread count.
Neil.
1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN
ZsZ
ZsZ is offline
PostPosted: Mon Sep 21, 2020 12:29 am    Post subject: Re: door nuts thread pitch Reply with quote
Standard M8 IS 1.25mm thread pitch.
Fine thread is M8-1.0 mm ultra fine is M8-0.75 mm, no coarse thread
https://en.wikipedia.org/wiki/ISO_metric_screw_thread
VW partnr for those M8x18mm bolts is N 01023911 which means a high tensile 8.8 structural grade bolt
Zoltan
dobryan
dobryan is offline
PostPosted: Mon Sep 21, 2020 5:55 am    Post subject: Re: door nuts thread pitch Reply with quote
Be sure you get the correct strength bolts to replace the stock ones.
Dave O
The Western Syncro build
MarkWard
MarkWard is offline
PostPosted: Mon Sep 21, 2020 6:00 am    Post subject: Re: door nuts thread pitch Reply with quote
You might want some Tuff Gel. Stainless hardware can be extremely frustrating to work with. The threads have a tendency to gall on assembly. I suggest going to an online company like Mc Master Carr to compare bolt strength. While unlikely, in an accident, the doors are part of the structure. Wouldn’t want a fastener to fail.
charleslabri
PostPosted: Mon Sep 21, 2020 7:09 am    Post subject: Re: door nuts thread pitch Reply with quote
thanks all!
i was using mcmaster to get parts Wink
Jake de Villiers
Jake de Villiers is offline
PostPosted: Mon Sep 21, 2020 7:28 am    Post subject: Re: door nuts thread pitch Reply with quote
ZsZ wrote:
VW part numberr for those M8 x 18mm bolts is N 01023911 which means a high tensile 8.8 structural grade bolt
As Mark alluded, stainless steel bolts will not meet the strength/safety requirements in that application.
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
charleslabri
PostPosted: Mon Sep 21, 2020 12:22 pm    Post subject: Re: door nuts thread pitch Reply with quote
yeah, total bummer. i was just reading up on it. I bought some of the goop that mark recommended
ALIKA T3
ALIKA T3 is offline
PostPosted: Tue Sep 22, 2020 11:45 am    Post subject: Re: door nuts thread pitch Reply with quote
Neil.
Hi Neil!
No evil inch in metric hardware. 1.25mm per turn is what it means Wink
