wheel alignment
3crispies
3crispies is offline
PostPosted: Tue Sep 22, 2020 2:27 pm    Post subject: wheel alignment Reply with quote
Getting front wheels aligned tomorrow after building front end. Been reading up and many confusing posts. Been told 1 deg negative camber and 3mm toe in each.
Running adjustable front beam on standard spindles and 145 tyres.
Any pointers on settings ??
RA 70
RA 70 is offline
PostPosted: Tue Sep 22, 2020 2:48 pm    Post subject: Re: wheel alignment Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?t=206764
Here’s a good detailed write up for alignment specs etc. Also after lowering your car you may find a need to adjust the caster. P
