Abscate Samba Member
Posted: Thu Sep 24, 2020 2:39 am Post subject: 2002 T4 - ATF temperatures while towing |
Just some data to report on my T4
I had a 1998 Volvo v70 follow me home, load was 3500 pounds
Towing in about 65F ambient, I saw AtF temps, monitoring data block 5 , of 98-117c on a five hourtrip.
95% of the time on flatland it ran at 103-5C, Tow speed 60 mph
The 117 C was peak at the top of the Berkshire Spur 15 minute hill pull. The T4 took that at 60 mph _________________ .ssS! |
MrPulldown Samba Member
Joined: September 08, 2020 Posts: 649 Location: Truckee
Posted: Thu Sep 24, 2020 4:26 pm Post subject: Re: 2002 T4 atf temperatures while towing |
Is this with an external/after market ATF cooler. SOrry I am new to this forum and do not know everyone's mods. _________________ 2002 EVC |
Posted: Fri Sep 25, 2020 2:02 am Post subject: Re: 2002 T4 atf temperatures while towing |
Attained 18 mpg In hilly country.
All stock, no aftermarket crap. _________________ .ssS! |
orbeamike Samba Member
Posted: Fri Sep 25, 2020 11:20 am Post subject: Re: 2002 T4 atf temperatures while towing |
This would be an interesting topic for people with original transmission heat exchanger setup to post their experience:
As for me: Based in NorCal, 8 years ownership of a 2001 EVC, 30K miles driven since my ownership all over the western states and many trips to the sierras. 90K miles total on the EVC. Just this year I start to monitor my transmission temp using Torque Pro. The transmission operates mostly in the 210F to 230F range. The transmission is serviced with OEM fluid and filters at 30K interval.
My uncle has a 2000 EVC with about 160K miles all original setup. No issues.
Joshwa Samba Member
Joined: November 18, 2015 Posts: 810 Location: North Seattle WA
Posted: Sat Sep 26, 2020 2:18 am Post subject: Re: 2002 T4 atf temperatures while towing |
It reached steady state of 115-117 in about 2-3 minutes on the hill pulls, so a longer one wouldn’t change much. I was pleased to see the stock config handled the heat so well.
The EVC is a heavier beast of course, so more heat generated. _________________ .ssS! |
sagavan Samba Member
Posted: Sat Sep 26, 2020 8:14 am Post subject: Re: 2002 T4 atf temperatures while towing |
I haven't towed yet, but my normal ATF operating temperatures are around 170 - 180 Fahrenheit (76 - 82 Celsius) with a tranny cooler. When going up a hill, i try to keep it around or below 200F (93C).
117 Celsius (242 Fahrenheit) seems quite high to me. Or perhaps I'm overly conservative with my atf temps? |
Posted: Sat Sep 26, 2020 1:12 pm Post subject: Re: 2002 T4 atf temperatures while towing |
sagavan wrote: |
This is the question that never gets answered, with the stock setup what's considered normal operating range? Assuming regular OE fluid service intervals and proper level.
People with external trans coolers all start to freak out when trans temp climbs above 200F, and yet there are people running stock setup with 200K+ miles for the past 20 years or more. I can guaranteed trans fluid temp almost always operate above 210F with stock heat exchanger. |
Posted: Sat Sep 26, 2020 2:29 pm Post subject: Re: 2002 T4 atf temperatures while towing |
It’s supposed to. The coolant temperature is close to 100C So the exchanger will be warming the ATF in winter. The transmission is designed for this
Excursions to higher temperatures are ok as long as you avoid breaking the oil down. I’ve been replacing mine at 50k intervals and I am now using synthetic Pentosin
If I had an EVC and was in the mountainous West, I would hang a cooler, but not in my flatland under standard use. _________________ .ssS! |
alaird Samba Member
Joined: September 08, 2013 Posts: 21 Location: portland
Posted: Sun Sep 27, 2020 12:27 am Post subject: Re: 2002 T4 atf temperatures while towing |
Just installed a scangauge in my 02 and completed a quick (2000mi) road trip through west coast mountains and a fair amount of fast passing. Not towing anything and with an aftermarket cooler, I was seeing coolant temps max around 198 and ATF temps max around 185. |
Posted: Sun Sep 27, 2020 8:03 am Post subject: Re: 2002 T4 atf temperatures while towing |
Abscate wrote: |
If I had an EVC and was in the mountainous West, I would hang a cooler, but not in my flatland under standard use. |
So it’s degraded oil that causes most transmission failures? Doesn’t excessive heat sometimes throw a code? This is good to know. I sure would like to drop a gear and go a little quicker up some of the highway climbs and passes. |
Posted: Mon Oct 26, 2020 1:33 pm Post subject: Re: 2002 T4 atf temperatures while towing |
Abscate wrote: |
In the last couple trips out here on the west coast in my EVC I have not seen my transmission temp surpassing your 117c (242f). Most of the highway miles are between 104 to 110c (220 -230f). No shifting issues. |
Posted: Mon Oct 26, 2020 3:26 pm Post subject: Re: 2002 T4 atf temperatures while towing |
orbeamike wrote: |
Abscate wrote: |
That’s not surprising. Remember I was towing 3500# _________________ .ssS! |
Posted: Tue Oct 27, 2020 2:43 pm Post subject: Re: 2002 T4 atf temperatures while towing |
Abscate wrote: |
That’s not surprising. Remember I was towing 3500# |
Do you also monitor your trans temp not towing? Does it get noticeable cooler?
My EVC only got to 117c (242F)when I was going up a steep grade in manual mode in 2nd gear, transmission still shifts well afterwards. Collectively I am trying to figure out what's considered "normal" operating temp range of a stock setup.
My transmission still seems to operate without issues between 210F to 245F. Just wondering with your experience? Thanks, |
midwestOutreach Samba Member
Posted: Sun Nov 01, 2020 4:35 pm Post subject: Re: 2002 T4 atf temperatures while towing |
My input on the temps pre vs post cooler installation.
Approx. 70F outside
Stock: ATF temp. 100-120C
Aftermarket: ATF temp. 80-90C
Highly recommended. _________________ In the garage: |
Posted: Sun Nov 01, 2020 6:50 pm Post subject: Re: 2002 T4 atf temperatures while towing |
midwestOutreach wrote: |
Approx. 70F outside
Highly recommended. |
I don't think there is any dispute that external cooler lowers the transmission temp compared to stock. Question has always been what's considered standard operating temp range. I know there are EVCs with over 200K miles with stock setup and all is still running well. 210F to 240F is fairly common with stock setup, if this temp range is detrimental then how do you account for many many properly maintained vans with this mileage? People install coolers because that's what online forum and groups recommends, but is it really necessary? external cooler is not without its own set of issues.
Below is a post from 2018 that I thought would be an interesting refresher related to this discussion:
markcm2 wrote:
I monitored temps on our recent trip down and back on the west coast while ambient temps were around 60-80 during the day. I have a German Transaxle kit without t-stat. Average transmission temps were 120-150, lows were around 100.
Normal climbs like a pass where I could maintain average speeds of 60mph or better (assuming the torque converter was fairly well locked up) my temps would rise up around 205.
In one case entering the sequoia national park from the southern (Three rivers) side the climb is pretty brutal. Speeds range from 10-35mph while elevation climbs several thousand feet. Ambient was probably around 60 while transmission temps hovered in the 240-250 range for the last 20-30 minutes of the climb. Our 2001 MV weekender Westy was loaded with 4 people, all our gear for 2 weeks, a rooftop space box, and a 5' wide aluminum hitch mounted cargo box on a steel swing hitch (the hitch weighs 40lbs alone).
I'm pretty sure my transmission has Redline D4 in it which led me to wonder what the operating temps are on such a fluid. I didn't find it directly on the site so I gave them a call and spoke to an application engineer who was very friendly and helpful. Here are some points I picked up from my questions that ya'll might be interested in if you don't already know:
Q: Is 240-250F for 20-30 minutes enough to degrade the performance of the D4 fluid, and should I change my fluid now?
A: Not at all, D4 will not be compromised at 250F. Generally speaking though, seals may begin to soften around 295, and hard parts such as clutch discs could start to see surface effects around 325-350; you'd be advised to keep your temps below 300.
Q:Some of us are using thermostats (set at about 190) in our Transmission cooler circuits (recommended by GoWesty); do you see this a benefit and is this a good temperature?
A: Yes, a thermostat is a good idea and 195 is perfect. Benefits of running a Tstat at this temp are reduced friction compared to cooler fluid such as the 120F you mentioned which can reduce lubrication and increase fuel consumption (effects of the higher viscosity at lower temps); both negative impacts. Running cooler also prevents heat from evaporating off any condensation in the ATF that may have accumulated. I would advise installing the thermostat for best performance. |
Posted: Thu Nov 05, 2020 8:22 am Post subject: Re: 2002 T4 atf temperatures while towing |
orbeamike wrote: |
Abscate wrote: |
Mine stays nailed to the coolant temperature when I am not towing. Thats by design of course. Good Post above on this _________________ .ssS! |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Sat Jun 04, 2022 8:32 pm Post subject: Re: 2002 T4 atf temperatures while towing |
In a couple weeks, my wife is planning to drive our 2003 EV from Kansas to the very center of Utah, to pick up her sister and help move back to Kansas.
They plan to rent one of those enclosed UHaul trailers for the trip back.
I was a little worried about the transmission temps in the mountains especially, and considering a cooler. In reading the big thread there, I came here.
And now I'm not so sure a cooler is necessary, but it still seems like not a bad idea to have some kind of easy temp readout for her to keep an eye on while towing in the mountains to help make sure they don't try to go too hard with it and fry the trans.
Any recommendations on something? I think I'm interested in one that plugs into OBD, because I could potentially move that from the EV to my Bus or the Passat as needed in the future.
I don't necessarily need all the bells and whistles, as long as I can set it to where she can always see the trans temp. Bonus, I suppose, if I could set some kind of alarm to go off at a higher temp.
Sidenote, is there any recommendation to shift from D to 3 when towing?
Only towing the van has done so far is our boat to the lake, but that is only a few miles so I've never been concerned. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Sun Jun 05, 2022 2:32 am Post subject: Re: 2002 T4 atf temperatures while towing |
If the transmision starts hunting going up a grade, move it into the 3 position until you crest. What’s the total load of trailer plus contents? _________________ .ssS! |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2541 Location: Ocean Beach in Beautiful BLUE California
Posted: Sun Jun 05, 2022 8:11 am Post subject: Re: 2002 T4 atf temperatures while towing |
ScanGauge2, and get it from the factory. OBD2. I *hear* they can preset it for Eurovan codes.
We have been very happy with our gauge.
Our transmission hit 245 degrees in our 2002 EVC, heavily loaded climbing up to Cedar Breaks Utah on a 100+ degree day. Slope was between 8 and 11 degrees. At that point we aborted the climb. This with the GoWesty cooler installed.
Suggestion: get the cooler and worry less. The ScanGauge will keep you informed. _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
