RainierSyncro Samba Member
Joined: February 26, 2013 Posts: 806 Location: Seattle
Posted: Thu Sep 24, 2020 6:06 pm Post subject: Need an eye bolt for a ratchet strap mounting point |
I haul my 2020 Honda Monkey in my van and have two ratchet straps to hold it in place. One is a strap wrapped around the pass shoulder belt mount and the other uses the bolt that holds the lower part of the back seat in place. My Macgyver'ed solution is a huge washer with a strap wrapped around twice to have something to hook into. It's not the most confident method, but what I really need is an eyebolt. Went to a bolt/nut store and they said that they didn't have anything with that fine of threads. Before I go down a multi hour rabbit hole, anybody out there know where I can get a 16mm eyebolt or know a better way to hook into this mounting point?
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Thu Sep 24, 2020 7:34 pm Post subject: Re: Need an eye bolt for a ratchet strap mounting point |
Looks like that's what I need. We'll see if it will work. Thanks |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Thu Sep 24, 2020 8:16 pm Post subject: Re: Need an eye bolt for a ratchet strap mounting point |
If that doesn't work, I secure my fridge in my Bus by using the second, unused seat belt hole (for middle seats if installed). A bolt and similar washer go into the hole, and the bolt tightens down to secure the hook of the strap.
You could also loop that strap around itself to tighten securely around the threads of the bolt. _________________ Dave Cook
1973 Wild Westerner
My Thing |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1842 Location: Vancouver Island, BC
davideric9 Samba Member
Joined: January 21, 2009 Posts: 1000 Location: Oakland CA
Posted: Fri Sep 25, 2020 8:03 am Post subject: Re: Need an eye bolt for a ratchet strap mounting point |
I've harvested many seat belt "eyes" from junk yard, as well as some trunk folding cleats. Almost free and plentiful, and the hole matches our seat belt bolts. I have purchased the gowesty eyebolts, but no longer see the need for these.
Gowesty eye bolts
_________________ 1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012) |
eeebee Samba Member
Posted: Fri Sep 25, 2020 8:04 am Post subject: Re: Need an eye bolt for a ratchet strap mounting point |
Any hardware that you can imagine at McMaster-Carr https://www.mcmaster.com/ _________________ Eric
1987 Vanagon Wolfsburg Special Edition
GoWesty 2.3
Democracy is the recurrent suspicion that more than half of the people are right more than half of the time. |
Posted: Fri Sep 25, 2020 10:10 pm Post subject: Re: Need an eye bolt for a ratchet strap mounting point |
Thanks for the ideas. I bought the GW eye bolts. We'll see if that's all I need. Not very many mounting points when the floor is all aluminum and I have the wall behind the front seats. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9606 Location: Western WA
Posted: Sun Sep 27, 2020 9:22 am Post subject: Re: Need an eye bolt for a ratchet strap mounting point |
Every time I need eye-bolts or attach points i don't have them.
Thanks for the reminder. _________________
....KTMs, GasGas, SPOT mtb |
jlrftype7 Samba Member
Posted: Tue Sep 29, 2020 7:12 pm Post subject: Re: Need an eye bolt for a ratchet strap mounting point |
Installed these tonight. I like the fact that they were inexpensive, kind of match the existing bent metal of the seat belt, and allow me to keep the bolt cover as well.
McMaster Carr, stainless steel, part 31665T43.
They are made for a 3/8” bolt. So, you need to open the hole to fit the 7/16” bolt on the vehicle. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Zeitgeist 13 Samba Member
Posted: Wed Sep 30, 2020 11:17 am Post subject: Re: Need an eye bolt for a ratchet strap mounting point |
I used old seatbelt anchors in my Eurovan when I picked up a rebuilt WBX a few years ago. I like how low profile they are. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
dabaron Samba Member
Joined: June 21, 2018 Posts: 2559 Location: Philly, mang
Posted: Thu Oct 01, 2020 8:00 am Post subject: Re: Need an eye bolt for a ratchet strap mounting point |
Zeitgeist 13 wrote: |
I used old seatbelt anchors in my Eurovan when I picked up a rebuilt WBX a few years ago. I like how low profile they are. |
lovely idea, any u-pick place should have gobs of these rip for the harvesting. _________________ 1991 Vanagon GL Camper
"burnin oil and cookin coils" -- Destructo
BiWerks Design, LLC |
uberaudi Samba Member
Joined: June 24, 2013 Posts: 502 Location: Hi-top Country
Posted: Thu Oct 01, 2020 8:17 pm Post subject: Re: Need an eye bolt for a ratchet strap mounting point |
jlrftype7 wrote: |
They are made for a 3/8” bolt. So, you need to open the hole to fit the 7/16” bolt on the vehicle. |
I use the same ones! _________________ '84 Adventurewagen 1Z Tdi, '89 Tintop ABA, and a 86 Syncro tintop WBX. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12005 Location: Santa Cruz, CA
Posted: Thu Oct 01, 2020 8:21 pm Post subject: Re: Need an eye bolt for a ratchet strap mounting point |
Those are rock climbing hangers, only a few dollars and very strong. I have had a few in the back of the truck forever. |
Posted: Thu Oct 08, 2020 9:19 pm Post subject: Re: Need an eye bolt for a ratchet strap mounting point |
Bought a 2-pack of eyebolts from Go-Westy. They worked! I guess the rear seat mounting points use the same bolt size as all the seat belt mounting points. Thanks everyone for the suggestion.
Posted: Thu Oct 08, 2020 9:35 pm Post subject: Re: Need an eye bolt for a ratchet strap mounting point |
I believe all cars with restraining devices (seatbelts) use the same size fasteners. Interestingly, these are an SAE size and pitch bolt, and not metric. _________________ Casey--
y u rune klassik? |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3096 Location: ABQ NM USA.... Except when not
Posted: Thu Oct 08, 2020 10:16 pm Post subject: Re: Need an eye bolt for a ratchet strap mounting point |
Interestingly, these are an SAE size and pitch bolt, and not metric. |
it is actually a almost same metric...14x1.25 IIRC or something like that... convenient they found a SAE/metric similarity _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Fri Oct 09, 2020 4:14 am Post subject: Re: Need an eye bolt for a ratchet strap mounting point |
vanis13 wrote: |
it is actually a almost same metric...14x1.25 IIRC or something like that... convenient they found a SAE/metric similarity |
7/16-20 is the most common size, but M12-1.75 is used in some vehicles and I swear the Japanese cars are using M11-1.25 which is virtually identical to 7/16-20. _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17126 Location: Retired South Florida
Posted: Fri Oct 09, 2020 5:03 am Post subject: Re: Need an eye bolt for a ratchet strap mounting point |
I think the logic was to use a bolt that was odd enough you couldn’t accidentally install the wrong bolt. _________________ ☮️ |
Posted: Fri Oct 09, 2020 7:27 am Post subject: Re: Need an eye bolt for a ratchet strap mounting point |
MarkWard wrote: |
I think the logic was to use a bolt that was odd enough you couldn’t accidentally install the wrong bolt. |
Might have been! Standard specifies 7/16 UNF, 1/2 UNF or metric equivalent.
The latter (metric) likely part of a revision at some point in time.
7/16-20, grade 8 is pretty much the smallest size that will pass some of the angle strength tests, of which the loads are far greater than any human could endure.
I’m surprised GoWesty would offer those eye bolts, strictly from a liability risk, as I doubt they would meet the angular pull-tests, even if they may not be a safety risk in the real world.
Note, there are plenty of modern (USA) vehicles with M12-1.75 seat belt bolts today, but 7/16-20 is still the overwhelming choice globally. _________________ John - 86 Wolfsburg Westfalia "Weekender"
