white74westy Samba Member
Posted: Wed Sep 30, 2020 3:32 pm Post subject: Plug wires and spark plugs |
Getting ready to do a tune up. Is there a favorite go-to that everyone has had good success with? I've had good results with NGK in the past. Is this okay for a '95 EVC? Stay with copper plugs? Stay away from platinum/iridium? Single electrode, or multiple electrode? Are there plugs and wires that I should stay away from?
Thanks for any and all advice. |
ocelotpotpie Samba Member
Posted: Wed Sep 30, 2020 7:38 pm Post subject: Re: Plug wires and spark plugs |
I tend to go with Champion or NGK in copper for that engine - the 2.5L gasoline.
Looks like the OEM plug is BPR5EKU so that's what I'd get again.
If you can get OEM wires and they won't break the bank then do that. Otherwise NGK or any other top quality brand should be good.
If it's lasted this long as OEM I'd go OEM and get another 25 years out of it. |
dazey77 Samba Member
Joined: May 11, 2020 Posts: 163 Location: Other side of the pond.
Posted: Thu Oct 01, 2020 1:18 am Post subject: Re: Plug wires and spark plugs |
I like NGK (I ride bikes). I fitted the iridum plug, used them on many bikes and found them to perform well and last well. BPR5EIX is whats in mine
Also got some NGK leads.
If your changing the leads then you may want to do the cap and rotor at the same time. _________________ My van modification blog:
www.dazedproductions.co.uk/Vanity |
postjosh Samba Member
Posted: Thu Oct 01, 2020 8:07 am Post subject: Re: Plug wires and spark plugs |
i've been very happy with my 4 electrode iridium bosch plugs in my 2.5 aaf 5 cylinder. they are unobtanium at this point but bus depot still has their little brothers, the 2 electrode platinum. _________________ '93 EV Wkndr – 5 cylinder – 5 speed - 280k+ miles |
Posted: Wed Oct 07, 2020 2:28 pm Post subject: Re: Plug wires and spark plugs |
Thanks for all the responses!
I placed an order with RockAuto earlier today. I ordered NGK wires, Bosch double tipped platinum plugs...they were on clearance for $0.99 each. I also bought a genuine VW cap, and a Bosch rotor. I hope to have them soon. I will report back once everything is in place. Hopefully it will eliminate the stutter I get when I step on the accelerator. |
Mark in a Van Samba Member
Joined: October 07, 2020 Posts: 2 Location: British Columbia
Posted: Wed Oct 07, 2020 7:29 pm Post subject: Re: Plug wires and spark plugs |
white74westy wrote: |
I have a ‘94 and tried the NGK wires (model RC-VWC028). Ended up having to return them because they a) didn’t snap tight to the plugs, and b) was too short to reach the coil. The NGK platinum plugs work fine, though. Hope the wires work better for you. |
Posted: Thu Oct 08, 2020 3:59 am Post subject: Re: Plug wires and spark plugs |
[quote="Mark in a Van"]
There are two coil lengths for the T4 over the years but your part code looks fairly different to mine (95)
NGK lead pack number RC-VW902
It is the longer coil wire. _________________ My van modification blog:
Posted: Thu Oct 08, 2020 6:08 pm Post subject: Re: Plug wires and spark plugs |
[quote="dazey77"]
Mark in a Van wrote: |
It is the longer coil wire. |
I contacted NGK Canada for their input and was told they agreed that the length was not correct but they said they did not offer an alternative set for my model/year. Back they went. |
Posted: Mon Oct 19, 2020 10:03 am Post subject: Re: Plug wires and spark plugs |
As I stated above, I placed an order with Rock Auto. I was a little worried after reading some of the other comments that fitment might be an issue. However, I'm pleased to say that everything worked out.
Here's what I got:
My apologies...but I didn't take a picture of the cap, before I installed it. I ordered an original VW cap to go along with the items above. They have all been installed and are working well!
Here's what came out of the van:
All things considered, the plugs didn't look great, but they didn't look terrible either. They had an unknown number of miles since they were last changed. I have no idea when the cap, rotor, wires etc. were replaced prior to taking ownership. It is hard to tell in the photo, but the contacts inside the cap are pitted. The rotor was extremely stubborn coming out. As you can see in the pictures, the end was burned and corroded. Overall, the van seems to be much happier since they were all changed out. I'm waiting on a new oil drain plug, in order to complete the last portion of the tune-up. Somebody reefed on it and stripped the head. As soon as it comes in, I hope to drain the oil and put in some fresh oil.
I hope this helps! |
subdewd Samba Member
Posted: Mon Oct 19, 2020 5:48 pm Post subject: Re: Plug wires and spark plugs |
At one point I had I installed the 4 electrode bosche plug. Performed worse than
The old ones I took out. Lowered mpg consistently . |
Posted: Tue Oct 20, 2020 9:56 am Post subject: Re: Plug wires and spark plugs |
I haven't had very good luck with the four electrode plugs, either, but some people dig them.
Changing plugs is usually a pretty easy job, too, so it's worth trying them out if you dig. I generally tend to stick with copper single electrode plugs. |
1961tbird Samba Member
Joined: July 21, 2018 Posts: 291 Location: Halifax, Nova Scotia
Posted: Tue Oct 20, 2020 12:41 pm Post subject: Re: Plug wires and spark plugs |
I changed everything out too (wires, distributor, rotor and plugs) in my 95 EVC.
The Bosch Platinum +2 plugs work great.
I bought the Magnecor KV85 8.5mm ignition wire kit from Pelican Parts. Expensive but the build quality is superb. Very happy. |
Posted: Wed Nov 18, 2020 4:47 pm Post subject: Re: Plug wires and spark plugs |
Thanks for all the feedback! I have no reference point, other than the way the vehicle ran prior to the plugs, wires, rotor, and cap having been replaced. So far, so good! I stayed away from the 4 electrode plugs, because there seemed to have been so many mixed results. The two electrode plugs seem to be doing well. There is a definite difference in the perceived performance. I don't have figures yet, because I haven't had her out enough to be able to gather any data, like mpg etc.
The thing that has me completely hacked off at the moment is the oil drain plug:
As you can see, somebody really went to town on this thing, and I can't for the life of me get it out. So completely aggravated and frustrated by this. I have tried a number of different tools and methods, and it still has not budged. I'm also struck by just how soft the metal on the bolt head is. I will figure it out...eventually. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22641 Location: NYC/Upstate/ROW
Posted: Mon Nov 23, 2020 4:15 pm Post subject: Re: Plug wires and spark plugs |
Get a good, new Vice Grip and get that locked on.that will get it.
Easy to weld a bar onto it , too. _________________ .ssS! |
Posted: Mon Nov 23, 2020 5:44 pm Post subject: Re: Plug wires and spark plugs |
The problem is that the drain plug washers aren't soft.aluminun
so people goon them on to keep them from dripping. Good luck, use vice grips and get a new plug washer and maybe use an oring behind.it |
Posted: Thu Dec 03, 2020 9:02 am Post subject: Re: Plug wires and spark plugs |
Cheers dazey77!
This was on the list of options. However, I wanted to chase down all the other options before I went that direction. Update below! I will likely do something similar when it comes time to do power steering. |
Posted: Thu Dec 03, 2020 9:06 am Post subject: Re: Plug wires and spark plugs |
Abscate wrote: |
Easy to weld a bar onto it , too. |
Yes sir!!! I started with parrots nose channel locks and was going to work my way up to a good set of vice grips. Went a slightly different direction.
I would have forgotten about the possibility of welding, had you not mentioned it. Hopefully there's never a next time, but... |
Posted: Thu Dec 03, 2020 9:09 am Post subject: Re: Plug wires and spark plugs |
subdewd wrote: |
Man I was pissed!!! I promise, there were lots of bad words thrown around, particularly after each new approach failed.
This will never happen again, as long as I own the rig. I just can't understand why anyone would think this was okay! |
Posted: Thu Dec 03, 2020 9:30 am Post subject: Re: Plug wires and spark plugs |
2 words,,,jiffy lube. R neighbors honda came home with a cracked oil pan.
Leaked out on their driveway. |
