jeffrw Samba Member
Joined: February 07, 2012 Posts: 19 Location: Las Vegas
Posted: Tue Oct 06, 2020 10:46 am Post subject: Re: Just put in the T3 Technique Swaybar and Endlinks |
candyman wrote: |
4mymalamute wrote: |
jeffrw wrote: |
I’ve been trying to buy for months now but finding both the bar and hd end links in stock at the same time has been tougher than trying to make it in to Wal Mart without a mask on. |
I had the same problem BUT when I ordered from T3 they held the sway bar for me (set it aside since I paid for it) and waited for the end links to come in. Took a couple of weeks but well worth it. T3 kicks ass indeed. Customer service is outstanding and products are top of the line. |
Last month I had to buy the bar from Vancafe and links from T3. With the way everything is nowadays, I was just happy to get them right away |
Now the end links are in stock and the bar is available. Are there any other vendors that stock the end links for T3? _________________ 1991 Carat - Wannabe Daily
2004 Passat - Daily |
porterbrown Samba Member
Joined: February 25, 2005 Posts: 718 Location: Bentonville, AR
Posted: Sat Dec 05, 2020 7:45 am Post subject: Re: Just put in the T3 Technique Swaybar and Endlinks |
Jumping into this thread to give praise to the T3 swaybar and end links. I've recently been considering selling the van to upgrade to a more modern, long-trip worthy, vehicle. After installing the T3 swaybar and endlinks, I'm seriously questioning getting rid of the van. The set removes all of the slop from the front end that you may not even realize is there. I've also recently replaced springs, shocks, UCA bushings and ball joints...and none of those parts hold a candle to the amount of difference the swaybar and endlinks made on how the van drives. It's fun to drive again; I'm seriously impressed with the effects _________________ '90 Westfalia GL Automatic |
hdenter Samba Member
Joined: October 14, 2008 Posts: 2754 Location: San Luis Obispo, CA
Posted: Sat Dec 05, 2020 5:46 pm Post subject: Re: Just put in the T3 Technique Swaybar and Endlinks |
I'm sure it's great! My question is: when will we see the rear sway bar?
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
whereiwannabe Samba Member
Posted: Thu Jun 03, 2021 8:03 pm Post subject: Re: Just put in the T3 Technique Swaybar and Endlinks |
Just installed my T3 sway bar and HD end links today (ordered in February). Kermit is 2WD (with LSD rear). I took the front tires off just to make it easier. Instructions were pretty clear, but I had to jump on the forum to figure out the metal yellow triangle piece placement of the end links - really helped when I realized they could be moved! LOL. I had put Radflo shocks on in April, along with Method wheels (new tires last Fall) and was very pleased with driveability improvements, but man, as many others here have mentioned, I can really feel this one!!! It's been happy days getting Kermit prepped for some road tripping this Summer! Be safe out there. p.s. With the SVX engine I'm interested in rear sway bar as well. _________________ 85 Wolfsburg Weekender aka "Kermit" (my 1st one!) |
S4VAGE Samba Member
Posted: Sat Jun 05, 2021 10:10 am Post subject: Re: Just put in the T3 Technique Swaybar and Endlinks |
These bars are worth every penny. This bar + BFGs + Bilstein + Springs = my van eats up the twisties. Too bad he is on a pretty big backorder. Waiting for one for our newest van... |
aidanp Samba Member
Posted: Sat Jun 05, 2021 2:41 pm Post subject: Re: Just put in the T3 Technique Swaybar and Endlinks |
Do you need to jack up the van to do the bar and endlinks? _________________ 1989 Vanagon Westfalia, with 2.5l Subaru by SmallCar, manual 'box, 16" wheels. |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4353 Location: United States, Iowa
Posted: Sat Jun 05, 2021 2:51 pm Post subject: Re: Just put in the T3 Technique Swaybar and Endlinks |
Technically no. But it is way easier with wheels off. Some of the years Vanagon have a slightly different mount surface, and it might take a little grinding, and probs should then hit it with some paint. Soooo, Ya, good idea to take wheels off, and have ti on jack stands, for safety. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
SeacoastRed Samba Member
Joined: December 18, 2018 Posts: 36 Location: Portsmouth, NH
Posted: Fri Jun 11, 2021 12:53 pm Post subject: Re: Just put in the T3 Technique Swaybar and Endlinks |
A set of ramps is ideal for this job. That's what I used and it was not bad at all although like most projects it took longer than I had budgeted.
I did have to buy a deep well socket for the bottom most nut of the HD end links (can't recall the size). On my 1991 van I also had to cut away a lot of body metal with a dremel as others have done. Chris's instruction reference drilling out a hole for late model vans to fit the sway bar bushing housing but I did not have to do that. |
gtxbullet Samba Member
Joined: July 29, 2010 Posts: 258 Location: Pewaukee, Wisconsin, 53072, United States
Posted: Fri Jul 09, 2021 2:57 pm Post subject: Re: Just put in the T3 Technique Swaybar and Endlinks |
hdenter wrote: |
Hans |
Buy 2 and install 1 in the back. There are images of how to install a front Vanagon sway bar in the rear.
I'll be doing this using my original front bar once the T3technique unit is in the front. _________________ Technician / Mechanic / Specialist
https://www.youtube.com/@itsastevething./videos
https://www.instagram.com/itsastevething/
https://www.facebook.com/ItsASteveThing/
Current Vehicles:
1988 Fiero 2.5L 5-speed
1985 Vanagon Multivan Subaru EZ30D with Subarugears 4.86 LSD 5-speed
1985 Vanagon Westfalia Weekender
2003 Jetta GLI VR6 6-speed |
Vashon Samba Member
Joined: September 23, 2012 Posts: 200 Location: Vashon Island
Posted: Fri Jul 09, 2021 11:20 pm Post subject: Re: Just put in the T3 Technique Swaybar and Endlinks |
I put in a T3 bar and endlinks about two years ago. I was rather disappointed .I expected to sway and rock&roll down the road like a drunken sailor but instead the darn van stuck tight around the corners and acted like it was on permanent good behavor. I almost called Chris to complain about the poor proformance of his bars and endlinks. I then realized after reading the package again I had bought ANTI sway bars.. That explained alot about the sudden civility of my van.
Thank you Chris, for another great T3 product.
btw : installation was easy as van projects go. |
0cean Samba Member
Joined: February 29, 2012 Posts: 1149 Location: California
Posted: Sun Jul 11, 2021 12:26 pm Post subject: Re: Just put in the T3 Technique Swaybar and Endlinks |
Vashon wrote: |
That's just unacceptable . I hope when my order comes, I will have a 50/50 chance of making it around freeway offramps wheels down. _________________ I'm not a mechanic, I just play one on the internet
Cluster Rebuild:
http://www.thesamba.com/vw/forum/viewtopic.php?t=569920&highlight=
Left for Dead the Resurrection Story Build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=613669
(Number of Different Donor VW Vans Body Parts Used: 12)
(Number of completely different vehicles parts used: 3) |
Vashon Samba Member
Posted: Sun Jul 11, 2021 7:50 pm Post subject: Re: Just put in the T3 Technique Swaybar and Endlinks |
I'm not a mechanic, I just play one on the internet |
In my driving experience with Vanagon's there is no reason not to bob and weave and brake. It just keeps the traffic away from you. Driving with precision will only make traffic think you are in control.
Cheers ,Timber
Westy 87 |
do.dah Samba Member
Joined: August 27, 2015 Posts: 447 Location: Washington
Posted: Fri Jul 16, 2021 6:23 am Post subject: Re: Just put in the T3 Technique Swaybar and Endlinks |
If you really wanna make your T3 swaybar and HD endlinks SHINE,, put one of these on; http://vwparts.aircooled.net/Whiteline-Rear-Swaybar-22mm-1986-92-Vanagon-T3-p/bwr12.htm
The pic may make it look as though you lose some ground clearance, but it's actually tucked up pretty nicely.
We have all been waiting for Chris to introduce us to his rear swaybar for many years, and this thing works great until he gets his onto his website. |
Yellow Rabbit Samba Member
Posted: Fri Jul 16, 2021 10:59 am Post subject: Re: Just put in the T3 Technique Swaybar and Endlinks |
I see it’s listed for 86-91 vans. What’s different about pre 86 vans that prevents the Whiteline rear bar from working? |
ProspectiveOwnergon Samba Member
Posted: Fri Jul 16, 2021 12:56 pm Post subject: Re: Just put in the T3 Technique Swaybar and Endlinks |
do.dah wrote: |
I've heard people moving their front to the rear after they installed T3 sway bar up front. |
turbotype1 Samba Member
Posted: Fri Jul 16, 2021 1:52 pm Post subject: Re: Just put in the T3 Technique Swaybar and Endlinks |
do.dah wrote: |
You don't happen to have any installed pics do ya? Just wondering how the endlinks mount _________________
117harv wrote: |
This new fad of get it the lowest, or run it with the worst looks, (patina) isn't cool, it's for the hey everyone look at me crowd, i'm driving a beat down ratty, unsafe, VW, how cool am I ???...your not....
Pissing off the purists since 1997
Wanted: Boyd Motors plate frame
57 Turbo Oval Sliding rag
67 13 window delux walk-thru- now 21
64 all original for the misses
83 Sinka m-TDI diesel |
4mymalamute Samba Member
Posted: Sat Jul 17, 2021 6:37 am Post subject: Re: Just put in the T3 Technique Swaybar and Endlinks |
Wonder if this will work with a Syncro? Anyone try it yet? _________________ 1989 Sally the Syncro.....she is a work in progress. 1.8T and tuned...she scoots up the hills...watch for flying dog drool out the windows.
1969 Bucky the Bug Convertible...red, rusted, work in progress....LOTS of work. |
Viva.Sabata Samba Member
Posted: Sun Jul 18, 2021 5:50 am Post subject: Re: Just put in the T3 Technique Swaybar and Endlinks |
Viva.Sabata wrote: |
Excited to put mine in too. Been accumulating parts while overseas for the past 2 1/2 years! |
Finally got mine in and love it! My van doesn’t lean nearly as much in the corners and it feels *kinda* like my old boxster haha! _________________ Sabata
1987 Westy Full Camper, Peloquin 5-Speed 2wd |
do.dah Samba Member
Posted: Tue Jul 20, 2021 6:18 pm Post subject: Re: Just put in the T3 Technique Swaybar and Endlinks |
@turbotype1, well, I tried loading a pic,, and even though I use to work in the high tech field,, I've apparently fell behind.
The endlinks attach to angle iron pieces, about 1 and 1/2 inches wide and about 3/16 thick. One leg is about 2" long. That bolts to the bottom bolt of the shock. The other leg of the angle iron(probably 1 and 1/2" long) faces towards the opposite side of the van, basically they face each other. The endlinks bolt up to the short leg of the angle iron. It's a VERY simple install, so much so, that in comparison, installing the T3 front bar is akin to doing major surgery.
John at Aircooled.net is VERY helpful, and should be able to tell you if that bar fits other vanagons outside of what is listed. Probably not a lot of people would put it on a synchro, cuz you'd lose so much articulation in the rear, but the endlinks seem like it's be very easy to unbolt them when you get off road. |
