Red Ryder Samba Member
Joined: June 26, 2021 Posts: 952 Location: Northern California
Posted: Tue Jul 20, 2021 2:10 pm Post subject: Wire gauge for auxiliary fuse panel |
Thinking about installing an auxiliary fuse panel behind the glovebox. I plan to pull power directly from the primary battery under the passenger seat for a short run under to this location. Would 8 gauge wire be satisfactory for this application? _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition
Tornado Red |
Vanuber Samba Member
Joined: February 16, 2020 Posts: 411 Location: Virginia
Posted: Tue Jul 20, 2021 3:33 pm Post subject: Re: Wire gauge for auxiliary fuse panel |
Red Ryder wrote: |
Thinking about installing an auxiliary fuse panel behind the glovebox. I plan to pull power directly from the primary battery under the passenger seat for a short run under to this location. Would 8 gauge wire be satisfactory for this application? |
It all depends on what you hooking up to the fuse panel. What is the maximum total power draw in amps?
Plug that number into the Blue Sea wire selection chart: http://assets.bluesea.com/files/resources/newsletter/images/DC_wire_selection_chartlg.jpg _________________ '85 Westfalia 1.9L
'72 BMW R75/5
'71 BMW R75/5
'02 Subaru Forester 2.5L |
squeegee_boy Samba Member
Joined: April 27, 2008 Posts: 762 Location: Langley, BC, Canada
Posted: Tue Jul 20, 2021 3:35 pm Post subject: Re: Wire gauge for auxiliary fuse panel |
https://www.bluesea.com/resources/1437
Here's a good table for this.
For a run that short 8GA wire is good for 40A, fused appropriately.
Robyn _________________ 1984 FrankenSyncro Westy. EJ25 RMW kit
1971 Super Beetle with an EJ22. Oh yes. Daily driver |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9940 Location: Orbiting San Diego
Posted: Tue Jul 20, 2021 4:00 pm Post subject: Re: Wire gauge for auxiliary fuse panel |
Here you can see that #8 Marine wire is rated for up to 80 amps continuous.
http://assets.bluesea.com/files/resources/reference/21731.pdf
Without knowing the size and type of loads you plan to run at the same time we can't say if you should go a size heavier.
Mark |
Gnarlodious Samba Member
Joined: September 28, 2013 Posts: 2323 Location: Adobe Jungle USA
Posted: Tue Jul 20, 2021 5:42 pm Post subject: Re: Wire gauge for auxiliary fuse panel |
#8 should be plenty for anything you are running up there, except for a loud audio amplifier. _________________ Vanagon ’83 diesel AAZ w/Giles injection, 5spd 4.57R&P+TBD and a '78 diesel Rabbit |
Posted: Tue Jul 20, 2021 6:19 pm Post subject: Re: Wire gauge for auxiliary fuse panel |
Thanks for the great feedback. _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
Tornado Red |
