bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Sun Oct 04, 2020 8:31 am Post subject: Troubleshooting generator |
Was working on the 71 Bus as it would not idle properly and would die when throttle was opened. The engine harness was hacked together and also rat bitten. So, I stripped it down and and rebuilt the engine harness.
The voltage regulator was a local old lucas style one and the voltage would vary from 10V to 16V when revved (measured between D+ and ground) - so it needed replacing. We had a new bosch electronic regulator so I also installed that. Also a new battery VW battery +ive harness. All wires were of correct gauge and crimped with OE style connectors.
After changing that and the spark plugs the engine fired right up and runs beautifully. But, the generator now does not charge.
Voltage measured between D+ and ground is now only 0.5-1.5V when revved. I also tested the no load voltage as described in Bentley -- disconnect wire from battery at the VR, connect negative of the multimeter to VR ground, and +ive to B+. Per Bentley it should read about 13.5V -14.5 at 2000rpm. I got nothing.
I'm a bit stumped now - dynamo was working before we changed the wiring. The new wiring is correct -- have triple checked it. And it's pretty simple.
While removing the leads from D and DF, the studs did turn around. Could it have broken inside? Should I check for continuity from D+ to D- (it just struck me as I was typing)?
Any other suggestions?
Thanks _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
VWLover77 Samba Member
Joined: June 20, 2003 Posts: 999 Location: North Canton, Ohio
Posted: Sun Oct 04, 2020 9:02 am Post subject: Re: Troubleshooting generator |
I've had some generator issues myself recently....
Your output test confused me. The one I ran was:
1. Disconnect both wires at the generator and make sure they are well protected so they don't short out on anything.
2. Attach a wire from the DF terminal on the generator to ground.
3. Start the engine and measure the voltage at D+. As you rev the engine, it should increase quite a lot. Mine went to almost 50V.
Do not run this test longer than necessary to verify that the generator works.
If you get no output at all, I'd say it's quite possible one of the wires broke off from one of the studs when it twisted.
Check out this link for more info...
http://www.vw-resource.com/generator.html _________________ Don
1978 Westy
1971 Super Beetle Convertible
"If more of us valued food and cheer and song above hoarded gold, it would be a merrier world." - J.R.R. Tolkien |
Posted: Sun Oct 04, 2020 9:12 am Post subject: Re: Troubleshooting generator |
Did you polarize your new regulator? I don't work on these often enough anymore to remember what to do without just getting out the manual and following their troubleshooting instructions step by step. |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Sun Oct 04, 2020 12:31 pm Post subject: Re: Troubleshooting generator |
Uh, regulators don't 'polarize' - only generators... _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
SGKent Samba Member
Posted: Sun Oct 04, 2020 1:53 pm Post subject: Re: Troubleshooting generator |
telford dorr wrote: |
Uh, regulators don't 'polarize' - only generators... |
so when the earth's magnetic field finishes its flop that is underway, will we all have to re-polarize our generators........... . _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun Oct 04, 2020 2:45 pm Post subject: Re: Troubleshooting generator |
Nah, wouldn't worry about it - we'll all be dead from undeflected radiation as the earth's magnetic field goes through zero... _________________ '71 panel, now with FI
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
i will wait the 10k years to figure that one out |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Sun Oct 04, 2020 2:53 pm Post subject: Re: Troubleshooting generator |
You probably broke the wire off the post inside the housing but it can be soldered back usually without removing the generator.
I did this a few times when I was a young tech. We also were in the habit of
Taking the belt off and jumping d+ to run the generator/fan to cool the engine
Down faster in order to do the valve adjustment quicker.
The worst scenario would be pulling the generator and taking it in to a repair
Shop. _________________ V.W.owner since 1967 |
SGKent Samba Member
Posted: Sun Oct 04, 2020 4:33 pm Post subject: Re: Troubleshooting generator |
old DKP driver wrote: |
Shop. |
oooooh - nifty trick _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
bnam Samba Member
Posted: Sun Oct 04, 2020 6:42 pm Post subject: Re: Troubleshooting generator |
I did try to polarize the dynamo. I was surprised when it turned very slowly when I connected the battery to d+ after grounding df. It did seem to slowly pick up speed but i had read not to do this for long so stopped.
Does the slow rotation during polarization give us a clue?
@old dkp driver - any how tos on soldering without removing?
Thx! _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
Posted: Sun Oct 04, 2020 9:53 pm Post subject: Re: Troubleshooting generator |
You should still be concerned that the connection may be broken under the
Housing.but glad to see the generator is working. _________________ V.W.owner since 1967 |
bnam Samba Member
Posted: Sun Oct 04, 2020 11:31 pm Post subject: Re: Troubleshooting generator |
I will also check the ground and see if it is a grounding related issue. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
SGKent Samba Member
Posted: Mon Oct 05, 2020 9:25 am Post subject: Re: Troubleshooting generator |
you could look for a cheap core that is no good but cheap, and practice on it.. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon Oct 05, 2020 10:13 am Post subject: Re: Troubleshooting generator |
bnam wrote: |
I was surprised when it turned very slowly when I connected the battery to d+ after grounding df. It did seem to slowly pick up speed but i had read not to do this for long so stopped. |
With the field (Df terminal) grounded, the generator will turn fairly slowly. This is because the back ElectroMotiveForce generated by the armature is proportional to the product of the armature speed and the strength of the magnetic field created by the field coils (which is proportional to the field current). If you reduce the field current, the armature will have to spin faster to create the same back EMF. Note: the back EMF is what counteracts the voltage applied to the armature, and thus what limits the armature current.
You can demonstrate this by either (1) adding resistance in series with the field coils, or (2) driving the field with a variable voltage power supply (positive connection to D+, negative to Df). As you reduce the field voltage/current, the generator will spin faster. If you were to reduce the field current to zero, the generator couldn't spin fast enough to generate the needed back EMF (so don't do this - bad idea!)
Note: this is all described in detail by basic DC motor theory.
Quote: |
Does the slow rotation during polarization give us a clue? |
Not really - unless accompanied by a very high current draw, which could indicate a shorted armature winding. _________________ '71 panel, now with FI
bnam Samba Member
Posted: Mon Oct 05, 2020 6:49 pm Post subject: Re: Troubleshooting generator |
Would resistance measurements between D+ and D- (12ohms) and between D+ and DF (16ohms) tell me anything? What should the stock readings be? I guess I could check on my bug.
I checked the ground, was good. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
Posted: Tue Oct 06, 2020 9:03 am Post subject: Re: Troubleshooting generator |
bnam wrote: |
Would resistance measurements between D+ and D- (12ohms) and between D+ and DF (16ohms) tell me anything? What should the stock readings be? |
The armature reading (D+ to D-) is way too high - should be in the fractions of an ohm. Try rotating the generator shaft to get a different brush contact.
Don't know about the field resistance - will have to go measure one. Seems a bit high. Stand by...
Remember, measuring low resistances with a multimeter is problematic at best, as probe contact resistance can be high. To do it accurately, one needs to use a four-wire measurement method (two wires pass a known fixed current through the unknown resistance, and the other two measure the resulting voltage. The second two are high impedance, so probe resistance is no longer a factor.) _________________ '71 panel, now with FI
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Tue Oct 06, 2020 9:12 am Post subject: Re: Troubleshooting generator |
bnam wrote: |
Not really - unless accompanied by a very high current draw, which could indicate a shorted armature winding. |
Damn, he beat me to it. That’s just what I was gunna say _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
cab57 Samba Member
Posted: Tue Oct 06, 2020 1:21 pm Post subject: Re: Troubleshooting generator |
bnam,
I have the same issue with my rebuilt 6v generator.
The polarization test was passed successfully, but not more than 0,5v with my drill at 1600 rpm.
I have about 3ohms between Df and D+, armature and brushes are NOS but same value (0,5v at 1600 rpm) with the original armature.
I am desapointed, everything is new or rebuilt. _________________ Beetle convertible built 06/66
Beetle ragtop built 28/04/59
Posted: Tue Oct 06, 2020 4:10 pm Post subject: Re: Troubleshooting generator |
Connect a battery (or battery charger) between D+ (positive) and Df (negative) [should pull around 4 amps.] Spin the generator again and measure the voltage between D+ and the case. _________________ '71 panel, now with FI
bnam Samba Member
Posted: Wed Oct 07, 2020 1:07 am Post subject: Re: Troubleshooting generator |
cab57 wrote: |
bnam,
I have the same issue with my rebuilt generator.
The polarization test was passed successfully, but not more than 0,5v with my drill at 2000rpm.
I have 3ohms between Df and D+, armature and brushes are NOS but same value (0,5v at 2000rpm) with the original armature.
I am desapointed, everything is new or rebuilt. |
Can you also check between D+ and D-? It should be low, but mine reads high. _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
