Kjlavoie Samba Member
Posted: Tue Oct 06, 2020 4:39 pm Post subject: Door panel |
My 85 vanagon siding door panel needs to be replaced. Anyone know where I can get a new one? The cover is also damaged so I'll need a full replacement. I have found the wood part but not with the cover. Thanks! |
Crooked Designer Samba Member
Joined: March 22, 2018 Posts: 323 Location: Chicago, IL
Posted: Tue Oct 06, 2020 5:42 pm Post subject: Re: Door panel |
Just replaced mine with a high quality replica from GoWesty only to find out my window seal on the slider is leaking when it rains (thought the PO was just lazy and left the door open in the rain)
Wasn’t cheap, but after installation (and before the next full night of rain) it looked amazing. Also gave me a chance to lube mechanicals and add sound proofing to the door. Insulation was in good shape, so just put that back in. _________________ '85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit |
DuncanS Samba Member
Posted: Wed Oct 07, 2020 3:55 am Post subject: Re: Door panel |
Make your own. Cheap and doesn't take very much time. JoAnne Fabrics has some nice leather look vinyl which is extremely close to the OG colors. There are topics on this here. |
wbailey2112 Samba Member
Joined: October 02, 2015 Posts: 483 Location: Grove City, OH
Posted: Fri Oct 09, 2020 11:13 am Post subject: Re: Door panel |
Go to your local big box home improvement store and buy a sheet of MDF. Use your existing panels as templates to cut the new ones. Cover with fabric, vinyl, etc. We opted for MDF bead board and painted them with latex paint from Sherwin-Williams that we had colored-matched to our cabinets. _________________ '74 Thing
'83 Westfalia |
Mi3ke Samba Member
Posted: Mon Jan 04, 2021 1:31 pm Post subject: Re: Door Panel Reupping |
Hello, first time poster here. '85 Vanagon. My sliding door panel is being replaced. Are there any "how to" on installing the panel out there. And any recommendations on the type of adhesive to use between the fabric and the raw pressboard? I have just enough clips to screw just one of them up.
Thanks in advance, Mi3ke |
TopBud Samba Member
Joined: February 28, 2004 Posts: 1111 Location: Flagstaff AZ
Mi3ke Samba Member
Posted: Mon Jan 04, 2021 2:45 pm Post subject: Re: Door panel |
Thanks TopBud. I already have my panel. I am looking for insight into how to best put fabric onto the pressboard (glue) and any instructions on actually installing it onto the door itself. One extra clip to screw up on.
Cheers, Mi3ke |
Posted: Mon Jan 04, 2021 3:02 pm Post subject: Re: Door panel |
JoAnne vinyl "leather", pimp-my-ride chrome strips from FLAPS. Use 3m 90 spray adhesive. it will not come off in hot weather. Wrap over the back edge for 2" |
TopBud Samba Member
Posted: Mon Jan 04, 2021 5:38 pm Post subject: Re: Door panel |
I looked at this video when doing mine. I opted to stay with the ABS. Good luck. Post pictures when you are completed.
https://ourkaravan.com/upholstered-wall-panels/ _________________ 86 bostig SYNCRO
66 convertible Karmann Ghia |
werksberg Samba Member
Joined: February 08, 2005 Posts: 2151 Location: Prescott Valley, AZ
Posted: Sat Feb 27, 2021 12:18 pm Post subject: Re: Door panel |
Thanks for the support .... stay safe. _________________ Werksberg Products....Products that work!
Follow my new products on my Facebook Werks Berg
Click the below ADs link for products & feedback.
Search "werksberg" on Photobucket for products photos & Please remember to buy "American made products!" |
sphet Samba Member
Joined: November 09, 2016 Posts: 345 Location: Vancouver, BC
Posted: Sat Feb 27, 2021 2:57 pm Post subject: Re: Door panel |
I am going to put repro vinyl paper onto mine. I cut a new panel from baltic birch, but pressboard is likely the same. I will use 3M 80 neoprene adhesive spray. It holds up under extreme temperatures. It's what the folks at bus-ok recommend for putting their paper on newly cut boards.
https://www.3mcanada.ca/3M/en_CA/p/d/v000074494/ _________________ 1982 Diesel Westfalia 1.6 NA - The Shellakabuukiee |
Mi3ke Samba Member
Posted: Mon Sep 27, 2021 6:10 pm Post subject: Re: Door panel |
Update to the door project. We bought a nice bamboo fabric from Joanne's along with the 3M spray glue. We got the fabric on and went to install using theses clips:
https://www.gowesty.com/product/upholstery-tools-hardware/2323/door-panel-clip-exposed-head-black-
And they are not deep enough. Any ideas where to get longer clips/plugs? Right now the plugs go through the holes but the length ends at the depth of the fabric (x2) plus the panel. I need it to go about another 3/16ths.
The hole in my life I am trying to fill:
Cheers, Mi3ke |
Posted: Mon Sep 27, 2021 7:52 pm Post subject: Re: Door panel |
The panels use holes which the fabric covers. This is what was used. You screw it in from behind. The head is designed to be covered. Maybe something else will work.
Mi3ke Samba Member
Posted: Mon Sep 27, 2021 8:21 pm Post subject: Re: Door panel |
Bueno. |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15143 Location: Syracuse, NY
Posted: Mon Sep 27, 2021 8:51 pm Post subject: Re: Door panel |
there are ALL SORTS of assorted door panel clip packs out there.
likely even your local NAPA has some on a rotating display by the counter.
but for $20 you'll have more than you ever dreamed of from Amazon/fleabay
https://www.google.com/search?q=assorted+door+panel+clips _________________
Abscate wrote: |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6242 Location: Portland OR
Posted: Tue Sep 28, 2021 9:30 am Post subject: Re: Door panel |
Kjlavoie wrote: |
To answer the question for the OP, you can get new door panels from the following sites:
https://sewfineproducts.com/Bug-Custom-Interiors
https://www.gowesty.com/shop/vehicle-parts/vanagon/body/upholstery/117?v=
Both sell quality products.
Not everyone wants to take the time or has the skill to make a home made product when you can buy professionally made panels for $180. _________________ 89 Westy 2.1 Auto
SyncroHead Samba Member
Joined: May 23, 2005 Posts: 1141 Location: Northern Nevada
Andymon Samba Member
Joined: February 24, 2015 Posts: 313 Location: Medford, OR
Posted: Wed Sep 29, 2021 9:12 am Post subject: Re: Door panel |
Kjlavoie wrote: |
I got a new one from Sewfine. Matching material and a perfect fit. _________________ "Blanch" '85 Westy
"Too many freaks and not enough circuses". |
