dash panels in a 69 Beetle
johnnyvw164 Premium Member
johnnyvw164 is offline
PostPosted: Sun Oct 11, 2020 7:17 pm    Post subject: Re: dash panels in a 69 Beetle Reply with quote
It would make sense that the panels for the padded dash would be a little smaller. Guess I will be doing some cutting and fitting of the original panels. Already did the right side since it was one gauge...we like the look of the "louvers" anyway. It's just a real PIA.
gorbur
gorbur is offline
PostPosted: Sun Oct 11, 2020 2:50 pm    Post subject: Re: dash panels in a 69 Beetle Reply with quote
I have a similar setup with VDO gauges on left and right panels Could only get a couple of tabs on the panel to line up. Panels were bigger too. Its a 75 with padded dash any high spots i smoothed down with a heat gun (delicately). Depending on how you cut the metal of the dash the anchoring rings on each gauge seem to be more than enough to hold the panels down.
73 - Ghia Cabriolet 1600 original
76 - Type1, 1776, full restomod
diamondblue1969
diamondblue1969 is offline
PostPosted: Sun Oct 11, 2020 1:25 pm    Post subject: Re: dash panels in a 69 Beetle Reply with quote
I think the ones for padded dashes are slightly smaller
PostPosted: Sun Oct 11, 2020 8:46 am    Post subject: dash panels in a 69 Beetle Reply with quote
I recently made a local purchase of a set of VDO gauges already mounted in dash panels (for either side of the speedo). Small tach in the right side, oil temp & pressure and voltmeter on the left side. When I went to mount them into the car, I found the panels were slightly bigger than the originals, especially in the vertical dimension (probably 8 mm or so). Does anyone know about different size panels? I was always in the assumption they were the same for just about every year.
