1.8t with stock 4 speed question
pomfritz
pomfritz is offline
PostPosted: Mon Oct 12, 2020 11:13 am    Post subject: 1.8t with stock 4 speed question Reply with quote
Hi
I am considering installing a 1.8t and getting my current 4sp rebuilt at the same time and also installing a Peloquin.
Stephan has said that this setup works fine with the motor. I like that and wanted to hear what other owners with this setup think and any suggestions.
The person doing the tranny recommends a .82 final drive ratio
Also any suggestions on a good place to get the Peloquin and final drive?
Thanks
83.5 233K. GW 2.3, SS exhaust, My German Frau named her Stefi
Wellington
Wellington is offline
PostPosted: Mon Oct 12, 2020 11:19 am    Post subject: Re: 1.8t with stock 4 speed question Reply with quote
You should state what size tire you plan to run.
pomfritz
pomfritz is offline
PostPosted: Mon Oct 12, 2020 11:27 am    Post subject: Re: 1.8t with stock 4 speed question Reply with quote
I run 205/65/15's
Trying to keep the to the original diameter so I can fit int he garage.
Vnyd Dog
Vnyd Dog is offline
PostPosted: Mon Oct 12, 2020 11:32 am    Post subject: Re: 1.8t with stock 4 speed question Reply with quote
Stephan did my 1.8T, and we followed his recommendation for a higher 4th gear. No issues, we run 215/65/16s. Also, if you're reaching out to them, can you ask them who they use for the TBD install? I'd like to also add one to mine and haven't gotten around to it!
'87 Westy 1.8T Conversion, Orignal Owner, European Delivery @ Westfalia factory in Weidenbrueck.
The Story:
https://www.thesamba.com/vw/forum/viewtopic.php?t=713391&highlight=life
pomfritz
pomfritz is offline
PostPosted: Mon Oct 12, 2020 11:39 am    Post subject: Re: 1.8t with stock 4 speed question Reply with quote
I will ask him. I'm planning to use Porters Precision for the tranny. He's really close to me and does work for many VW shops in the area as well from the Bay Area.
Vnyd Dog
Vnyd Dog is offline
PostPosted: Mon Oct 12, 2020 11:44 am    Post subject: Re: 1.8t with stock 4 speed question Reply with quote
I wonder if that's who Stephan uses too. Because when ours was in I know the trans was sub'd out to another shop for the gearing. Anyways, good luck. Are you supplying the Peloquin or just letting Porters do all the work? Shoot me a PM on the price for install once it's done!
The Story:
pomfritz
pomfritz is offline
PostPosted: Mon Oct 12, 2020 11:55 am    Post subject: Re: 1.8t with stock 4 speed question Reply with quote
I'll do that I'm not sure at this point what I will do, still working out the details, but GW sells it for 1400. Seems high so I'd like to see what else is out there and have contacted Peloquin.
dougnlina Premium Member
dougnlina is offline
PostPosted: Mon Oct 12, 2020 12:31 pm    Post subject: Re: 1.8t with stock 4 speed question Reply with quote
I have a Stock ratio box with a 1.8T, it works out fine. A slightly taller 4th is not unreasonable, but ultimately it will depend on the size tire you want to run. I am running 215/75/15s, the van works nicely with this set up and has great power, and I cruise at 70mph and 3900 RPM, generally getting around 18 mpg. The van/engine/exhaust combo does have a resonant frequency between 3400 and 3600 rpm (65mph), so I would suggest you avoid any gearing that will leave it in that range at whatever highway speed you are seeking. If you think you will end up with larger tires than what I am running I would suggest NOT changing the gearing. Another consideration is van weight and how much abuse you are willing to throw at the transmission. (I have a syncro, tranny is to be protected) Big power, coupled with big gearing, big speed and big tires and something is going to break or wear out. Like life, its all a series of priorities and compromises Smile
"Olive" a '60 Ragtop Beetle
"Grover" a '87 Syncro Tintop 1.8T
pomfritz
pomfritz is offline
PostPosted: Mon Oct 12, 2020 2:24 pm    Post subject: Re: 1.8t with stock 4 speed question Reply with quote
Thanks for that info. When running at 3900 are you getting close to the end of the “good” RPM range for the 1.8? Is the tach ranges on the stock cluster still applicable?
Mines not a synchro and the driving is mostly just plain vanilla. Got the usual goodies that add to the weight current engine seems to be fine with it.
PostPosted: Mon Oct 12, 2020 3:38 pm    Post subject: Re: 1.8t with stock 4 speed question Reply with quote
No, 3900 is just where everything smooths out and feels right, I should mention it is 70 indicated but with the larger tires it is probably closer to 75 actual mph. The engine seems fine reving higher, and I have used 5000 rpm for 5-10 minutes at a time in third gear to pull up steep highway grades, The redline is close to 7000. They are incredibly tough little engines. In a perfect world there would be one more gear, but after awhile you just get used to the highway revs.
danfromsyr
danfromsyr is offline
PostPosted: Mon Oct 12, 2020 8:21 pm    Post subject: Re: 1.8t with stock 4 speed question Reply with quote
the 1.8T doesn't mind higher RPMS and will be fine with any gearing really.
I blew 4th gear in my trans 5 hours from home
I came home in 5.5hrs in 3rd gear on the interstate... that was ~60mph back instead of 70mph but 5hrs @ ~4500-5000rpms..
it's fine.. boost responds to 'load' not RPMs as much..
boost costs fuel makes heat. so if you put too tall of a gearing/tire combo then it'll be in 'load' and boosted stage easier and more often..
I prefer to keep the RPMs up vs loading the engine and staying in boost too much or constant
holocenevan
holocenevan is offline
PostPosted: Tue Oct 13, 2020 7:27 pm    Post subject: Re: 1.8t with stock 4 speed question Reply with quote
I have a SAH kit in my 89 Wolfsburg. I had the trans rebuilt by Rancho, with stock gearing, a 4.86 and a Peloquin. 215/75-15 tires. Like the other posters have said a longer 4th would be fine in some situations but the 1.8T doesn’t mind much of anything you ask of it. Yes the green band on the stock tach is accurate, the torque builds noticeably at 2000. The difference is that one can wind it to the rev limiter if you’re in the mood, and it likes it. I will put larger tires on soon. I’m sure it will still rally Ophir Pass up from the Ophir side. Hope this helps.
skyboy
skyboy is offline
PostPosted: Tue Oct 13, 2020 9:31 pm    Post subject: Re: 1.8t with stock 4 speed question Reply with quote
I'm in the process of the conversion, transaxle is currenlty being rebuilt. I have a syncro westy, will be running 215/75/15 tires and a 4.86 r&p. All my math pointed to a 1.17 3rd and a .78 4th. A few said that would be really good, a majority said don't do it. I called GTA to get gt gears, and after talking with them they really suggest staying stock or .82 4th, so I bought heavy duty stock 3rd ratio and a .82 4th. You can give GTA a call and they can run your setup and recommend gearing to fit your vehicle and driving habits.
1968 912 HWT
1991 Syncro Westfalia
4mymalamute
4mymalamute is offline
PostPosted: Wed Oct 14, 2020 7:06 am    Post subject: Re: 1.8t with stock 4 speed question Reply with quote
I installed the 1.8t kit from Stephans....best thing ever! I have stock gearing, which is fine. I run it up and down the freeway (up to Tahoe, down to the Bay Area) cruising at 80mph. She purrs. I have no experience with different gearing BUT I wouldnt mind seeing if it made a big difference. Good luck and see you out on the road up in Folsom or Sacramento area!
1989 Sally the Syncro.....she is a work in progress.
djsixbillion
djsixbillion is offline
PostPosted: Wed Oct 14, 2020 10:16 am    Post subject: Re: 1.8t with stock 4 speed question Reply with quote
Another happy 1.8T driver here - I installed the kit from SAH, and had my Syncro trans gone through by Porter's as well (this is the shop SAH uses). I kept the stock gearing and have no real complaints, but if I had to do it over again would probably go with a higher 4th gear. The engine certainly doesn't mind revving high at all, but the overall driving experience (NVH) for long distance cruising would, I think, be improved. Running 215/75/15 tires, for what it's worth.
1990 Syncro Westy 1.8T
1996 Land Cruiser - Locked/Supercharged/Intercooled - RIP!
vanagonjr
vanagonjr is offline
PostPosted: Wed Oct 14, 2020 6:57 pm    Post subject: Re: 1.8t with stock 4 speed question Reply with quote
Ditto - it just feels better too.
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Wed Oct 14, 2020 7:41 pm    Post subject: Re: 1.8t with stock 4 speed question Reply with quote
Do you just drive around in fourth gear, then? I'm assuming an 012 trans would drop the rpms down significantly in fifth.
Casey--
Volkswagens powered by Volkswagen
'01 Weekender VR6 -->2.5 TDI?
Oly Bulli
'87 300TD OM606 7mm Myna pump and HX30
vanagonjr
PostPosted: Thu Oct 15, 2020 4:24 am    Post subject: Re: 1.8t with stock 4 speed question Reply with quote
If I’m driving 50mph, absolutely. At 62mph or so, I shift between 4th and 5th on inclines, mostly for the reason above; I have 27” tires.
Besides gearing, terrain and tire diameter, one’s cruising speed is a huge overlooked factor.
I read posts about people driving their vans @ 80-85, which I think is nuts (but if I lived in South Dakota, I might have had a different view), so compared to a 62mph cruiser the optimum gearing for an identical drivetrain changes. Well, IMHO.
Zeitgeist 13
PostPosted: Thu Oct 15, 2020 8:50 am    Post subject: Re: 1.8t with stock 4 speed question Reply with quote
The speed limit where I live is 70mph, so those speeds aren't just theoretical. 85mph is really pushing it in any T3 due to unfavorable aerodynamics, but I've certainly done it back when I had the WBX. Even though our T4 is the go-to rig for road trips (for soooo many reasons), my requirements for T3 gearing is that it should be able to cruise comfortably @ 73-75mph without sounding like it needs to upshift. Any engine/trans combo that can't deliver on that requirement is unsatisfactory.
Casey--
Oly Bulli
vanagonjr
PostPosted: Thu Oct 15, 2020 11:16 am    Post subject: Re: 1.8t with stock 4 speed question Reply with quote
@ 73-75, I can leave it in 5th, no problem.
