BCgee Samba Member
Joined: February 22, 2012 Posts: 126 Location: Montana
Posted: Tue Oct 13, 2020 9:29 am Post subject: DIY Swing Arm |
Here’s the visual story of last weekend’s DIY project: a bumper swing arm on the van for carrying bikes, tools, and more.
Started the process with a GW tow pkg rear bumper that I reinforced in the corner, and an upper GW ladder. However, the steep price-tag, lack of robust features, and lower weight limit on GW's swing arm kit made the case for a custom swing arm. Given I had the GW items as new-to-us at a discount but am function-focused and not brand loyal, I considered the VanCafe or Burley sheet metal swing away on the rear upper van pillar, but ultimately decided to stick with a straightforward bumper swing arm build.
Used a 1/4” dual sheer steel bracket, massive 2 3/8 collar, and greased internal bearings on a 3/8” grade eight bolt, suitably overbuilt. The swing arm is 2x3” 1/8” tube also with grade 8 bolts for the removable upper ladder. The swing arm locks at 90 and 110 deg when open, plus an interior latch that drops into a new hole in the bumper: both latches are welded up but use replaceable spring based pins for security and longevity.
I ended up needing to tweak and bend the swing arm top plate to match the GW ladder base's angle, a factor I hadn't originally considered. It didn't look pretty at first but after paint and in practice it works fine with the ladder, and without the ladder it easily attaches to our XL aluminum tool box with another bracket I fabbed up.
A primary emphasis of this swing arm is hauling family bikes, specifically the monster heavy SurlyBigDummy cargo bike via a modified Yakima FrontLoader, while still being able to tow the raft trailer. Total materials cost was about $150, and I'll also recommend the new Titanium 125 flux mig welder from Harbor Freight, picked up to complement my old Lincoln stick welder. The 125 is surprisingly robust, super lightweight with lots of adjustability; it did great on thinner steel at a significant price savings compared to a name-brand flux mig set-up. Looking forward to using the 125 on a roof rack tube build for the hightop.
_________________ 1987 SVX Syncro Hightop |
squeegee_boy Samba Member
Joined: April 27, 2008 Posts: 762 Location: Langley, BC, Canada
Posted: Tue Oct 13, 2020 9:50 am Post subject: Re: DIY Swing Arm |
Nice work. I used the same hinge for a 2 sided rack on my van. They're fantastic
Available here if anyone's interested:
https://www.4xinnovations.com/Swing-Out-Tire-Carrier-Hinge-Assembly_p_109.html
There is a right and left side available. Not cheap, but they'll hold up a team of horses.
Robyn _________________ 1984 FrankenSyncro Westy. EJ25 RMW kit
1971 Super Beetle with an EJ22. Oh yes. Daily driver |
fleetwood41 Samba Member
Posted: Tue Oct 13, 2020 10:21 am Post subject: Re: DIY Swing Arm |
That's freaking great work man!
All for a Big Dummy, nonetheless. _________________ 1987 2WD w/ 2.5 Subi & Poptop Conversion |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3094 Location: ABQ NM USA.... Except when not
Posted: Tue Oct 13, 2020 11:29 am Post subject: Re: DIY Swing Arm |
Very nice! I'd love to see a closeup and parts list for your top latch
_________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
jimf909 Samba Member
Posted: Tue Oct 13, 2020 12:20 pm Post subject: Re: DIY Swing Arm |
The top latch is what came to mind for me as well. I think on both the RMW and GW swingy-outs the top latch could be improved, perhaps by clamping or bolting a more positive engagement point to the top of the hatch. Just latching to the top of the hatch is a wear point. The vinyl on the latch wears through then there's metal on metal touching. I have RMW racks and they're outstanding but I'd point to that latch as being 1 step behind the quality of the rest of the rack. _________________ - Jim
Abscate wrote: |
BCgee Samba Member
Posted: Wed Oct 14, 2020 6:25 am Post subject: Re: DIY Swing Arm |
vanis13 wrote: |
The ladder top latch is GoWesty’s design. I had to bend it to fit the hightop orientation and my custom swing out dimensions: metal alloy seems decent.
I’m considering a latch upgrade; something along the lines of a Destaco J Hook with locking mechanism.
Seems a gold standard latch atop the rear hatch, for tall ladders, would be a bolt or t hook attached into the sheet metal, but that would require drilling and fabrication with close tolerances that still allow for rear hatch opening. _________________ 1987 SVX Syncro Hightop |
thatbaldwinlife Samba Member
Joined: August 01, 2011 Posts: 777 Location: Out exploring
Posted: Wed Oct 14, 2020 6:50 am Post subject: Re: DIY Swing Arm |
Love it when people build their own stuff.
nate _________________ 1987 Westy
Insta: @Thatbaldwinlife
Vanagon Adventure and DIY videos:
That Baldwin Life YouTube Channel |
designer Samba Member
Joined: November 05, 2009 Posts: 484 Location: Idaho-but just the tip
Posted: Wed May 12, 2021 7:59 pm Post subject: Re: DIY Swing Arm |
BCGee if you're still around ... so the spring loaded pin you're using to hold the swing to the bumper ... is that holding up well?
It's the same one as the hold out for the arm when opened and i'm in the middle of a build now and hadn't thought of that option.
Been contrasting and comparing the various latches like you were considering, but haven't settled on one yet. Some are way too long for my liking. Especially for up top ...
I've got my bumper all welded up and I made a swing away hinge from scratch but am still working through securing it when closed. _________________ __________
87 Syncro Westy : 2.5l
"It is that annoying, accelerating downhill so I can make it up the next hill in the same gear. Foot to floor hoping I can get out of the way of other cars getting onto the highway." - somebody on here around 2013. |
TopBud Samba Member
Joined: February 28, 2004 Posts: 1111 Location: Flagstaff AZ
Chilepines Samba Member
Joined: October 11, 2022 Posts: 140 Location: New Hampshire
Posted: Mon Oct 02, 2023 5:25 am Post subject: Re: DIY Swing Arm |
Anyone ever try bolting a hinge like this to a RMW bumper at the existing chain loop mounting points? I just want to mount a water and Bas container - not a heavy tire or bike. _________________ White 89 Westy with 2004 Subaru EJ25 - Betty |
