Abelclasico Samba Member
Joined: December 03, 2017 Posts: 152 Location: Carrboro, NC
Posted: Sun Feb 28, 2021 4:25 pm Post subject: Re: Walt's 1973 412 Barn Find |
quick question about the bumper overriders. Where they an option or only certain models had them?
thanks,
Abel |
NurseryWalt Samba Member
Joined: January 29, 2016 Posts: 145 Location: Abbotsford, BC
Posted: Sun Feb 28, 2021 4:26 pm Post subject: Re: Walt's 1973 412 Barn Find |
Abel,
I think they were dealer installed.
Walter _________________ '66 Bug with collector plate and '73 412 project |
Pepperbilly Samba Member
Joined: April 08, 2017 Posts: 977 Location: Seattle, Wa
Posted: Sun Feb 28, 2021 6:16 pm Post subject: Re: Walt's 1973 412 Barn Find |
Yes, they were a dealer installed option. I have them also on the wagon. If you look closely the rubber impact part on the overriders has a VWoA stamping. Mine are still good to go.
Hey Walter, you say you have a good interior guy. Does he have connections to the original carpet material?. I am trying to get the same material so I can replace the fronts. The rest of my carpet is in great shape in the back so looking for a match. I have the black color with a bit of the salt and pepper.
Bill |
Posted: Sun Mar 07, 2021 4:28 pm Post subject: Re: Walt's 1973 412 Barn Find |
Hello Bill,
Regarding the carpets, I haven't got a sample yet. I told my upholstery guy to match the originals. I'll let you know when I see the new carpet.
Posted: Sun Mar 07, 2021 4:40 pm Post subject: Re: Walt's 1973 412 Barn Find |
Saturday was another bumper day! Took the bumpers to the re-chromer last week but he gave me some homework...remove all the brackets and rubber. So here was my goal for the day.
This was the original front bumper. Fairly bad shape. Luckily the spare front bumper was better.
The original front bumper had a nice reinforcement inside. Took a while to shake out all the straw. It's a barn find after all!
Rear spare bumper with a tow bar and sheared off hitch. Wonder when that broke off! The original rear bumper is in better shape.
Luckily I have all four bumper overriders in varying condition. Getting the rubber strips off was a bit of a challenge. Finally I took them home and chiseled off a few speed nuts.
Drove to Mission, BC to Atomic Plating and delivered my (stripped) bumpers. I guess the real fun will be to find matching rubber strips for the bumpers and overriders.
Ceckert64 Samba Member
Joined: September 16, 2015 Posts: 1963 Location: Manitowoc, WI
Posted: Sun Mar 07, 2021 5:17 pm Post subject: Re: Walt's 1973 412 Barn Find |
Nice build so far!
For some of the bumper pieces, you may have a lot of options. The rear bumper and other pieces is exactly the same as the Type 3s. The only difference is the bumper bracket for the rear on T4s has one extra hole. For the bumper guards, you may be able get some NOS ones or good used ones. T3 and some of the T1 bumper guards may also fit. Here’s a 412 bumper on my T3 Squareback. It just bolted in please with no modifications. The old bumper is on the ground and the 412 one installed.
_________________ 1964 sunroof Beetle Restoration "Herbie"
1972 Sierra Yellow Tin Top Westfalia Camper
“Fitz” 1971 Westfalia Poptop |
Posted: Sun Mar 07, 2021 7:32 pm Post subject: Re: Walt's 1973 412 Barn Find |
I knew the late type 3 and type 4 REAR only (thru 1973) were interchangeable. The fronts are a 411 part only. So does the bumper bracket have to be modified or does it slide right in? I thought the bumper brackets were different.
Bill |
Posted: Sun Mar 07, 2021 9:09 pm Post subject: Re: Walt's 1973 412 Barn Find |
Pepperbilly wrote: |
Bill |
On the brackets, they just slide in. The 412 bumper bracket had three holes for mounts and slid right in. One hole both the 412 and T3s used. Another hole was for use in a 412. The other hole was for use in a T3. So, it was setup for that. But, my T3 bumper bracket didn’t have the third hole drilled. So the bumper brackets may have to be “modified” depending on what they came off of but the extend of the modification is drilling one hole. Hopefully that makes sense. I can get some pictures of the difference.
Aiden _________________ 1964 sunroof Beetle Restoration "Herbie"
Posted: Sun Mar 07, 2021 9:19 pm Post subject: Re: Walt's 1973 412 Barn Find |
Well that is easy! It’s so simple you don’t have to post any photos...and this is good info to know. Thanks!
Bill |
Posted: Sun Mar 07, 2021 9:59 pm Post subject: Re: Walt's 1973 412 Barn Find |
Bill |
Posted: Mon Mar 15, 2021 8:41 am Post subject: Re: Walt's 1973 412 Barn Find |
My restorer has been busy the last week. Wheels are media blasted.
He also got busy on some of the body panels.
To me that is very exciting. Once the engine is out and the whole body gets media blasted, that's a sign that everything moves forward again.
Posted: Mon Mar 15, 2021 10:42 am Post subject: Re: Walt's 1973 412 Barn Find |
Good progress Walter! I have not started any metal or body work yet. My body guy is too busy right now.
Bill |
Posted: Sun Mar 21, 2021 1:27 pm Post subject: Re: Walt's 1973 412 Barn Find |
More bumper stuff. My rechromer called to tell me he has started and he wants money!
While I'm waiting for the wheels to be finished, I decided to clean up some wheel bolts. Before:
After brushing with a wire brush:
The door windows looked a bit dirty. So I cleaned them up a bit too.
Razor blade is a good instrument!
Cheers, Walter _________________ '66 Bug with collector plate and '73 412 project |
Posted: Sun Mar 21, 2021 7:03 pm Post subject: Re: Walt's 1973 412 Barn Find |
Oh yes! The rechromer will want suitcases of money. I’m in the middle of that right now myself.
Bill |
Posted: Sun Mar 28, 2021 1:02 pm Post subject: Re: Walt's 1973 412 Barn Find |
More Wheelie stuff on Saturday, but relatively simple. What the wheels looked like before:
What the wheels look like on my work bench at home:
What the tire looks like mounted on the VW 412:
Even the spare tire looks pretty nice.
The VW 412 ready to be towed to Buny's 'N Bugs tomorrow for the engine and transmission removal and rebuild. (I know the spelling of this shop is unconventional. Something about only a certain number of letters fit on the fax machine when they were starting out in business!)
This should give me some more room in the shop for a while!
Hawker Samba Member
Posted: Sun Mar 28, 2021 1:59 pm Post subject: Re: Walt's 1973 412 Barn Find |
Wow! That’s good progress you are making. 👏🏻👏🏻
BR,
Rob |
Posted: Sun Mar 28, 2021 2:20 pm Post subject: Re: Walt's 1973 412 Barn Find |
Hello Rob,
I've got paid friends helping me!
Posted: Sun Mar 28, 2021 2:28 pm Post subject: Re: Walt's 1973 412 Barn Find |
Walter,
Wow! You are moving right along. I have ordered some carpet samples from a company named Sewfine. Looks like they do VW’s only. Their photos of material looked very stock. I will let you know what I get.
Bill |
raygreenwood Samba Member
Posted: Sun Mar 28, 2021 6:46 pm Post subject: Re: Walt's 1973 412 Barn Find |
Walter,
Bill |
I have samples from Sewfine as well. They have nice stuff!
Ray |
19super73 Hardcore Stock Nazi
Joined: October 18, 2007 Posts: 4351 Location: Cité Soleil
