ubercrap Samba Moderator
Joined: July 01, 2004 Posts: 1060 Location: Ridley Park, PA
Posted: Wed Oct 14, 2020 8:18 pm Post subject: L-Jet connector seal/grommet? |
I'm going through my '74 Bosch L-Jet equpped wagon and replacing all the fuel hoses, as it has been sitting for 15 years. I noticed when I unplugged the wiring from an injector, the small rubber seal/grommet inside the plug around the connectors fell apart. As I pulled the rest, I realized another one was missing. Solutions? I don't know how harmful it is, but I don't like that the plug can move up and down at all, plus, nothing good an come of moisture getting in there. _________________ '74 412 wagon
(2) '74 412 2dr. sedan
'73 412 2dr. sedan |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Wed Oct 14, 2020 8:51 pm Post subject: Re: L-Jet connector seal/grommet? |
You can generally buy the plug housings with new gaskets. Many versions. Post some pictures close up so we can see which one it is. In a pinch...very long ago...I have replaced teh gasket with fine bead of silicone from a narrow nozzle. Spread it evenly with a plastic pic...let dry.
Ray |
ratwell Samba Member
Joined: April 26, 2003 Posts: 8717 Location: Victoria, BC
Posted: Fri Oct 16, 2020 2:52 am Post subject: Re: L-Jet connector seal/grommet? |
The Type C locking connectors now have a clear silicone seal inside that replaces the rubber seal as seen in the Type A/B style connectors on L-Jet FI harness connectors.
I've pried this one out partially to show its profile:
_________________ '78 Westfalia CDN
'76 Doublecab
Read the Baywindow FAQ |
Posted: Fri Oct 16, 2020 6:03 am Post subject: Re: L-Jet connector seal/grommet? |
ratwell wrote: |
Thank you for posting this.
While its slightly cleaner that how mine turned out when ai filled in with a fine bead ir silicone.....its pretty much the same effect I got.
I am bettiing looking at the smooth face....that they pumped it in with a needle and parked them on a block of teflon until they set.
Ray |
Posted: Fri Oct 16, 2020 10:20 am Post subject: Re: L-Jet connector seal/grommet? |
Ok, yeah, I found that type of connector for about $5-6 a piece, so easily affordable to get the seals from. _________________ '74 412 wagon
Posted: Fri Oct 16, 2020 11:25 am Post subject: Re: L-Jet connector seal/grommet? |
I inquired about the seal recently and got this reply from a vendor who sells the Type C connectors.
“The original manufacturer does give a part number for that seal, but it appears to be for internal use only as they are not sold anywhere or able to be ordered, probably just used to create the subassembly with the connector shell.” _________________ '78 Westfalia CDN
'76 Doublecab
Posted: Fri Oct 16, 2020 11:39 am Post subject: Re: L-Jet connector seal/grommet? |
ratwell wrote: |
“The original manufacturer does give a part number for that seal, but it appears to be for internal use only as they are not sold anywhere or able to be ordered, probably just used to create the subassembly with the connector shell.” |
Yep...I have never found them "sold" separately...though years ago i could find dealers with a few in their parts box (probably scrounged from other cars)...that they did not have a price for ...so they usually threw them in if I was buying something. Ray |
Posted: Fri Oct 16, 2020 3:05 pm Post subject: Re: L-Jet connector seal/grommet? |
ratwell wrote: |
AMP became Tyco Electronics which is now called TE.
Here’s the AMP Junior Timer part number for future reference if it’s possible to source one:
TE Connectivity
825-383-1
Neoprene seal
https://www.onlinecomponents.com/te-connectivity-amp-brand/8253831-10510982.html
It’s got me thinking about modifying a cookie cutter into a stamp that can cut these out of a sheet of silicone like the photo I posted... |
Yep. I remember when Tyco and AMP merged. The part number index was like 50,000 parts. Finding things back around 1999 was crazy on their web site.
Thanks! Ray |
Posted: Sun Nov 01, 2020 11:52 am Post subject: Re: L-Jet connector seal/grommet? |
Seals are transferred from the new plugs to the ones on the car, so far so good! They feel nice and tight/stable after plugging back onto the injectors. _________________ '74 412 wagon
