I just bought a Ghia that sat for the past 41 years.
Page: Previous  1, 2, 3 ... 12, 13, 14, 15  Next
Braukuche
Braukuche is offline
PostPosted: Tue Mar 30, 2021 4:49 pm    Post subject: Re: I just bought a Ghia that sat for the past 41 years. Reply with quote
xoo00oox wrote:
Braukuche wrote:
I like rebuilt German Solex the best. But they have to be machined, shaft bushings installed, bases checked for flatness...just putting in a new gasket kit seldom works especially with the PICT 34 -3 carbs.
Is there a company or a guy you're happy with to get this done?
https://www.thesamba.com/vw/classifieds/detail.php?id=2435620
Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
Marcdeb
Marcdeb is offline
PostPosted: Tue Mar 30, 2021 5:24 pm    Post subject: Re: I just bought a Ghia that sat for the past 41 years. Reply with quote
Braukuche wrote:
https://www.thesamba.com/vw/classifieds/detail.php?=2435620
I second that. I had Tim (VolkzBitz) rebuild my 34Pict-3 and it came back as good as new.
Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
Vladiiiii
Vladiiiii is offline
PostPosted: Tue Mar 30, 2021 10:57 pm    Post subject: Re: I just bought a Ghia that sat for the past 41 years. Reply with quote
While this may be in theory the best option, please check if they can maybe test it after the rebuild.
I had mine rebuilt in Germany (very reputable guy), and it did not idle at all. Backing off the idle jet slightly, and loctiteing into place, did the trick.
Maybe I'm wrong, but there isn't really a way to check if the idle jet was forced into the thread too much at one point, so that when you snug it up normally, it goes past the "sweet spot" (because the thread is longer) and you get less fuel.
At least a small detail to think about Wink
Vlad
Vlad's 72 Ghia (Once in a Lifetime Restoration topic)
https://www.thesamba.com/vw/forum/viewtopic.php?p=9237746#9237746
mxl556
mxl556 is offline
PostPosted: Wed Mar 31, 2021 5:15 am    Post subject: Re: I just bought a Ghia that sat for the past 41 years. Reply with quote
xoo00oox wrote:
It's an original Solex 30PICt-3 made in W Germany, doesn't seem to have play in the throttle shaft. to me it feels like it's slightly lean. If I give it a slight tap of the gas to richen it with the accelerator pump it seem better for a second. Possibly a richer idle jet or idle air jet? What do you think? Is this typical of today's ethanol fuel causing lean conditions?
My understanding is that the gasoline with ethanol would lean out the mixture and it also has less energy and generally does not work the same way as pure gasoline. Need larger jets to overcome this but better to find E0 gas. You should be able to find ethanol free gas in upstate NY, give it a try and see.
I have a 34 pict3 from Tim (Volkzbitz). I got it about 8 years ago and it has been working perfectly. Probably have 10-15K miles on it at least. It has larger 130/55 jets to better handle E10 gas. I believe Tim's carbs normally come with larger jets to work with E10 gasoline.
Max
xoo00oox
xoo00oox is offline
PostPosted: Wed Mar 31, 2021 5:01 pm    Post subject: Re: I just bought a Ghia that sat for the past 41 years. Reply with quote
Thanks for the tips and link guys, I'll continue working with it and try to get it to smooth out.
Meanwhile, the Squrit is smoothing out very nicely....
xoo00oox
xoo00oox is offline
PostPosted: Mon Apr 12, 2021 11:43 am    Post subject: Re: I just bought a Ghia that sat for the past 41 years. Reply with quote
I enriched the main jet and pilot jet and that really made the nice improvement in the driveability I was hoping for, no more stalling coming to a stop and the hitching feeling when driving with a light throttle is gone. It's so much nicer to drive being smooth.
How do you guys carry bikes with these things? I can very carefully let it ride as a co-pilot with the roof down but if it starts to rain I'll have to make a decision.
For anyone that cares.......
I marked out the water line with a laser level and painted the bottom of the boat red.
And after that cured, flipped it to start work on the top side!
Marcdeb
Marcdeb is offline
PostPosted: Mon Apr 12, 2021 12:41 pm    Post subject: Re: I just bought a Ghia that sat for the past 41 years. Reply with quote
Here's an ad for a Ghia Bike Rack that just got posted.
https://www.thesamba.com/vw/classifieds/detail.php?id=2262467
Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
xoo00oox
xoo00oox is offline
PostPosted: Mon Apr 12, 2021 12:47 pm    Post subject: Re: I just bought a Ghia that sat for the past 41 years. Reply with quote
YOW! I sure as Hell am not putting that thing on my car!
Braukuche
PostPosted: Mon Apr 12, 2021 1:03 pm    Post subject: Re: I just bought a Ghia that sat for the past 41 years. Reply with quote
Other than the piece of masking tape on it that says Ghia I wonder what other proof he has. I’m calling BS on that one.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Marcdeb
Marcdeb is offline
PostPosted: Mon Apr 12, 2021 2:03 pm    Post subject: Re: I just bought a Ghia that sat for the past 41 years. Reply with quote
No, I wouldn't either!!! Laughing But knowing me, if I put a bike on that beautiful upholstery, with my luck, I would damage it for sure.
Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
xoo00oox
xoo00oox is offline
PostPosted: Tue Jun 22, 2021 1:23 pm    Post subject: Re: I just bought a Ghia that sat for the past 41 years. Reply with quote
Greetings Ghia group. Not much activity going on with my Ghia, once I got it fully situated looking and driving nice it just sits and collects dust. I don't think I've driven it in about six weeks.
I did just find that tail light lens I needed at the swap meet at the Terryville CT VW show this past weekend. A near perfect Hella made in Germany for only $10!
There were plenty of Ghia sedans at the show....
And in the Ghia convertible section, there was only one...
-check out tha Schwimmwagen
I would have driven mine there but wanted to camp out at the show Saturday night so drove my '89 Westy instead.
rbsurfguy
Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
rbsurfguy is offline
PostPosted: Tue Jun 22, 2021 3:40 pm    Post subject: Re: I just bought a Ghia that sat for the past 41 years. Reply with quote
All of us East Coast convertible owners need to get up to that show next year to boost the vert representation, Charlie, Marc, you guys up for it???
Haven't seen a Schwimmwagen in a long time, you are a lucky man for sure!
Jeff
1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
xoo00oox
xoo00oox is offline
PostPosted: Tue Jun 22, 2021 3:54 pm    Post subject: Re: I just bought a Ghia that sat for the past 41 years. Reply with quote
Years ago there used to be two Schwimmwagens that would show up to the Litchfield show. I have not seen one in years either, glad that one showed up this year.
Marcdeb
Marcdeb is offline
PostPosted: Tue Jun 22, 2021 8:03 pm    Post subject: Re: I just bought a Ghia that sat for the past 41 years. Reply with quote
Jeff
Not surprising. Way more coupes out there. I'd love to go, but I need to get the darn thing road worthy first, and then gain some confidence with reliability. But possible for sure.
Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
Marcdeb
Marcdeb is offline
PostPosted: Tue Jun 22, 2021 8:07 pm    Post subject: Re: I just bought a Ghia that sat for the past 41 years. Reply with quote
I did just find that tail light lens I needed at the swap meet at the Terryville CT VW show this past weekend. A near perfect Hella made in Germany for only $10.
Hi Andrew,
If you need a reason for a drive, head on over here to Vermont. I'll help you put some miles on that beautiful car! Laughing Laughing
Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
xoo00oox
xoo00oox is offline
PostPosted: Wed Jun 23, 2021 6:50 am    Post subject: Re: I just bought a Ghia that sat for the past 41 years. Reply with quote
Hi Andrew,
I'm considering going to the Wolfsgart show in Burlington at the end of July.
https://wolfsgart.com/aboutus/
Rome
Rome is offline
PostPosted: Thu Jun 24, 2021 4:16 am    Post subject: Re: I just bought a Ghia that sat for the past 41 years. Reply with quote
You caught me in this photo; I'm at far right with the checkered shirt and the straw hat, speaking with the Ghia's owner rbfara who has his back to you. Nuts that we did not realize who we are. In this group, not seen on the right, was Dennis from v-dubstore in eastern PA who is my VW cylinder head and case machining specialist. I asked the event DJ whom I've known for over 20 years if there was a Samba group photo, which in past years (long ago) used to be taken right at the DJ bus- and there seemed not to be one this year. I missed meeting several other Samba people at the event such as Mustie1 and 67ctbug. Maybe next year your Ghia will be displayed in this class!
Marcdeb
Marcdeb is offline
PostPosted: Thu Jun 24, 2021 4:53 am    Post subject: Re: I just bought a Ghia that sat for the past 41 years. Reply with quote
That sounds like a cool event. I've heard of it but never checked it out. The same weekend, there is the Volks-Fair in Deerfield NH.
https://the-bug-club.webs.com/volks-fair-2021
Unfortunately I will be in Columbus Georgia for my Grandson's baptism. Bad timing! Sad
Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
xoo00oox
xoo00oox is offline
PostPosted: Thu Jun 24, 2021 6:11 am    Post subject: Re: I just bought a Ghia that sat for the past 41 years. Reply with quote
Cool! I've know JimmyD the DJ for years, he was hanging out with our group around the campfire Saturday night. What a great show it was this year!
xoo00oox
xoo00oox is offline
PostPosted: Mon Aug 02, 2021 10:30 am    Post subject: Re: I just bought a Ghia that sat for the past 41 years. Reply with quote
Well here it is August already and I still don't think I've even put more than a couple hundred miles on my Ghia.
I did come across this beauty over the weekend at the Wolfsgart show in Burlington....
Page 13 of 15
