Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
Posted: Sat Oct 17, 2020 8:59 am Post subject: PSA: Defective Headlight Relays |
Hey Guys:
FYI there's a big batch of defective headlight relays being sold at parts stores right now. After acquiring 3 of them and pulling my hair out I tried an old Meyle and it worked fine.
These relays are being sold by Napa, Advance and probably many others. They all appear to be made on the same assembly line and boxed according to the retailer. None work correctly, low beams work but there's no high beams. I'm strong with electrical and these SOBs really had me wondering about my abilities until I tried a used one and it worked fine.
These relays fit almost every VW made between 67-79 but I'm posting here as that's the vehicle I was working on. I don't know if Everett wants to crosspost this, but at least I'm letting people know.
Use the German Meyle one, it works!
PS Napa refunded no problem, Advance told me no returns on electrical items, period. Thirty bucks out the window, and it was only $20 at Napa.
PSS: If you want to use one of these, connect power to terminal 30 (which is not used in this circuit, oddly) and it will work, and you'll have flash-to-pass with the key on also.
_________________ '66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263 |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Sat Oct 17, 2020 9:55 am Post subject: Re: PSA: Defective Headlight Relays |
Did you, perchance, determine exactly why they don't work? (Might as well get something for that lost $30...) _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Sat Oct 17, 2020 10:04 am Post subject: Re: PSA: Defective Headlight Relays |
Send them to Telford. He will figure the problem out _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Sat Oct 17, 2020 10:13 am Post subject: Re: PSA: Defective Headlight Relays |
It’s probably the old problem of having to add a jumper wire from terminal
30 to terminal 56
This has been going on For years .
Please do a search for soldering or just using connectors for your project _________________ V.W.owner since 1967 |
SGKent Samba Member
Posted: Sat Oct 17, 2020 10:47 am Post subject: Re: PSA: Defective Headlight Relays |
old DKP driver wrote: |
30 to terminal 56
Please do a search for soldering or just using connectors for your project |
yes - this is all it is. There was a thread discussing the jumper just a couple days ago, 17 posts down from this, https://www.thesamba.com/vw/forum/viewtopic.php?t=744440 . We have 40 - 50 year old cars. Some things have to be adapted. I believe that the old relays had an internal jumper that was added to make them work. The newer ones lack it. That said, someone out there probably has a NOS one from the 1970's for $100 - $150. Jumper one from NAPA, or $100 - $150 NOS, buyers choice. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
