63 turn signal switch turning on steering column
ripperfarms
ripperfarms is offline
PostPosted: Sun Oct 18, 2020 7:16 pm    Post subject: 63 turn signal switch turning on steering column Reply with quote
I have a 63 sedan and the turn signal switch is turning on the steering column.
I tried to find some youtube videos on how to fix that but to no avail.
It is in the shop right now for some new spring plates but when I get it back I want to fix the turn signals.
They will work but the whole turn signal column (housing) and the lever slip around the steering column, maybe a 1/8 turn, before turning the signal on.
Is there some clamp inside of there or what should keep it from sliding around the steering column.
Thanks for any help ahead of time....Dave in Illinois....the land of no old VWs.
Sharp64
Sharp64 is offline
PostPosted: Sun Oct 18, 2020 7:37 pm    Post subject: Re: 63 turn signal switch turning on steering column Reply with quote
There should be a slotted screw that tightens and holds the assembly in place.
1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine
KTPhil Premium Member
KTPhil is offline
PostPosted: Sun Oct 18, 2020 8:17 pm    Post subject: Re: 63 turn signal switch turning on steering column Reply with quote
Once you confirm the screw:
1) Check for center on the steering box:
2) Then check for centering of the steering wheel on the column. If you skip this you can break things.
3) Set the gap between theswitch and steering wheel:
mukluk
mukluk is offline
PostPosted: Sun Oct 18, 2020 8:23 pm    Post subject: Re: 63 turn signal switch turning on steering column Reply with quote
The screw is located as shown below, it threads into a clamping plate which is forced against the column tube to hold the switch assembly in place.
ripperfarms
PostPosted: Mon Oct 19, 2020 6:27 am    Post subject: Re: 63 turn signal switch turning on steering column Reply with quote
I think this answer will work for me ...... as soon as I get the bug back I will fix it.
I felt around there before but did not feel it so this time I will look closer.
Thanks to everyone for their help
