Da Bug Man Samba Member
Joined: October 27, 2019 Posts: 1 Location: Ft Myers Fl
Posted: Wed Oct 21, 2020 7:02 am Post subject: Triangle shape drain hole in a bullet turn signal? |
Can anyone comment on the meaning of a triangle shape drain hole in a bullet turn signal? I have 2 complete assys, appear all original, even has bulbs inside. Original screw on wire terminals.
Thanks for the help. |
56Cabrio Samba Member
Joined: May 22, 2008 Posts: 1899 Location: San Fernando Valley, CA
Posted: Wed Oct 21, 2020 8:17 am Post subject: Re: Triangle shape drain hole in a bullet turn signal? |
Daves Bug Shop wrote: |
Wrong thread but here you go.
_________________ F#CK CANCER
Make a donation
1956 Rag Top owned since 1988
1963 Hard Top
RIP Dad 4/20/1951 - 2/4/2023 |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Posted: Wed Oct 21, 2020 1:10 pm Post subject: Re: Triangle shape drain hole in a bullet turn signal? |
I have always understood it to be for water drainage _________________ How to Post Photos
splitjunkie Samba Member
Posted: Wed Oct 21, 2020 2:10 pm Post subject: Re: Triangle shape drain hole in a bullet turn signal? |
EverettB wrote: |
I have always understood it to be for water drainage |
Yep. _________________ Chris
Yustrn JHC Controla
Joined: August 01, 2000 Posts: 5478 Location: Ovaland, CA
Posted: Wed Oct 21, 2020 3:51 pm Post subject: Re: Triangle shape drain hole in a bullet turn signal? |
Bugs had circles, buses had triangles (some early buses 55/56 buses came with circles too)...they fit but they aren't accurate. |
Loren Samba Member
Posted: Wed Oct 21, 2020 4:03 pm Post subject: Re: Triangle shape drain hole in a bullet turn signal? |
VW used the round drain holes first and discovered that they didn't drain very well so they changed them to triangular holes. The triangular holes break the water tension and let the water drain much better than the round holes. I believe that bug, bus and Ghia covers all had round drain holes initially until VW discovered they didn't drain very well and made the change. |
finster Samba Member
Joined: May 26, 2012 Posts: 7935 Location: north o' the border
Posted: Thu Oct 22, 2020 4:47 am Post subject: Re: Triangle shape drain hole in a bullet turn signal? |
there's me thinking it was a secret message from the illuminati... _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
santagary Samba Member
Joined: May 26, 2019 Posts: 12 Location: PAGOSA SPRINGS, COLORADO
Posted: Thu Oct 22, 2020 5:14 am Post subject: Re: Triangle shape drain hole in a bullet turn signal? |
Loren wrote: |
Now that makes perfect sense! |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Tue Oct 27, 2020 2:35 pm Post subject: Re: Triangle shape drain hole in a bullet turn signal? |
My unmolested, un-restored June 1955 Oval Sunroof has her original "round" bullet water drain holes... FWIW...
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
1958ghia Samba Member
Posted: Wed Oct 28, 2020 8:09 am Post subject: Re: Triangle shape drain hole in a bullet turn signal? |
Yustrn wrote: |
Also early Ghias had them, but since they are mounted rotated 90 degrees, the water drain hole 'triangle' is on the long edge of the trim piece. Oh and they are also chrome/stainless/aluminum on Ghias too but basically the same piece. Up '58-early '59 vintage that is... |
