Lessis More Samba Member
Posted: Fri Oct 23, 2020 1:59 am Post subject: Tips on storing bug body outside in wet climate |
Maybe a silly question but I will be taking the body off my 66 bug to work on the chassis this winter.
The body must be outside in a wet sometimes snowy environment.
The body will be on wood braces elevated off the grass.
Could be out there for 6 months....... or longer if I know me.
Any tips would be greatly appreciated! |
oprn Samba Member
Joined: November 13, 2016 Posts: 12744 Location: Western Canada
Posted: Fri Oct 23, 2020 4:43 am Post subject: Re: Tips on storing bug body outside in wet climate |
If the body is complete and weather tight with all widows and doors in place I see no problem. The only thing I would suggest is keep it high enough to allow good air circulation and watch for rodents. Maybe a bit of mouse poison placed in the heater ducts? |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Fri Oct 23, 2020 1:04 pm Post subject: Re: Tips on storing bug body outside in wet climate |
Cover it with a good quality tarp. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Fri Oct 23, 2020 1:17 pm Post subject: Re: Tips on storing bug body outside in wet climate |
vwracerdave wrote: |
Cover it with a good quality tarp. |
& use some 2X4 wood blocks on the roof/fenders to keep the tarp from touching the body. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Sat Oct 24, 2020 1:38 am Post subject: Re: Tips on storing bug body outside in wet climate |
Thanks all!
I'll be getting a breathable car cover as well.... Nothing fancy but should do the trick for a few months.
By the way.. I just discovered a mouse living in my headliner. |
Abscate Samba Member
Posted: Sat Oct 24, 2020 5:19 am Post subject: Re: Tips on storing bug body outside in wet climate |
What kind of mouse? Or a Norway rat? _________________ .ssS! |
oprn Samba Member
Posted: Sat Oct 24, 2020 5:27 am Post subject: Re: Tips on storing bug body outside in wet climate |
Funny thing - in another storage thread I suggested a tarp and got jumped all over. I didn't on this one and it is recommended!
Opinions change.
A tarp does work but it must be in a wind free spot AND tightened up to stop it from rubbing. Car covers with a soft backing are better. |
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2666 Location: Long Island, NY
Posted: Sat Oct 24, 2020 6:34 am Post subject: Re: Tips on storing bug body outside in wet climate |
There should be a way to prevent moisture from collecting on the inside of the cover. Not as much of problem in cold weather as in hot, but worth mentioning. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
johnnyvw164 Samba Member
Joined: July 27, 2020 Posts: 573 Location: South of Raleigh
Posted: Sat Oct 24, 2020 7:07 am Post subject: Re: Tips on storing bug body outside in wet climate |
Maybe consider cutting some wood to replicate the chassis and bolt it up, so that the body is sealed? Otherwise anything with legs can crawl into it |
Splitdog Samba Split Personality
Joined: February 16, 2004 Posts: 4125 Location: Planet VW
Posted: Sat Oct 24, 2020 9:05 am Post subject: Re: Tips on storing bug body outside in wet climate |
Any car covered outside in the wet weather will eventually collect mold and such on the inside. _________________ CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker |
my59 Samba Member
Joined: August 13, 2003 Posts: 3793 Location: connecting the dots
Posted: Sat Oct 24, 2020 9:14 am Post subject: Re: Tips on storing bug body outside in wet climate |
Folks here store boats outside in the winter by making pvc frames over the boat and covering with a tarp so the tarp sheds water.
The key thing is having a gravel pad, the boat is off the ground, and the frame is longer, wider than the boat. Tarp is not on the boat itself. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3333 Location: 802 The Pointless Forrest
Posted: Sat Oct 24, 2020 11:19 am Post subject: Re: Tips on storing bug body outside in wet climate |
Shrink wrap. _________________ "Albatross"! |
far rider Samba Member
Joined: August 30, 2005 Posts: 773 Location: Rutland, VT
Posted: Mon Oct 26, 2020 5:38 pm Post subject: Re: Tips on storing bug body outside in wet climate |
I would put down heavy plastic on the ground and then plywood over the plastic. Prevent moisture from coming out of the ground. If the cover you put on is not breathable you’re better off leaving it open. Not sure but you might be better off leaving it uncovered. My 2 cents. Good luck _________________ 67 zenith blue sunroof
Contentment; when what you have is what you want. |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Mon Oct 26, 2020 6:44 pm Post subject: Re: Tips on storing bug body outside in wet climate |
agreed 100% not even a year into my HF tarps and they started flaking until they were no more. _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Mon Oct 26, 2020 8:07 pm Post subject: Re: Tips on storing bug body outside in wet climate |
Far rider is correct. If there's any factory paint on the roof it is better off shedding water than having a tarp slowly rub all your paint off. Tarps will trap water if in contact at all. When I hated myself and my '74 Thing had to live outdoors for 2 years I used PVC pipe to elevate a cover above the paint. Water still got through- and the car drained just fine. but no damage to the paint occurred- and no moss, mice or mold. _________________
EverettB wrote: |
FU#5 |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Tue Oct 27, 2020 5:13 am Post subject: Re: Tips on storing bug body outside in wet climate |
I have just a little experience storing things in damp environments. It needs to be at least a couple of feet off the ground so air can easily pass under it. If the windows are in it you really shouldn't need to tarp it.
_________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1227 Location: Eerie PA
Posted: Thu Oct 29, 2020 12:40 pm Post subject: Re: Tips on storing bug body outside in wet climate |
Build a frame for the tarp, like a makeshift shed roof like mentioned here. Then spray the body down with a water displacing long term rust proofing coating. Don't know what you have where you are from but WD40 makes one that works well. Fluid Film into the heater channels and inside of doors and anywhere else you can get the straw to go in and coat it real well. If you have good paint on the car wax it with a ceramic hybrid style wax, Mequires makes a good one.
If your window rubbers are bad and leaking duct tape them over to seal them until you are ready to replace them. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 11 Window (Zelda)
1965 13 Window (Lucas)
1957 Oval ragtop
1988 Cabriolet VR6 conversion
Plus a lot of other rusty junk |
Manfred58sc Samba Member
Posted: Fri Oct 30, 2020 7:26 am Post subject: Re: Tips on storing bug body outside in wet climate |
No tarp, apply WAXOYL to the exposed surfaces, good for about 8 mo. Its a marine grade protectant . Cheap dryer sheets for the mice. _________________ Fat chick owner/operator |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Fri Oct 30, 2020 8:41 am Post subject: Re: Tips on storing bug body outside in wet climate |
...and a cat. |
Posted: Fri Oct 30, 2020 2:51 pm Post subject: Re: Tips on storing bug body outside in wet climate |
Shrink wrap like they do on boats. _________________ "Albatross"! |
