Stockholm VW Samba Member
Posted: Sat Oct 24, 2020 3:15 pm Post subject: Preheat hose? Rear seat strap? Questions, questions, questions. |
I’m back with more questions.
1. What tins do I remove to reattach the preheating hose on my ‘66 Bug with a 1600 cc engine. See pic of what I need to get to.
2. Check out my baggage strap. Looks like it’s broken off. What do I have here and if it’s complete, how does it attach?
Thanks in advance! 👍 |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Sat Oct 24, 2020 3:39 pm Post subject: Re: Preheat hose? Rear seat strap? Questions, questions, questions. |
I can only answer #1
Do you mean both pieces?
The little rectangular tin should slip in there and then you screw it on from the top side.
The pre-heat tube goes over the exhaust and under the exhaust nut.
If your engine is complete right now, remove the lower exhaust mounting nut, slip the tube on, then re-install the nut.
Not the most perfect pic of the nut but
_________________ How to Post Photos
Helfen Samba Member
Joined: January 19, 2009 Posts: 3450 Location: Vulcania
Posted: Sat Oct 24, 2020 4:23 pm Post subject: Re: Preheat hose? Rear seat strap? Questions, questions, questions. |
I'll answer the 2nd question with a question. What do you do when your belt in your pants breaks? answer; buy another one.
Buy a new replacement rear seat retaining strap. |
KTPhil Samba Member
Posted: Sat Oct 24, 2020 4:45 pm Post subject: Re: Preheat hose? Rear seat strap? Questions, questions, questions. |
I think there was a thread about how to attach a new strap. It's not self-evident at first look, so it's worth searching the forum for the answer, maybe with photos. |
Big Bull Shooter Samba Member
Joined: April 28, 2018 Posts: 460 Location: Canadian Rockies
Posted: Sat Oct 24, 2020 6:55 pm Post subject: Re: Preheat hose? Rear seat strap? Questions, questions, questions. |
Here's some pics that I had in my gallery of that strap from my 69.
I've played around with the buckle, so I'm not sure if it is oriented correctly.
I believe the strap is screwed to the metal seat back frame at the top of the seat back. I would go out and check, but it's -15 C right now!
Helfen Samba Member
Posted: Sat Oct 24, 2020 7:38 pm Post subject: Re: Preheat hose? Rear seat strap? Questions, questions, questions. |
Not sure what the change is, but starting in 1965 and ending in 1977-8 the strap is different. |
TheRide Samba Member
Joined: May 06, 2019 Posts: 293 Location: North Carolina
Posted: Sat Oct 24, 2020 8:05 pm Post subject: Re: Preheat hose? Rear seat strap? Questions, questions, questions. |
Stockholm VW wrote: |
1. What tins do I remove to reattach the preheating hose on my ‘66 Bug with a 1600 cc engine. See pic of what I need to get to. |
You are saying that you are going to install the piece shown? remove the rear tin aka breast plate. |
