Nickel_Nackel Samba Member
Joined: February 07, 2018 Posts: 130 Location: Bellingahm WA
Posted: Sun Oct 25, 2020 1:53 pm Post subject: Replacing ignition control module |
Do I just slap this puppy on my van like this and call it good?
I guess I need to cut in more screw holes cus this doesn’t line up with the old ones
_________________ 1985 1.9L Potato |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 13780 Location: Palm Beach County, Florida
Posted: Sun Oct 25, 2020 2:25 pm Post subject: Re: Replacing ignition control module |
I would try it before you mount it. The original is a 2 part with an aluminum heat sink that is attached to the van and the module bolts to the heat sink.
If it works see if you can use one of the original holes. _________________ 1982 Vanagon Camper with ALH TDI.
1990 Vanagon Camper Syncro.
In Car https://youtu.be/5hbfdUJR88Q |
Also is running my van at 25 degrees 2” from the U mark okay for it? _________________ 1985 1.9L Potato |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9012 Location: Mt Lemmon, AZ
Posted: Sun Oct 25, 2020 3:23 pm Post subject: Re: Replacing ignition control module |
Can you reuse your original heatsink in addition to the components you show in the photo? Yeah, that would give you two heat sinks but might allow the original holes to be used. |
Posted: Sun Oct 25, 2020 3:26 pm Post subject: Re: Replacing ignition control module |
Nickel_Nackel wrote: |
Also is running my van at 25 degrees 2” from the U mark okay for it? |
I think 2" is more than 25° -- perhaps about 35°.
But yeah, should be okay - I actually run a little more advance than that. |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 2207 Location: Bemidji, MN
Posted: Sun Oct 25, 2020 3:50 pm Post subject: Re: Replacing ignition control module |
so in the vintage BMW airhead world, they use the same ignition module. there have been numerous instances where these have had intermittent failures due to a lack of heat sink grease between the module and heat sink. it'll probably work just fine, but if you want a belt and suspenders approach, separate the two and apply some heat sink compound. it has made a difference in the BMW motorcycle world. _________________ -dan
87 Westy, stock 2.1 w/ 4 spd ratty but reliable
89 Westy, stock 2.1 w/ 4 spd, fate unknown |
