dhaavers Samba Member
Joined: March 19, 2010 Posts: 7733 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Tue Oct 27, 2020 7:51 pm Post subject: Re: Good muffler for CDH or Webasto heaters? |
^^^ Works for me...barely noticeable outside the van...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
pdm777 Samba Member
Joined: August 06, 2012 Posts: 348 Location: Clovis, CA
Posted: Wed Oct 28, 2020 12:19 pm Post subject: Re: Good muffler for CDH or Webasto heaters? |
two for me.
_________________ 1990 Westy Full Camper |
fxr Samba Member
Joined: December 07, 2014 Posts: 2300 Location: Bay area CA
Posted: Wed Oct 28, 2020 12:29 pm Post subject: Re: Good muffler for CDH or Webasto heaters? |
pdm777 wrote: |
two for me.
Do ensure when they're finally fitted that the drain holes on each point vertically down... _________________ Jim Crowther
Vespa GTS 300 |
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Wed Oct 28, 2020 1:20 pm Post subject: Re: Good muffler for CDH or Webasto heaters? |
Dave, I have a genuine Espar muffler, much better metal etc than the CDH version, installed. It is coupled with a silicone exhaust hose which decouples a lot of harmonic noise. The heater exhaust thru a Teflon sleeve and a 90⁰ bend. Very quite. IMHO it should be standard. BTW the muffler is mounted via Teflon bushings. Looks very German/factory.
As you well know I prefer once and done! _________________ Schau in das Buch |
?Waldo? Samba Member
Posted: Wed Oct 28, 2020 4:56 pm Post subject: Re: Good muffler for CDH or Webasto heaters? |
pdm777 wrote: |
two for me.
If you watch the video that Sodo posted earlier, the author of the video mentions that the mufflers should always be installed so that they are vertical with the drain hole at the bottom of each muffler. Your picture shows the two drain holes pointing in opposite directions with neither of them vertical. |
pdm777 Samba Member
Posted: Wed Oct 28, 2020 5:49 pm Post subject: Re: Good muffler for CDH or Webasto heaters? |
Yes, Yes, Yes, I know.
I want them horizontal for max clearance.
The very short pipe minimizes back pressure,
and muffles the 'jet exhaust' sound very well.
They are supposedly stainless.
'Chineeze stainless' ha ha.
Every time I crank the heater up, any moisture will
be driven out. I doubt they will 'rust' from the inside out.
I live in a dry state. Our vehicles simply don't rust.
Plain steel mufflers don't corrode in this environment.
If these mufflers last five years, I am happy.
If my cheapo CDH is still kickin in 5 years, I'll be surprised.
There will be better solutions in a few years. or not.
Do yours whistle as you drive with the drain holes pointing down??? _________________ 1990 Westy Full Camper |
