anthracitedub Samba Member
Posted: Mon Oct 26, 2020 7:15 am Post subject: Whole house water filter system |
Just thought I’d check here to see if anyone else has input regarding adding a filter system to the incoming water supply of their home.
I live just outside city limits and have well water. I have a water softener and overall my water is pretty good. I have a PUR filter on my kitchen sink for drinking. I also have a water cooler and we refill our 5 gallon jugs at a local market. I’m the only one that drinks the tap water in the house.... tastes fine to me...also use it for my coffee.
I travel for work and get to use water from different states often... and when doing so I feel like some of the other water leaves me feeling cleaner after showers and in some cases it tastes better.
My water at home with out the softener is hard and does have a little rust/metal tinge to it.... the faucets outside the house have rust stains below them and the toilet tanks have some rust staining. So I know my water kinda sucks and needs help.
I’ve decided to look into filter systems that I can plumb in myself and I am blown away at all the different types and pricing. I’ve just begun this journey and I also don’t mind spending money on this improvement... but I don’t know where to start... thought I’d ask on here to see if anyone else has had a similar experience and found a decent system. |
kingkarmann Samba Member
Posted: Mon Oct 26, 2020 8:13 am Post subject: Re: Whole house water filter system |
We purchased a small reverse osmosis system from Kinetico. It has worked very well for us.
The kinetico softener has a prefilter to help with iron.
We have well water so some sort of softener and filtration is necessary.
I chose the kinetico system simply because it operates "on demand" and doesn't require electricity or need to cycle at a preset time. _________________ "Depression is a malfunction of the instrument we use to determine reality.”
Mike Gerson
What is your "Bespoke Reality"? |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Mon Oct 26, 2020 9:43 am Post subject: Re: Whole house water filter system |
My home with a deep drilled well is 20 years old this year....
I installed a whole house filter ... the same time I installed a water softener .. which was 18 years ago.
Filter is a Whirlpool single stage with a clear reservoir/bowl.
Its amazing how much sediment it collects. Mostly fine particles. I use the fiberglass filters.
I try to clean and replace the filter every 6 months... I have one cartridge clean and ready to swap out . I reuse them after washing them out with bleach.
I think its a great investment for home well water systems.
My home has CPVC and only has some slight issues with calcium deposits getting through to mixing valves and faucets.
Granted my parents home had copper up until a few years ago... always had typical copper staining.. They switched to Pex and while the staining left.... the bronze pex couplings didnt make it 3 years before the well water ate them alive even with a filter and softener...
IMO have your water tested and evaluate what you really need..
You may find you need a whole house and some satellite filters.
I now just want a damn hot water recirculation system...
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
Relyt Samba Member
Posted: Mon Oct 26, 2020 10:52 am Post subject: Re: Whole house water filter system |
I also live just outside of town, the city limits start on the other side of my driveway, and am on a well.
I would suggest sending out a water sample to be tested, that will show how hard your water really is and what is actually in it. This should be done annually regardless.
Hard water isn’t necessarily bad. It’s usually perfectly fine for drinking. The downsides, as you probably know, are that it can be harder to clean as soaps don’t work as well in hard water, it can cause stains but really the issue is sediment deposits in your water heater and wash machine etc., and the taste.
The 3 main ways of filtering, that I’m aware of, is:
A house filter, it’s just a big filter, better then nothing but not super great. I chose not to do this as it didn’t seem that effective.
Water softener, this requires a device to be plumbed in along with a way to drain out its waste. This uses a type of salt and essentially swaps the salt out with minerals in the water, the harder the water the more salt that is used. I chose not to do this as I didn’t want to be putting that much salt in our water.
Reverse osmosis, this basically removes everything but the water. For a whole house you need the reverse osmosis machine, giant tanks, and a way to drain the waste water. This is by far the most effective but also the most expensive and labor intensive, and some argue that removing all minerals is bad for us, I’ve seen studies showing that it can leach minerals essential for our teeth and bones if used too much.
What I ended up doing, since our water came back drinkable but with trace lead (old house and fixtures that I will be replacing) and reportable nitrate levels (not enough for retesting or concern but enough for the health department to take note, probably due to the mounds of horse poop and not pumping the septic for 10+ years, both of which I have corrected), is I got a small under the sink reverse osmosis system for our drinking/cooking water. This is the system I got:
https://www.amazon.com/APEC-Alkaline-Drinking-Water-ROES-PH75/dp/B00NWZ1RCK?
I liked this one because after it filters it puts some minerals into the water.
In the spring I will check the water heater and everything for sediment to reassess if I want a water softener or house filter. _________________ 69 Beetle - Daily driver
1600 SP (unknown history)
30 PICT 1 w/power circuit (Volkzbitz)
205T (Bill) |
KTPhil Samba Member
Posted: Mon Oct 26, 2020 11:08 am Post subject: Re: Whole house water filter system |
Start with a water test, so you know what you are trying to remove or balance. Otherwise you are shooting blind. There can be many elements in well water that may have no taste or smell.
Michigan? Not Flint, I hope... |
Zundfolge1432 Samba Member
Posted: Mon Oct 26, 2020 11:59 am Post subject: Re: Whole house water filter system |
I was talking to a buddy from work about whole house filters. He did it when House was built and primarily to make beer. I helped him run off 20 gallons at a time and it was great, that’s reason enough to invest in filtration😀 probably already mentioned but filtered water is easier on everything washers,toilets,water heaters etc. but the beer was reason enough. |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3331 Location: 802 The Pointless Forrest
Posted: Mon Oct 26, 2020 1:41 pm Post subject: Re: Whole house water filter system |
Look into charcoal filtration. _________________ "Albatross"! |
Posted: Mon Oct 26, 2020 3:11 pm Post subject: Re: Whole house water filter system |
Alright... good info to help kick start this project. I’m certainly gonna do the water test first. From there I can source a type of system, hopefully something simple and affordable that covers my needs. |
Abscate Samba Member
Posted: Mon Oct 26, 2020 6:11 pm Post subject: Re: Whole house water filter system |
You can’t leach your bones out drinking DI or distilled water. _________________ .ssS! |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Tue Oct 27, 2020 8:36 am Post subject: Re: Whole house water filter system |
Volkswagenut "spoke" for me as well- a good, inline filter, changed every six months works well- on my well water.
Well water, if left unfiltered will wear out your softener faster. Once you start filtering and you clean your shower heads it will feel like you doubled you pressure. _________________
EverettB wrote: |
FU#5 |
Posted: Tue Oct 27, 2020 10:24 am Post subject: Re: Whole house water filter system |
I may just go ahead and get an in-line filter to put in for the time being... they’re affordable and easy to splice in. Our water really doesn’t seem too bad, I just want it to be the best it can be with in reason. Our water softener works and I often hear it regenerating at night, but I only have to put salt in it a few times a year... it doesn’t seem to use a lot. My old house had the exact same unit and I would have to add a bag every month... this house maybe 4 bags a year. It is working but seems strange that I barely use salt. I can put it in bypass mode and the water tastes bad... with it on the water tastes good, it’s always ice cold and clear. I’m also thinking that some of the issue is with my hot water heater... the water from there seems to have a little metallic odor to it... probably time to replace that unit as well, it’s gotta be quite old. My house was built in 96 and it possibly could be the original. |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Wed Oct 28, 2020 9:32 am Post subject: Re: Whole house water filter system |
Relyt wrote: |
Many years ago I asked our plumbing contractor about water softeners and salt input. He said it was a very minimal amount of sodium added to the softened water.
Here's a good explanation... https://www.water-rightgroup.com/blog/why-does-my-water-softener-need-salt/
In my experience, softened water tastes terrible. But I suppose that depends on how bad the hard water tastes. I grew up on well water, but now have very good city water here in the mountains of Idaho. No softener required. _________________ nothing |
oprn Samba Member
Joined: November 13, 2016 Posts: 12740 Location: Western Canada
Posted: Wed Oct 28, 2020 4:14 pm Post subject: Re: Whole house water filter system |
Our well started to produce sand. Just a bit at first but it got worse so I put a filter in the line into the house. That only took out the course stuff so I found a centrifugal pre filter to add. Eventually the sand volume got so bad that it was not sufficient either. We had to drill a new well.
Now the filter does very little. I check it every 3 months so and there is virtually nothing in it. Both wells are very alkaline though. Too high in salts for human consumption so I installed a reverse osmosis filter for just the drinking and cooking water. It’s working well and I calculated the payback time at about a year as opposed to buying bottled water.
Treating all the water this way is just not economical. |
Posted: Wed Oct 28, 2020 4:37 pm Post subject: Re: Whole house water filter system |
cdennisg wrote: |
In my experience, softened water tastes terrible |
Agree on that.... when my taste was better (loss from occupational accident) ... the cold NC well water was the absolute best ... My grandparents used to bottle it to take back to Jersey.....
I have one house spigot plumbed specifically raw for that reason... ..plus one at the well head..
A group of college girls stopped by one Sunday.... they were doing a water and septic survey and test.. .they asked if Id like to contribute and wanted it raw right out of the head ...
Water test came back clean and clear..
Had my septic tank pumped for the first time ever this year (20 years)... all good.. I even pulled the effluent filter ... was pretty clear. I just wanted to get an idea where it all stood after the time and use.
Well water is natures filtered water......
... with rural septic tanks... kinda makes ya think....
On that note... plant a garden over your drain field .. and you will have hulk size vegetables _________________ aka Ken {o\!/o}
Usually and often edited |
oprn Samba Member
Posted: Thu Oct 29, 2020 8:06 am Post subject: Re: Whole house water filter system |
Not true in our case. The affluent from our septic system is deadly to plant life due to the alkalinity in the well water.
I had the sewer outlet to the field freeze off one winter so I dropped a sump pump into the septic tank until spring. There was a dead strip across the yard that took 3 years to grow grass again and the trees on that corner did not make it. The same thing happens when we water the garden from the well.
So nature’s filter in is not perfect in all cases. |
Posted: Fri Oct 30, 2020 4:59 pm Post subject: Re: Whole house water filter system |
I actually have city sewer and as of last year there is a city water line they installed for miles down the highway heading north to a brand new giant hospital they finally opened just a few weeks ago. I don’t know if there are plans to branch out to our subdivision or not... but we do have fire hydrants installed at the entrance of the sub. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Fri Oct 30, 2020 5:48 pm Post subject: Re: Whole house water filter system |
I'm on my own well here.
I use an undercounter charcoal filter to a separate spigot for drinking, cooking, making ice.
Since we had sediment clogging the washing machine inlet screen, I put a small sediment filter inline for that.
When we clogged a couple of toilet fill valves, I bought inline toilet fill filter screens for those (yes, they do exist) to save on replacing toilet fill valves.
I've had to clean the screen in a shower head once, and sink faucet aerators occasionally. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3853 Location: San Jose, CA
Posted: Mon Nov 02, 2020 7:56 pm Post subject: Re: Whole house water filter system |
Late to the show but I just noticed this post (actually I've been distracted on other sites now that I got a OneWheel ).
Yes, I installed a whole-house filter on the incoming 1" service line to the house when I repiped the whole place (yes, I repiped it myself, and copper is easy to sweat). I'm on municipal water.
It's one of the best things I could've done, I love it. I drink the tap water and it tastes good (or DOESN'T taste?). It doesn't stink either. It's the big canister that takes the filters that are about 5" in diameter and roughly 12" tall. The filters I use have a charcoal component, and when I go to replace the filter every 3 or 4 months, the white outer element wrap is discolored a disgusting greenish-brown.
But here are a couple of UN-scientific indicators that tell me it's doing an excellent job:
1) I'm still on the same chrome-plated brass shower head that I installed new when I repiped 13 years ago, with nothing more than a scant amount of calcium deposited around the outside perimeter, and the spray adjustment gizmo in it still works perfectly (while all the neighbors complain of crusted fixtures within a couple years), and
2) One way I determine if excess minerals are in the water is by adding about 1 cup of water to a sauce pot and boil it dry, down to nothing...and see what kind of crusty residue is left behind in the pot. In my case, nearly nothing, a very slight white haze that you can barely see, and wipes away with a fingertip.
Oh, one last piece of evidence, no crust in the coffee maker
I think it's better for ALL of the fixtures, and the water heater too, and pipes, etc. I've had zero problems or leaks from my faucets since then, either.
So there's my experience with it. Now where's my OneWheel?! |
oprn Samba Member
Posted: Tue Nov 03, 2020 6:46 am Post subject: Re: Whole house water filter system |
anthracitedub wrote: |
Three years ago the county put in a water line from a city 2 hours away to service the towns around here. We were all offered a hook up if we paid to have the line trenched in. It came past 4 miles west of us and the cost for us would have been $30,000 to get it to our property line. Then there would have been the cost of trenching it into the house and a monthly bill for water use for ever after.
I said "No thanks!" A new well was cheaper and no monthly bill arrives in the mail! None of our neighbors took them up on it either. |
Posted: Tue Nov 03, 2020 2:19 pm Post subject: Re: Whole house water filter system |
Spring in front of house, when dug 25 yrs ago, found an old oak pipe used to water cattle, never runs dry, others come during drought to water their live stock, stick a pipe ten feet in the ground here , get all the water you need. _________________ "Albatross"! |
