airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Mon Oct 26, 2020 10:29 pm Post subject: T1 fan blade sharpening - effects |
Hi Folks,
Anybody here ever run a Type 1 fan blade with sharpened blades?
I’m interested mostly in noise reduction; flow effects would be interesting too.
See you on the road,
www.airschooled.com |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Tue Oct 27, 2020 4:59 am Post subject: Re: T1 fan blade sharpening - effects |
Me interested azwell interested me _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
PuddleRainbow Samba Member
Joined: April 13, 2018 Posts: 288 Location: The Dirtiest Of Jersey
Posted: Tue Oct 27, 2020 5:14 am Post subject: Re: T1 fan blade sharpening - effects |
https://www.tandfonline.com/doi/pdf/10.1080/19942060.2010.11015339
Effects of Edge Geometry on Flow Driving of a
Stamped Metal Cooling Fan
Hongmin Li
From Conclusion:
".....The main advantages of the cooling fan with
sharp edges are in the noise reduction, air flow
rate improvement, and the reduction of power
consumption. Sharp edge cooling fans are
recommended for electric motors when any of the
following is true for the application. (1) The
broadband noise level is high. (2) The blade
passing frequency and vortex shedding frequency
spikes are big concerns. (3) The cooling fan
power consumption is a significant part of the
electric motor total power input." |
Posted: Tue Oct 27, 2020 5:58 am Post subject: Re: T1 fan blade sharpening - effects |
ok, next question... why hasnt anyone talked about doing this(well, at least here on the samba), and how should the be sharpened? What angle? what side? Would polishing the blades help too? _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Tue Oct 27, 2020 9:14 am Post subject: Re: T1 fan blade sharpening - effects |
PuddleRainbow, thanks for that reference!
This topic came up when I was discussing Type 1 noise with a turbine engineer last month, and we got on the topic of fan blade design. She suggested sharpening the leading and trailing edges of each fan blade, but I’m not sure what tools I would be able to do that with. Sharpening the outer (trailing) edges is simple enough... but the inners?
I doubt polishing the blades will help; my fan collects a fine layer of fuzz/grime as the miles pass by.
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Tue Oct 27, 2020 11:08 am Post subject: Re: T1 fan blade sharpening - effects |
I don’t have this much time on my hands...the fans work as-built and probably the quietest part of the engine unless you have hydraulic lifters and a quiet muffler |
Posted: Tue Oct 27, 2020 11:38 am Post subject: Re: T1 fan blade sharpening - effects |
Yes, the fan works as built. Especially because they had to build six million of them for mere pennies.
If you spent 30,000 miles a year at 3,800rpm, you would know every single whine and whir too... The Type 1 fan is FAR from the quietest part of the engine. (Take your belt off and go for a drive if you don’t believe me.)
Another sound we can discuss is the 1:1.9 ratio of early bay fan to engine speed. (special belt/pulley setup different from all other Type 1 engines, which run a 1:1.8 or so.) The resulting “chord” of a pitch is a crunchy semi-tone relationship between the engine and fan, while the 1:1.8 is only slightly less irritating. This discussion is worth having if the fan blade sharpening does as described in the article. If the fan cools more, we can slow it down. Less speed is always quieter, but changing the ratio of engine to fan speeds will net subtle sonic success as well.
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Tue Oct 27, 2020 11:59 am Post subject: Re: T1 fan blade sharpening - effects |
As one who has studied "some" fluid dynamics and airfoils, I can say that it's not as simple as just sharpening the tips.
Without empirical testing data, it is hard to be sure you are helping and not hurting.
The angle of the edge. The skewness of the edge. The blend radius, angle of attack: all can play a big part affecting "flow separation" in a flat airfoil.
I have found when VW fans get noisy, it's because they are loaded with debris, or have a flow restriction. |
Dan Ruddock Samba Member
Joined: October 25, 2012 Posts: 3594 Location: Sarasota, in my adopted state of Florida
Posted: Tue Oct 27, 2020 12:06 pm Post subject: Re: T1 fan blade sharpening - effects |
txoval wrote: |
A hydraulic like quiet valve train is possible with solid lifters. Dan |
mark tucker Samba Member
Posted: Tue Oct 27, 2020 12:52 pm Post subject: Re: T1 fan blade sharpening - effects |
yes dan is right, although some people dont think so. as for the fan blade and sharpening it, if you do you need to make a jig so all are the same,witch makes it much eaxer to do also. for the incomming side i wood do it this way,and for the outlet I wood do it that way. not a point from both sides. of coarse then come s the balancing....does ya have a balancer? stand it in the corner and see if it falls over?? I suppose a balanceer could be made somewhat simple if you wished to do so. but....balanced how? this way or that way? is it out on this side or that side of the fin? does it mater? I say MR dyno needs to do one and see what it does!!!! and finaly... is more hp less flow? or same or more flow& less pumping losses? and finaly what about cavatation??? eye wood think that doing the leading&trailing edges right should raise the cavatation rpm...but my eye woods can always see the florist through the trees& flowers. only real tested dayta would be reliable not well I done it any I got 50 more hp.... or a slails mans claims...and finaly the shape of the balde fin.... leave it alone or do some work to it?? and remember more flow may be less hp to the wheels...slower with a better blower so it last longer...or not |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Tue Oct 27, 2020 1:13 pm Post subject: Re: T1 fan blade sharpening - effects |
Ohio Tom wrote: |
This ^^^^^....and
....the angle of the sharpening will vary its effect...depending on the speed the air is moving over the blade (or the blade moving through the air really).
Its just like any other wing. AS speed increases....the boundary layers move around. So you may get it really quiet at one rpm....but create enough turbulence and drag to lose power...or it may be really noisy at another rpm....but actually have less power loss.
And...to get it all working correctly.....across a highly variable rpm....you may need variable pitch.
It would be cool to figure out...but damn...thats a LOT of testing.
Point #2 from Puddlerainbow's "conclusion" from the article....is key to what is being stated above.
Quote: |
(2) The blade
spikes are big concerns. |
Ray |
txoval Samba Member
Posted: Tue Oct 27, 2020 3:38 pm Post subject: Re: T1 fan blade sharpening - effects |
I guess my smartass walked into that comment. Several factors can determine the “quietness” of the valve train. The point I was trying to make is that an Aircooled VW engine is not quiet (compared to a modern Honda Civic for example). I personally have never heard the VW fan over the exhaust or wind blowing in my windows...and in Houston, Texas we drive with the windows down 100% of the time.
Now, if this mod provided significantly better/more efficient cooling I could understand it.
Dan Ruddock wrote: |
txoval wrote: |
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Tue Oct 27, 2020 6:20 pm Post subject: Re: T1 fan blade sharpening - effects |
it should be much more efficient at shredding those mouse nests...and their residents |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Tue Oct 27, 2020 8:43 pm Post subject: Re: T1 fan blade sharpening - effects |
volksworld wrote: |
Like the time I saw a pigeon try to land on the engine cowl of a running Boeing 737-300.
*POP* |
oprn Samba Member
Joined: November 13, 2016 Posts: 12730 Location: Western Canada
Posted: Wed Oct 28, 2020 8:03 am Post subject: Re: T1 fan blade sharpening - effects |
There is no doubt in my mind that it would be possible to improve a stock fan but at what cost in time compared to gains? In my view the effort would be far more productive in designing a variable pitch or variable speed fan. |
Zundfolge1432 Samba Member
Posted: Wed Oct 28, 2020 8:42 am Post subject: Re: T1 fan blade sharpening - effects |
Remembering years ago when balancing became a thing |
Posted: Wed Oct 28, 2020 8:53 am Post subject: Re: T1 fan blade sharpening - effects |
aparently troxol hasent heard a quiet vw. yes they can be as quiet as a honda. |
petrol punk Samba Member
Joined: August 21, 2007 Posts: 975 Location: Las Vegas, NV
Posted: Wed Oct 28, 2020 9:18 am Post subject: Re: T1 fan blade sharpening - effects |
Might be doable with a file. A file as wide as the fan blades could sharpen the outer tips easily. The inner would be a pain but you could probably do it with a small file _________________ 36hp '56 European DeLuxe oval, '70 bug 1835cc dual 36DRLA, and a '98 4x4 5spd single cab Tacoma |
txoval Samba Member
Posted: Wed Oct 28, 2020 11:02 am Post subject: Re: T1 fan blade sharpening - effects |
I would pay to hear VW with a stock pee-shooter exhaust be as quiet as a new honda civic, lol good luck with that. Change the exhaust to an A-1 merged header system and you'll need extra good luck. Now, perhaps if you ran the exhaust to the front of the car you could accomplish that
This is comical...post a video
mark tucker wrote: |
Posted: Wed Oct 28, 2020 2:47 pm Post subject: Re: T1 fan blade sharpening - effects |
what does exhaust have to do with engine noise? also good mufflers are very rare on vw's. |
