sidtheleaper28 Samba Member
Posted: Tue Oct 27, 2020 8:55 am Post subject: Will adding a thermostat increase my heating airflow. |
I've owned 2 beetle in my life and seen many others. Not once have I seen a beetle with the cooling thermostat. If in place, it should while closed increase airflow, you would think through the heater and defrost system? |
mukluk Samba Member
Posted: Tue Oct 27, 2020 9:00 am Post subject: Re: Will adding a thermostat increase my heating airflow. |
If you're talking about the 1965+ flap-style thermostat setup, then yes, airflow through the heater boxes will likely be increased to some extent while the thermostat flaps are closed. The earlier throttle ring thermostat reduces the amount of air permitted into the fan while cold. _________________ 1960 Ragtop w/Semaphores "Inga" |
gt1953 Samba Member
Posted: Tue Oct 27, 2020 11:21 am Post subject: Re: Will adding a thermostat increase my heating airflow. |
I will say one thing, the air will be a lot warmer/hotter. You will get more air flow when the the flaps are closed. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
wcfvw69 Samba Purist
Posted: Tue Oct 27, 2020 5:17 pm Post subject: Re: Will adding a thermostat increase my heating airflow. |
I've found reinstalling the thermostat and flaps makes a substantial difference in the heated air getting hot faster.
The other key factor is ensuring you're running the VW heater boxes, not the aftermarket ones that are about 1/4 as effective. _________________ Contact me at [email protected]
The Samba member since 2004.
FL-Frank Samba Member
Joined: August 08, 2015 Posts: 823 Location: Jupiter, Florida
Posted: Wed Oct 28, 2020 6:34 am Post subject: Re: Will adding a thermostat increase my heating airflow. |
I added a correct thermostat to mine about a year ago, and it starts and runs so much better now! Definitely worth it! _________________ “Tinker Toy” 1967 Savannah Beige Beetle Sedan...........Mostly Original Survivor
“Fritz” 1964 Gulf Blue Karmann Ghia Coupe...Complete Pan-Off Restoration SOLD |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Posted: Wed Oct 28, 2020 6:58 am Post subject: Re: Will adding a thermostat increase my heating airflow. |
sidtheleaper28 wrote: |
With an operational thermostat, before the flaps open, the air flow for the heat will be more, as some air will not be flowing over the cylinders, so has to move through the shroud hoses. And the cylinders and heater boxes will warm up faster.
Once the thermostat opens fully, the volume of air will decrease some as some of the air will now go over the cylinders. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
