puchfinnland Samba Member
Joined: December 26, 2005 Posts: 279 Location: Deale Maryland
Posted: Tue Oct 27, 2020 5:30 pm Post subject: Mansi has impress me again! Newly designed 1:35 rocker arms |
Marco just posted these on his facebook page,
Wow!!
rockers come with cro-mo, pushrods, and lash caps
_________________ ABYC marine master technician , EX European auto technician, new business- EASTCOASTWEST , custom work on campers, only systems, no mechanical |
Posted: Tue Oct 27, 2020 5:31 pm Post subject: Re: Mansi has impress me again! Newly designed 1:35 rocker arms |
there is the video on his page
https://mansispeed.com/resources/ _________________ ABYC marine master technician , EX European auto technician, new business- EASTCOASTWEST , custom work on campers, only systems, no mechanical |
livethevanlife Samba Member
Joined: May 18, 2015 Posts: 204 Location: La Paz, Baja California Sur
Posted: Tue Oct 27, 2020 7:20 pm Post subject: Re: Mansi has impress me again! Newly designed 1:35 rocker arms |
Been waiting on these. What are the estimated HP/TQ gains on a stock 2.1 with his injectors? _________________ www.LiveTheVanLife.com
www.VentureLibre.com
https://www.PeaceVans.com/baja
1991 Syncro Triple Knob Westfalia "Miki" 2.2WBX
1992 Syncro Triple Knob Tintop "Schnitzel" 1.9AAZ
1990 Syncro Rear Locker Doka Subi 2.2
1974 VW Thing 1835cc
1989 VW Carat |
Syncronoid Samba Member
Joined: January 21, 2012 Posts: 1111 Location: Stanford, CA and Bend, OR
Posted: Tue Oct 27, 2020 8:23 pm Post subject: Re: Mansi has impress me again! Newly designed 1:35 rocker arms |
Marco quotes 10-12HP, nearly the same as he quoted for the 1.25's. Someone needs to dyno these.
livethevanlife wrote: |
Been waiting on these. What are the estimated HP/TQ gains on a stock 2.1 with his injectors? |
_________________ '90 Syncro Westy w/GW2.5L |
Posted: Wed Oct 28, 2020 5:53 am Post subject: Re: Mansi has impress me again! Newly designed 1:35 rocker arms |
Thank you. Any reasons why you might not want to add these? Downsides? I thought I had heard that higher ratio rockers could sacrifice low end power for gains on the top end. These seem great, just trying to educate myself and others. _________________ www.LiveTheVanLife.com
1989 VW Carat |
Schustie Samba Member
Joined: January 21, 2019 Posts: 24 Location: Bend, OR
Posted: Wed Oct 28, 2020 7:38 am Post subject: Re: Mansi has impress me again! Newly designed 1:35 rocker arms |
beautiful photos. Thanks for posting.
My fantasy Engine rebuild is taking shape in my mind. _________________ Eric
1990 Westy FAS Gen V TDi |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Wed Oct 28, 2020 11:06 am Post subject: Re: Mansi has impress me again! Newly designed 1:35 rocker arms |
Thank you. Any reasons why you might not want to add these? Downsides? I thought I had heard that higher ratio rockers could sacrifice low end power for gains on the top end. These seem great, just trying to educate myself and others. |
Bump!
Is this a thing?
Haven't heard of such, and inquiring minds want to know! _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Wed Oct 28, 2020 11:56 am Post subject: Re: Mansi has impress me again! Newly designed 1:35 rocker arms |
The beauty of high ratio rockers is increased air flow without adversely affecting low end performance. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6360 Location: Honolulu,Hawaii and France
Zeitgeist 13 Samba Member
Posted: Wed Oct 28, 2020 12:43 pm Post subject: Re: Mansi has impress me again! Newly designed 1:35 rocker arms |
Someone more learned than me might know this, but what's the difference between the valve lift/duration of ratio rockers vs. just a high lift cam? Does the case not have enough clearance for the cam to match the amount of the rockers? _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
11BC2 Samba Member
Joined: August 27, 2017 Posts: 495 Location: Cool, California
Posted: Wed Oct 28, 2020 2:23 pm Post subject: Re: Mansi has impress me again! Newly designed 1:35 rocker arms |
ALIKA T3 wrote: |
I spot an imperial bolt on this rocker shaft |
And of such a low grade...what would Carrol Smith say! |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Thu Oct 29, 2020 8:36 am Post subject: Re: Mansi has impress me again! Newly designed 1:35 rocker arms |
11BC2 wrote: |
ALIKA T3 wrote: |
That's funny! When I was racing my budget was nowhere near high enough to make him happy...
But I don't think that cap screw is doing a whole lot of actual work. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Thu Oct 29, 2020 8:48 am Post subject: Re: Mansi has impress me again! Newly designed 1:35 rocker arms |
Zeitgeist 13 wrote: |
Someone more learned than me might know this, but what's the difference between the valve lift/duration of ratio rockers vs. just a high lift cam? Does the case not have enough clearance for the cam to match the amount of the rockers? |
Ratio rockers would be a bolt on option vs splitting the case for a performance cam. And yes, you’d want to be sure the lobes had clearance.
As long as the pistons and pushrods have clearance, looks like a nice add on anyone could handle. _________________ ☮️ |
vanaru Samba Member
Joined: November 02, 2005 Posts: 169 Location: Sykesville, Maryland
Posted: Sun Nov 01, 2020 12:37 pm Post subject: Re: Mansi has impress me again! Newly designed 1:35 rocker arms |
The 5/16 24 grade 5, or the equivalent of 8.8 metric, Bolt is probably overkill for the application.
[/quote] _________________ 1962 sunroof beetle
1982 porsche 911 SC
1991 vanagon WRX powered |
GUAPO _ VANAGON Samba Member
Joined: February 18, 2014 Posts: 4 Location: San Antonio
Posted: Wed Nov 11, 2020 9:57 pm Post subject: Re: Mansi has impress me again! Newly designed 1:35 rocker arms |
So has anyone installed these on their rig, very interested since i have a freshly build 2.1 that I haven't installed. What would I gain? |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Sat Mar 13, 2021 2:39 pm Post subject: Re: Mansi has impress me again! Newly designed 1:35 rocker arms |
So it's 2021, has anyone bought a set? _________________ This free advice is worth exactly what you paid for it.
marcotheturbosteamengine Samba Member
Posted: Sat Mar 13, 2021 7:34 pm Post subject: Re: Mansi has impress me again! Newly designed 1:35 rocker arms |
Steve M. wrote: |
So it's 2021, has anyone bought a set? |
Im sure someone will post there experience, lots of sets have been sent out. |
Posted: Sat Mar 13, 2021 8:14 pm Post subject: Re: Mansi has impress me again! Newly designed 1:35 rocker arms |
marcotheturbosteamengine wrote: |
Steve M. wrote: |
I'm sure it will be a postive experience! _________________ This free advice is worth exactly what you paid for it.
Posted: Sun Mar 14, 2021 6:58 am Post subject: Re: Mansi has impress me again! Newly designed 1:35 rocker arms |
I have the Mansispeed Injectors and Rockers installed on my newly rebuilt 2.1. The combination is great, with added umph, made even better with the techtonics ECU chip. Worth the money, every little bit counts. As for dyno numbers or anything other than seat of the pants I cant comment, but the combination feels great to me. _________________ www.LiveTheVanLife.com
1989 VW Carat |
boxer74 Samba Member
Joined: July 03, 2011 Posts: 709 Location: Ontario, Canada
Posted: Wed May 26, 2021 12:24 pm Post subject: Re: Mansi has impress me again! Newly designed 1:35 rocker arms |
Are these worth considering for a 1.9? _________________ 74 Super
84 Westy |
