depps74 Samba Member
Posted: Tue Oct 27, 2020 7:18 pm Post subject: Disconnected battery, now reconnected it seems weaker |
1990 multivan. I Recently installed a kitchenette behind the passenger seat and as such had to remove the battery to secure the kitchenette to battery compartment. When I reconnected the battery the positive nut was stripped and very hard to tighten. I had to tap it and really work it to tighten and its still not really perfect. While doing this a couple of times the ground wire was attached (by just drifting onto the battery nut) and I got a few sparks.
Now when I start the van it takes the starter longer to start the van, and on one occasion it dint have enough power to start the van and I had to jump it.
Did I kill my battery? Or do I just need to get that connection rock solid? My mechanic said the starter is perfect. I have no idea how old the battery is, but looks newish.
A side note, the cable to the starter did come off once, and I cleaned and clamped the connection better. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Tue Oct 27, 2020 7:28 pm Post subject: Re: Disconnected battery, now reconnected it seems weaker |
Batteries don't last forever, but here's my simple three-step plan:
1) Pull battery again & clean the ground cable connection to body.
2) Replace wonky + clamp.
3) Reinstall battery & put it on a good charger overnight (8-10 amps).
4) Try again & be ready to buy a new battery....
(...doesn't matter what it looks like, it's just gotta work...)
Optional step 3.5) Run to your FLAPS & ask for a free battery load test.
(You'll probably end up doing this sooner or later...) <shrug>
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Wed Oct 28, 2020 4:46 am Post subject: Re: Disconnected battery, now reconnected it seems weaker |
Always disconnect the battery ground before you disconnect the positive cable. Those sparks could cause in rare instances an explosion. Certainly your arching drained the battery some. Time to get your volt meter out and measure what’s going on. _________________ ☮️ |
jimf909 Samba Member
Posted: Wed Oct 28, 2020 7:28 am Post subject: Re: Disconnected battery, now reconnected it seems weaker |
MarkWard wrote: |
Always disconnect the battery ground before you disconnect the positive cable. Those sparks could cause in rare instances an explosion. Certainly your arching drained the battery some. Time to get your volt meter out and measure what’s going on. |
This was drilled into me decades ago. My young and dumb brain wondered "why disconnect the negative, the red one carries all the power" (false). When the negative cable is connected to the battery the entire chassis becomes negative and is waiting to create a short anytime a wrench (or wire) connected to the positive side of the battery touches the chassis. When negative is divorced from all circuits you can touch the positive wires anywhere you want (mostly) and there's no harm. _________________ - Jim
Abscate wrote: |
Posted: Wed Oct 28, 2020 8:41 am Post subject: Re: Disconnected battery, now reconnected it seems weaker |
For vans with more than one battery, I suggest disconnecting both battery ground cables. At one time I had a Yandina combiner. The batteries should have been isolated, but were combined. I got a few surprise sparks changing the alternator. _________________ ☮️ |
jlrftype7 Samba Member
Posted: Wed Oct 28, 2020 10:51 am Post subject: Re: Disconnected battery, now reconnected it seems weaker |
MarkWard wrote: |
For vans with more than one battery, I suggest disconnecting both battery ground cables. At one time I had a Yandina combiner. The batteries should have been isolated, but were combined. I got a few surprise sparks changing the alternator. |
Oops.....THAT WOULD be a surprise.... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
