charleslabri Samba Member
Joined: December 08, 2019 Posts: 615 Location: Nashville/Yosemite
Posted: Mon Nov 02, 2020 10:20 am Post subject: Correct ID for the brake vacuum |
My line is totally shot, did some measurements, and best as I can tell its a 11/32"- but want to make sure before i go buy 20' of hose |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17153 Location: Retired South Florida
Posted: Mon Nov 02, 2020 10:25 am Post subject: Re: Correct ID for the brake vacuum |
Can't help you with the ID, but if you are replacing vacuum tube with hose, it will need to be strong enough not to collapse. VW back in the day, had vacuum hose with a wire reinforcement.
I've not seen the plastic tube actually fail. Are you sure you need to run the entire length of the van? _________________ ☮️ |
Posted: Mon Nov 02, 2020 10:41 am Post subject: Re: Correct ID for the brake vacuum |
MarkWard wrote: |
I've not seen the plastic tube actually fail. Are you sure you need to run the entire length of the van? |
I guess I could cut the portions where its got holes in and splice, but it seems to be a pretty straightforward line with a check valve, so I figured id just replace it |
Posted: Mon Nov 02, 2020 11:12 am Post subject: Re: Correct ID for the brake vacuum |
It just needs to be thick walled. Otherwise, the vacuum inside will allow it to collapse on itself. _________________ ☮️ |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4026 Location: Redwood City, California
Posted: Tue Nov 03, 2020 7:54 pm Post subject: Re: Correct ID for the brake vacuum |
I just bought this hose for my Truck. The only place that actually had it in stock was "West Coast Metric" they sell it in 3 ft lengths and it is pricey. My original lasted over 30 years so spending $45.00 on its replacement is OK with me.
These are expensive toys, don't cheap out over a few dollars.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Wed Nov 04, 2020 9:04 am Post subject: Re: Correct ID for the brake vacuum |
Tube for Brake Booster - 12.5x1.25x3450
Plain ole 1/2" nylon air brake tubing. Both have plain ends. I would use internal sleeves. _________________ Schau in das Buch |
