VWinny Samba Member
Posted: Fri Apr 16, 2021 6:48 am Post subject: Re: What did you do to your Eurovan or T4 today? |
Yanked Out the engine.
{Before Pics} |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Fri Apr 16, 2021 3:41 pm Post subject: Re: What did you do to your Eurovan or T4 today? |
Finally killed off the code for temp sensor performance by replacing it
About $8 from FCP, a half hour to put in. I don’t like the play I;the tie rods so might do all four as PM _________________ .ssS! |
VWinny Samba Member
Posted: Wed Apr 21, 2021 7:03 am Post subject: Re: What did you do to your Eurovan or T4 today? |
Tidying up wiring, getting ready to remount the engine Ive completely rebuilt in my garage.
Whridlsoncestood Samba Member
Joined: November 25, 2020 Posts: 178 Location: Orange, CT
Posted: Thu May 06, 2021 8:55 pm Post subject: Re: What did you do to your Eurovan or T4 today? |
Successful couple of days. Finally got some wether to get to e van up in the air for a while. Transmission flush. Oil change. New coolant temp sensor. Two new radiator fan resistors and got my ac working but that gives me another job of replacing the auxiliary water pump! It got toasty apparently. That’ll get swapped in round two of maintenance with new pads and rotors at all 4 corners and a brake fluid flush.
_________________ 2001 EV MV |
Posted: Sat Jun 05, 2021 6:10 am Post subject: Re: What did you do to your Eurovan or T4 today? |
Finally got the awning on
streamr Samba Member
Joined: February 26, 2007 Posts: 555 Location: Southwest FL
Posted: Sat Jun 05, 2021 6:35 am Post subject: Re: What did you do to your Eurovan or T4 today? |
Nice, can you show/tell us how you connected to roof? Thanks. _________________ '03 MV |
Posted: Sat Jun 05, 2021 7:41 am Post subject: Re: What did you do to your Eurovan or T4 today? |
streamr wrote: |
Nice, can you show/tell us how you connected to roof? Thanks. |
Mounted it to the square Thule bars that were on the van when I bought it using the gowesty brackets. I want to find a basket to go on the bars next.
Posted: Sat Jun 05, 2021 7:51 am Post subject: Re: What did you do to your Eurovan or T4 today? |
Thanks. I have the Yakima round bars but probably could make that work. Also, I use the Yakima LoadWarrior (I think that's what they call it). It may not fit since your bars are spaced farther apart than mine. They have a "Mega" version that is longer. Their mounting system works with square bars, too. _________________ '03 MV |
Posted: Sat Jun 05, 2021 8:41 am Post subject: Re: What did you do to your Eurovan or T4 today? |
streamr wrote: |
Thanks. I have the Yakima round bars but probably could make that work. Also, I use the Yakima LoadWarrior (I think that's what they call it). It may not fit since your bars are spaced farther apart than mine. They have a "Mega" version that is longer. Their mounting system works with square bars, too. |
Kit works even better for round bars! It comes with U bolts so you don’t have to drill the bar.
I have to keep the rack bars far apart since ARB says not to have more than 28” past the mounting points. A few of the longer baskets are built with extension pieces and still require the closer bar spacing which is kinda silly.
jean-claude Samba Member
Posted: Thu Jun 24, 2021 8:42 pm Post subject: Re: What did you do to your Eurovan or T4 today? |
Westfabulous wrote: |
EVCSNOW wrote: |
I removed my totally non functional Westfalia camper water tank level sensor; cut it open; fully rebuilt it, including the electronics; water tested it; re-installed it; and enjoyed seeing the functional water tank icon on the overhead display again. This had never worked since I’ve owned the van, but it’s all good now. |
What did you have to do to rebuild the tank level sensor? |
It was pretty much a full rebuild: new resistors, new reed switches, new lead wires, new mounting hardware (the original mounting hardware disintegrated). Reinstalled the repaired electronics and then repaired the existing tube after cutting it open. Water tested for 24 hours. Bench tested. Tested in vehicle. Installed in vehicle. Voila! |
Would you be interested in doing another one? If so what would you charge? If not I totally understand. Ive been trying to order one (even though the price hurts my feelings) but no-one has any in stock. I have ordered 2 just to have the company come back and tell me they actually don't have any to ship and then they refund my money. I wish one from a t3 would work because they are half the price and US stock is available . |
VWinny Samba Member
Posted: Sun Jul 04, 2021 8:57 pm Post subject: Re: What did you do to your Eurovan or T4 today? |
Literally dug out the flooring with a shovel on this one.
Threw down some fiberglass, killed the rust with some paint,
ran treated subfloor, vapor barrier/ comfort cushion and 100% waterproof flooring.
funky wood
drab to fab ~~ |
VWinny Samba Member
Posted: Sat Jul 10, 2021 7:48 pm Post subject: Re: What did you do to your Eurovan or T4 today? |
I ordered a new camshaft pulley.
Joshwa Samba Member
Joined: November 18, 2015 Posts: 810 Location: North Seattle WA
bikes! Samba Member
Joined: April 27, 2014 Posts: 97 Location: Central CA Coast
Posted: Fri Sep 10, 2021 8:05 pm Post subject: Re: What did you do to your Eurovan or T4 today? |
The metal T looks well made. Who is the supplier for those? |
Joshwa Samba Member
ELO78 Samba Member
Joined: September 18, 2015 Posts: 168 Location: Oak Park, IL
Posted: Sat Sep 11, 2021 8:05 am Post subject: Re: What did you do to your Eurovan or T4 today? |
These plastic coolant tees are common failure items at this point, right? Seems like cheap insurance / peace of mind to replace them all.
If one were to replace them all in one swoop, how many are there and where are they located throughout the cooling system? _________________ Eric
1990 Westy Multivan, 2.1 L WBX, 4-speed - SOLD
2003 EuroVan Westy Weekender |
Joshwa Samba Member
bikes! Samba Member
Posted: Tue Sep 14, 2021 5:56 pm Post subject: Re: What did you do to your Eurovan or T4 today? |
ELO78 wrote: |
If one were to replace them all in one swoop, how many are there and where are they located throughout the cooling system? |
Over on the vortex, KBATTPO has a great write up for 24V VR6 cooling systems. The PDF he links to has a list of the various fittings. |
Mary Scaia Samba Member
Posted: Thu Nov 18, 2021 9:34 am Post subject: Re: What did you do to your Eurovan or T4 today? |
I'm picking up my 'new to me' 1992 Westfalia Eurovan CV today
leadvillian Samba Member
Joined: December 05, 2020 Posts: 10 Location: Colorado
Posted: Sat Nov 20, 2021 2:35 pm Post subject: Re: What did you do to your Eurovan or T4 today? |
Built these shelves inside the cabinets to improve the EVC storage situation....
