Rocky Mountain Westy Samba Member
Joined: April 17, 2008 Posts: 1031 Location: Fort Collins Colorado
Posted: Wed Nov 04, 2020 12:43 pm Post subject: RMW Subaru Conversion kit. The rumor is a reality |
Hey Guys and Gals,
I know there have been rumors over here for quite sometime about RMW releasing a complete Bay Window conversion kit. I probably even started some of them. The reality is that we started working on it over 5 years ago. It would get attention, then get sidelined. Then it would get tested and never it would fail the criteria. Then it would get re-engineered and blah,blah,blah. It just took a long time to get it right. I want to start this link to help answer questions and support for the kit. So if you have questions, fire away.
Our goal was to develop a kit with minimal body modification that you could drive at cruising speed without running the electric fans or overheating. We tried different variations of the belly radiator and it always seemed to have drawbacks, whether it was ground clearance or heating up the floor or just not getting enough cooling efficiency to make driving comfortable without staring at the temp gauge. After a few renditions and lots of testing, we ultimately moved on to working on a in bay twin radiator set up. We found this to work really well. I think a lot of people are skeptics here. I will share the secret though. All the air that comes into the rear vent needs to go through the radiator. if there is air gaps around the radiator, the efficiency drops quickly. So we spent the time to make a full block of plate kit that uses weatherstrip to seal each radiator to the cavity. The next key is the efficiency of the fan. Putting a round fan directly on a square radiator leaves quite a bit of surface area that doesn't get cooled when the fan is on. This naturally creates issues with the duration and duty cycle of the fan system. So we made Aluminum fan shrouds so that when the fan is on, the entire radiator surface is getting cooled. This make the fans runs less frequently and for a shorter amount of time.
We made a custom Air box too. The engine bay can get toasty. The cooler your intake air, the better your engine will perform. So our Airbox slips into the round hole in the passenger side of the engine bay. The air is then sucked into the engine through the stock ECU hole. This is in the sealed off area before the radiator. This cavity is significantly cooler than the engine bay itself. We also have a mandrel tubing bender. We made custom coolant pipes to run all the plumbing in a nice neat layout. Nothing looks worse than corrugated flexible hose in the engine bay.
Our kit also includes a battery relocation kit, an electrical wiring harness to run the cooling fans. The battery is relocated underneath the rear seat. We have found that while this does take up a little bit of storage space, it is has it's merits in this location.
We also have a 250 page manual with lots of pictures. We anticipate our customers will drive most of the editing in the manual. We did our best with version 1 but we aren't necessarily technical writers and you don't know what you don't know. So the manual is a great guideline to follow but common sense and some basic mechanical knowledge and understanding will really go a long ways.
We use a similar exhaust to our Vanagon conversion. It is all stainless steel and hand TIG welded in our shop. We also do all the bending and parts processing in house for the exhaust. This has been a proven system on over 1000 Vanagons and we rarely have warranty issues.
Our engine support bar is very solid. It ties into the upper unibody where the upper trans attachment points are and also ties into the rear bumper bolts. It uses the stock square rubber Subaru motor mounts.
Our shortend oil pan that we use on Vanagons is a direct fit here as well.
We make our own throttle body reverser. We also have a simple throttle cable set up that is very smooth and crisp.
We acknowledge that there are a lot of DIY solutions to getting this done. We encourage it. Our goal here is to not compete with that. We understand that people can spend there time sourcing things from all over and spending less than $3k in parts. Often times there is lot of figuring out time and a lot of time spent creating little or big solutions. We are looking to help the person that doesn't want to figure out all those things.
Admittingly I have been driving my Bay Window a lot more since the conversion. It is a pleasure. We are here to help. Thanks so mush to the Samba and the VW community. _________________ Rocky Mountain Westy Inc.
www.rockymountainwesty.com
970-310-3441
[email protected]
The Splitzgauer build (when I have time to work on it and update the thread)
http://www.thesamba.com/vw/forum/viewtopic.php?t=497133 |
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Wed Nov 04, 2020 12:58 pm Post subject: Re: RMW Subaru Conversion kit. The rumor is a reality |
Omg! Yes!!! What’s the price? And what is the transmission I used? What about all the wiring? Gauges? Etc? What bus model is the kit available for, early? Late?
And when can it actually be purchased? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
Posted: Wed Nov 04, 2020 1:10 pm Post subject: Re: RMW Subaru Conversion kit. The rumor is a reality |
ivwshane wrote: |
And when can it actually be purchased? |
It does require a donor engine and wiring harness. We can modify the harness for you to fit in the Bus. It is set up for 72-79 buses. It is set up for the original transmission. We do suggest getting the later model bell housing if you have an early trans. It is ready to ship on the Van Cafe website. _________________ Rocky Mountain Westy Inc.
970-310-3441
[email protected]
alman72 Samba Member
Joined: October 09, 2014 Posts: 2573 Location: MICHIGAN
Posted: Wed Nov 04, 2020 1:34 pm Post subject: Re: RMW Subaru Conversion kit. The rumor is a reality |
air thru the orig ECU hole.… what do non FI busses do in that case? |
Joined: January 01, 2007 Posts: 16883 Location: sticksville, ct.
Posted: Wed Nov 04, 2020 1:39 pm Post subject: Re: RMW Subaru Conversion kit. The rumor is a reality |
ivwshane wrote: |
fiddy8hunnitdollhairs, plus 1k to have your harness done
https://www.vancafe.com/product-p/rmw-baywinkit.htm
mike, i'm gonna call b/s on the underbelly radiator running hot. I agree, the location isn't for everyone....but I have a bus in dallas WITH a/c that hasn't broken 205*
that said, looks like a decent kit. will this system work with a/c? _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
SGKent Samba Member
Since a lot of bays that will want these are in western smog states, have you submitted the package to say CARB for approval? Anything 2002 - 2004 would require it because the bus would then be treated at the engine YOM. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Nov 04, 2020 1:50 pm Post subject: Re: RMW Subaru Conversion kit. The rumor is a reality |
That was my next question: will these pass smog or will a 77 need to be smogged if the engine is from a 2000 forester?
Also, with all that air coming into the engine bay, how does it get out?
Your kit lists a new clutch option, is that just a stock clutch for a bus or a needed accessory? My 091 transmission was just rebuilt including new flywheel and clutch.
I also tried to add it to the cart and it said it was out of stock. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
SGKent Samba Member
Posted: Wed Nov 04, 2020 2:10 pm Post subject: Re: RMW Subaru Conversion kit. The rumor is a reality |
ivwshane wrote: |
I also tried to add it to the cart and it said it was out of stock. |
Shane - if you install it in a 1977 bus in California the bus will end up going to a referee who will put a tag on it so it gets tested as a later year Sub conversion. The only issue I know people here in CA have is that every sensor, wire and hose have to be intact the same as the donor year to pass smog. If the original engine had a sensor in the trans that fed info to the ECU, then it has to exist to pass smog. That means if the original engine family came from an automatic that had torque sensing sensors that sent data to the ECU the same trans sensors have to exist with the conversion. If the clutch sends a signal when it is pushed in that changes what the ECU does, that same sensor has to be on the conversion. This means that someone has to be careful which car and year they pull a donor engine from.
I don't mean this as a political statement but with the election results looking like essentially Kamala Harris being the next US president, and the Trump admin having relaxed smog standards across the USA, I wonder if she will push her views on California smog onto the rest of the USA. If so it is likely CARB standards will be forced on others. That has been the pattern when other states like NY etc want to update their smog laws. Some of the non-CARB products Bus Depot has sold over the years have pissed off CARB to where they issued orders to Bus Depot to stop shipping them to CA or face huge fines. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Nov 04, 2020 3:06 pm Post subject: Re: RMW Subaru Conversion kit. The rumor is a reality |
skills@eurocarsplus wrote: |
that said, looks like a decent kit. will this system work with a/c? |
Yeah, My 78 Westy has A/C. As you know, that is a whole nother animal.
I get it the the belly radiator works for folks. We just weren't confident in putting it out to the masses that way. In the end, the engine bay system is easier to manufacture and install.
You definitely get cred for the way you do it. Hopefully this kit will allow more folks to have the same experience. _________________ Rocky Mountain Westy Inc.
970-310-3441
[email protected]
Posted: Wed Nov 04, 2020 3:11 pm Post subject: Re: RMW Subaru Conversion kit. The rumor is a reality |
ivwshane wrote: |
We leave this up to the customers. We can't track and comply with every rule out there.
You can reuse your clutch if it is new or low mileage.
The air goes down through the engine bay and out the bottom of the van. _________________ Rocky Mountain Westy Inc.
970-310-3441
[email protected]
Posted: Wed Nov 04, 2020 3:48 pm Post subject: Re: RMW Subaru Conversion kit. The rumor is a reality |
Rocky Mountain Westy wrote: |
for sure, a/c adds to the mess
steve, I REALLY hope you're wrong this time _________________
Jake Raby wrote: |
Brian wrote: |
RalphWiggam Samba Member
Joined: February 02, 2018 Posts: 906 Location: SouthEast
Posted: Wed Nov 04, 2020 6:54 pm Post subject: Re: RMW Subaru Conversion kit. The rumor is a reality |
Damn it why couldnt this kit come out before I dropped > 6k on my basement T4 rebuild?
Can't wait to see some installs and testing data. |
Posted: Wed Nov 04, 2020 9:06 pm Post subject: Re: RMW Subaru Conversion kit. The rumor is a reality |
SGKent wrote: |
ivwshane wrote: |
I don't mean this as a political statement but with the election results looking like essentially Kamala Harris being the next US president, and the Trump admin having relaxed smog standards across the USA, I wonder if she will push her views on California smog onto the rest of the USA. If so it is likely CARB standards will be forced on others. That has been the pattern when other states like NY etc want to update their smog laws. Some of the non-CARB products Bus Depot has sold over the years have pissed off CARB to where they issued orders to Bus Depot to stop shipping them to CA or face huge fines. |
Hmm...I think the sensors I’d be most worried about is the O2 sensors because there are two but there are also two cats on a 2000 forester and I don’t see that happening on a bus.
The other thing I’d have to think about is how cabin heat is handled. _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
SGKent Samba Member
Posted: Wed Nov 04, 2020 9:33 pm Post subject: Re: RMW Subaru Conversion kit. The rumor is a reality |
cabin heat would be easy. There are a couple Vanagon conversions who explained what they went thru to get past BAR. It was more than a conversion in another state would be. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Nov 05, 2020 9:37 am Post subject: Re: RMW Subaru Conversion kit. The rumor is a reality |
This is the best quote on the Samba. So many customers ask if the part is German... The standard reply is, "You do realize that Germans know how to buy parts in China too..." _________________ Rocky Mountain Westy Inc.
970-310-3441
[email protected]
Abscate Samba Member
Posted: Thu Nov 05, 2020 9:55 am Post subject: Re: RMW Subaru Conversion kit. The rumor is a reality |
In NY the focus is on Diesel emissions from commerical stuff - nothing in the works for passenger cars. We stopped smogging when engine management became so good that if it doesn't code, its clean.
Good BG conspiracies are fun to speculation, but eventually, as the 'ET' line goes...."This is reality"
Focus of new admin will/should be repairing international relations, first. _________________ .ssS! |
Posted: Thu Nov 05, 2020 11:16 am Post subject: Re: RMW Subaru Conversion kit. The rumor is a reality |
Abscate wrote: |
Focus of new admin will/should be repairing international relations, first. |
Speculating on the country adopting stricter emissions control standards and acting like that is a bad thing, is completely selfish. Everyone knows internal combustion engines will soon be a thing of the past. Our kids and grandkids will forever be wondering why we were such assholes to the environment.
For me this kit is a step in the right direction. We all know how much better EFI controls emissions and fuel economy. My bus is tuned very well, but still smells like total shit if you are riding behind it compared to the other 99% of cars on the road. |
SGKent Samba Member
Posted: Thu Nov 05, 2020 12:22 pm Post subject: Re: RMW Subaru Conversion kit. The rumor is a reality |
RalphWiggam wrote: |
Abscate wrote: |
Strange - my bus is almost as clean burning as my MDX. Unless you live in California and have had exposure to the smog laws here you really don't have any idea how nanny they are. Besides, California has already banned the sale of cars with internal combustion engines as of 2035. [Admin removed short political trolling statement] _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
earlybayjim Samba Member
Joined: July 12, 2013 Posts: 249 Location: East Dubuque, IL
Posted: Thu Nov 05, 2020 1:08 pm Post subject: Re: RMW Subaru Conversion kit. The rumor is a reality |
Is there an early bay kit in the works? Are you going to sell any of the parts separately, like the engine mount?
Its cool that this finally happened. Good job. _________________ 1971 Chianti Red Westfalia x2
1985 Westfalia
1984 tintop |
