Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Fri Nov 06, 2020 2:15 pm Post subject: Drain Flaps |
These are the flaps on the inside of the rear fender area. I want to freshen mine up. Is the rubber part available or should I just make some? How about the push-on retainers?
Here's a great image of them in place from Yeti69's gallery
Max
Dfasty Samba Member
Joined: November 22, 2005 Posts: 528 Location: north bay,ca.
Posted: Fri Nov 06, 2020 7:26 pm Post subject: Re: Drain Flaps |
the push on retainers are at McMaster or local hardware stores. _________________ 70 fastback automatic 06 invader |
Simon DeCasas Samba Member
Posted: Sun Nov 08, 2020 11:29 am Post subject: Re: Drain Flaps |
Are these the same as a notchback? |
Bobnotch Samba Member
Posted: Sun Nov 08, 2020 3:13 pm Post subject: Re: Drain Flaps |
Max Welton wrote: |
Max |
I'd probably make some new ones. In my area the metal likes to rust away.
You could use some 3M Window Weld to glue the rubber back on, and maybe some plastic push pins (used on newer cars to hold plastic parts on) to hold the rubber on for the flap. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun Nov 08, 2020 3:15 pm Post subject: Re: Drain Flaps |
Simon DeCasas wrote: |
They are for the later model Notchbacks. At least on my 71 Notch they were the same as the Square that donated them.
Don't know about the early cars. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Sat Nov 14, 2020 9:06 am Post subject: Re: Drain Flaps |
Drill out the rivets, keep the metal pieces (or use them as a template to make new pieces), use the rubber part as a template on something this:
https://www.mcmaster.com/rubber-sheets/backing-typ...er-sheets/
Chrome/plate/paint the metal parts, use new rivets and you're all done. |
